Color matched bumper end cap thread.
Discussion in '2.5 Gen Tundras (2014-2021)' started by r4z0r51o, Feb 18, 2017.
  1. Apr 30, 2018 at 7:44 AM
    #181
    showtime240
    showtime240 New Member
    Not sure , I never use pressure washers. I just use a 2 bucket system with a microfiber sponge.
    I tired using the pressure washer with foam cannon and I still had to scrub the truck by hand. Didnt make any sense to whip out the pressure washer for something I have to scrub anyway.
  2. Jun 1, 2018 at 6:43 PM
    #182
    HecticEnergy
    HecticEnergy New Member
    TJ
    SE Texas
    2017 MGM Tundra SR5
    Winjet Rear brake lights, leather seats, BackFlip tonneau cover, Spyder headlights, Pro Grille, pop&lock
    I bought plastics to replace the chrome. The rear ones seem to be missing some material along the top. Seems like theres an extra bracket for the plastic ones for reinforcement that the chrome ones didnt need.
    I could be wrong as i havent disassembled anything yet... id hate to get into it and have to redo and undo it all over again because im missing pieces...
    Thanks in advance!
    Never mind - I found it, just had to dig deeper...
    https://www.tundras.com/threads/201...-number-cost-and-part-number-break-down.6523/
  3. Jun 2, 2018 at 2:19 PM
    #183
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    2018 Black TRD OR CM Limited
    I scored a set of end caps from a platinum on CL and having them painted to match @ a local body shop. all together I’m at 285 between parts and paint, will install when I figure out what I’m doing with the chrome surround and bulge. I don’t really mind the grill insert that’s on my 18 limited.
  4. Jun 3, 2018 at 11:10 PM
    #184
    TundraTravvv
    TundraTravvv New Member
    Travis
    2016 Toyota Tundra TSS
    - 6 in. stage 2 pro comp suspension lift - 35 in. Nitto Trail grappler tires - 20 in. mayhem wheels - 4 RGB rock lights
    How much did this cost? Looks amazing btw.
  5. Sep 11, 2018 at 4:27 PM
    #185
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    24 GMC Sierra At4x AEV
    Can any of you that did the plastic corners show a pic of them? Ordered directly from Toyota too, and going to swap out the chrome for these plastic ones. How do they look unpainted?
  6. Sep 22, 2018 at 4:14 PM
    #186
    Ob1
    Ob1 New Member
    20180922_190109.jpg I just had the chrome deplated off of mine. Delivered them to the painter today. Fingers crossed and hoping for the best.
    Tony v likes this.
  7. Sep 22, 2018 at 4:26 PM
    #187
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    cool deal.. keep us posted. i saved my metal ones just in case so i may do the same thing you are doing.
  8. Sep 22, 2018 at 4:40 PM
    #188
    Ob1
    Ob1 New Member
    Ha ha ha, I may be asking to buy yours before it's all said n done.
    Bob likes this.
  9. Sep 23, 2018 at 6:52 AM
    #189
    TNtundra18
    TNtundra18 New Member
    Charlotte, NC
    2018 Tundra Limited
    For those that swapped your chrome for plastic painted ones, it says you need a liner extension. Is that true and if so, where does it go?
  10. Sep 25, 2018 at 7:09 AM
    #190
    Spitfire
    Spitfire New Member
    Long Island
    2018 Cement Limited Trd off road
    Do you need to take the end caps off to remove surround and grill? Or vice versa to change out end caps? Want to redo front end but money wise might have to do in separate steps spread out a bit
  11. Sep 25, 2018 at 11:43 AM
    #191
    JohnH
    JohnH From PA
    Pennsylvania
    2017 Tundra SR-5 4x4 TRD MGM
    ADS 3.0 with clickers ADS bypasses Deaver U748 springs Magnum steps (with Line-X applied) Powdercoated bumper ends Powdercoated TRD wheels Pro grill Husky X-Act
    I am not sure what the “surround” is.
    Hopefully this will help—I took off the grill and bulge to replace them and I didn’t have to remove anything else. Six months later I took off the bumper to get to the end caps...both are pretty straightforward.
    Spitfire[QUOTED] likes this.
  12. Sep 26, 2018 at 6:13 PM
    #192
    bigzrs01
    bigzrs01 New Member
    Zack
    Charlotte, NC
    2018 Cement CM
    What and where is everyone ordering their oem paint or vinyl wrap from? Any particular sites that are above the rest? As someone who will be replacing their bumper in the near future, I refuse to drop tons of money on this project lol.
  13. Sep 30, 2018 at 4:24 PM
    #193
    Heatonrx
    Heatonrx New Member
    Did you get the two liner seals? I read you might get away with trimming what's there?
  14. Oct 2, 2018 at 8:28 AM
    #194
    snektundra
    snektundra New Member
    Ken
    2016 Tundra SR5 CrewMax
    20" Gear BigBlocks, 34" Falken AT's, 3/2 Level kit, PD Black Emblems
    I have been lurking for a while on this site to see how folks were 'de-chroming' their tundras, I finally decided to
    take a shot at doing this to my 2016 Super White CM. Power coating is bucks where I live (San Jose, Ca area) as
    is having a body shop paint them body color. I have prepped and painted cars before so decided I would take a shot
    and have it redone by a shop if I F'ed it up.
    With several fairly small surfaces needing paint (not painting a hood here) - I started looking to see if there was a decent match for 2016 Super White 040 in a commercially
    available spray can. After testing several different cans of white (I now have a life time supply of white rattlecans in various shades) -
    I came up with Rustoleum Painters touch in # 342251 Gloss White (The # is very important as they have 3 shades of 'gloss white'). I
    picked up mine at walliemart (Home depot stocks another shade in my area). I have used this paint before and it is fairly tough and
    has weathered well.
    Anywho...I sanded the 4 chrome bumper ends with a random orbital and 80 grit, degreased, etch primed, sanded, primed, sanded and painted with 5-6 coats. Similar process for hood bulge and grill surround (I didn't know the center grille section is removable from the
    shroud you want to paint) - but hand sanded instead of machine sanded the chrome on plastic. Finish went on well and dried very glossy.
    End result - color is a 99% match (you have to look at it in the perfect light to see the slight shade difference) on the grill surround and bulge. For some damn reason - I can notice a slight shade difference between the from bumper caps and the factory painted panels below
    the headlights. The rear caps are a near perfect match with the bed sides and tailgate.
    Just thought i'd throw this out there for you Super White 040 DIY'ers
  15. Oct 2, 2018 at 9:12 AM
    #195
    bigzrs01
    bigzrs01 New Member
    Zack
    Charlotte, NC
    2018 Cement CM
    How many cans did you go through? Trying to get an idea of how many I need to get as i plan on doing this as well. Im assuming you removed all parts to sand and paint?
  16. Oct 2, 2018 at 9:44 AM
    #196
    snektundra
    Ken
    Actually - removed the grille and bulge for painting. With grille removed, removed plastic panels under headlights, lower grille support, fog light assemblies, the fender well splash panels (behind fogs) and the plastic shroud cover thats the middle of bumper (reach 3x hidden 10mm nuts on both sides through fog light bumper end cutouts) . I just drop clothed the fender / engine area and behind the bumper ends. This goes pretty fast once you do it 1x.
    For the rear bumper ends - I just popped up the plastic bumper step pad and popped a bolt between bottom of pad and top of bumper to maintain a
    gap so I could get paint up under where pad covers. Remove the 3x plastic pop fasteners on the underside in hitch area first. Once the bumper pad
    is popped up - just tape the lip of the pad well so no paint reached the step pad and paper from there up and below to protect from spray. I choose to do
    it this way after reading what was involved to get the plastic step pad completely off. No regrets here - the rear bumper ends turned out perfect and no paint got on the pad.
    Lee4x2Tundra, Tmoneyl337 and bigzrs01 like this.
  17. Oct 2, 2018 at 10:05 AM
    #197
    bigzrs01
    bigzrs01 New Member
    Zack
    Charlotte, NC
    2018 Cement CM
    Awesome job, looks great. Can’t wait to do mine.
    How many cans did you have to go through for the ends and surround combined?
  18. Oct 2, 2018 at 10:11 AM
    #198
    snektundra
    Ken
    oops sorry - my last answer was half baked - for the bulge, grill surround, front and rear bumper ends with 5 coats all around - I went through
    about 5 cans (these were the promo 25% free type cans). I would say it would have taken about 6 normal sized rattle cans. I used about 4.5 cans
    of the etching metal primer as well. I did not clear this as I was afraid the shade would have changed - I am rethinking not doing this now.
    Again - the color code for the gloss white is what matters here (besides very good prep)
    K
    NewImprovedRon and bigzrs01 like this.
  19. Oct 3, 2018 at 4:12 AM
    #199
    SK_Tundra
    SK_Tundra New Member
    Stockton Ca
    2015 Tundra Mall Rated
    6D17AB2B-D401-4764-9C8D-4437A9B2A3CC.jpg E89507F0-9E76-4350-918B-15D4DAC55A76.jpg
    Got mines wrapped. Cost $200
    Spitfire and bigzrs01 like this.
  20. Oct 7, 2018 at 12:58 PM
    #200
    viha22
    viha22 MAGA
    WA
    2018 Cement Limited Tundra Crewmax TRD 4x4
    Did you have to remove bumper ends to get them wrapped?thanks
    Blueknights75 likes this.
  21. Oct 7, 2018 at 2:15 PM
    #201
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    X2, im in the process but haven’t decided on what i want to do.
  22. Oct 7, 2018 at 5:48 PM
    #202
    Ob1
    Ob1 New Member
    Here's the final product. Deplated the chromed bumper caps and had them painted. Removing chrome at a plating shop was 140 for the bumpers ends front n back. Really don't like the idea of sanding chrome myself or even paying to get it done. Hexavalent chromium is a nasty and dangerous metal, whether on your skin or lungs. Not to mention the fact that primer is not too kin on adhering to chrome, sanded or not. Got a hood bulge and grill shroud which I purchased used, they're OEM and originally MGM in color but rather faded n old. Got one on Facebook Market, and the other on Offerup. Total 200. Painting the bumper caps, bulge, and shroud was $350. Total in parts and labor was about 690.......... Full disclosure, I had to paint everything twice because I refused to wait to have it done right by a proper paint shop. Hence an extra 300 bucks that I didn't mention above which I paid an idiot who did a horrid job that had to be redone by a proper paint shop. Lesson learned, whatever you decide on doing, make sure to stick with professional people in order to prevent any do overs at your expense.
    Henry1jg, Tony v, Spitfire and 2 others like this.
  23. Oct 7, 2018 at 8:13 PM
    #203
    SK_Tundra
    Stockton Ca
    I did not remove the caps
    viha22 likes this.
  24. Oct 7, 2018 at 9:21 PM
    #204
    Ely010606
    SPARKS, NV
    Thanks
    viha22 likes this.
  25. Oct 8, 2018 at 3:27 AM
    #205
    Crunch527
    Iowa
    TRD Supercharger/BAM
    When I did my grill surround and front bumper corners I just bought new plastic front corners and grill surround and Roman had his guy do the paint work. Perfect match!
  26. Oct 8, 2018 at 4:24 AM
    #206
    poheller
    poheller 2018 Platinum
    Scot
    The great state Ohio
    2018 platinum
    I did that a while back. But I live in Ohio! Half way thru winter ended up behind a salt truck. Spinning salt all over the road and my bulge and surround and when I home it looked like I drove thru a sand blaster, so I went with body shop paint and have been good ever since. Avoid salt trucks at all cost. But it does look great.
  27. Oct 8, 2018 at 9:00 AM
    #207
    viha22
    viha22 MAGA
    WA
    C2D64407-24FC-4A48-A552-B453EB1C0FF0.jpg Is this guy unprofessional or is he right
  28. Feb 6, 2019 at 11:25 PM
    #208
    Boxer310
    Boxer310 New Member
    2018 white tundra crewmax sr5
    There is another thread on this ecoological company is working on bumper shellz for tundra they are covers that go right above the chrome Oem the bumpers they are cheaper and painted to match should be ready this month
  29. Jun 21, 2019 at 9:42 PM
    #209
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Did you paint or wrap? If wrap what did you get to match the blue ribbon?
  30. Oct 9, 2019 at 10:26 AM
    #210
    Lee4x2Tundra
    Lee4x2Tundra New Member
    Isaac
    2017 White Tundra TSS
    How is this holding up?
