Cold weather question
Discussion in 'Off-Topic Discussion' started by Bprose, Dec 21, 2018.
  1. Dec 21, 2018 at 4:48 PM
    Bprose
    Bprose [OP] Old member
    VA
    17 Tundra CM TRD
    got a question for you cold weather guys. Going on another snowboarding road trip tomorrow to Utah. Coming from the southern border you can’t find below freezing windshield wiper wash here. Two weeks ago my washer nozzles froze. I should have picked some up while I was there. Oops.
    Wondering if adding rubbing alcohol to the summer blend stuff I gave will lower freeze point.
    Any thoughts?
  2. Dec 21, 2018 at 5:54 PM
    Adriver71x
    Adriver71x New Member
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    I use rain x 20 below in Connecticut
  3. Dec 21, 2018 at 5:57 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Yes that should lower the freezing temp on the fluid. Idk how much you wanna add but I dont think it could do much damage when diluted with washer fluid. I think you're good. Just remember to grab a couple gallons on your trip for future use
  4. Dec 22, 2018 at 5:17 AM
    Bprose
    VA
    17 Tundra CM TRD
    Thanks
  5. Dec 22, 2018 at 5:35 AM
    trainracer
    trainracer New Member
    walmart sells rain x washer fluid booster it lowers the freezing temp by 20 degrees
  6. Dec 22, 2018 at 5:47 AM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    Or cheap vodka works as well
    BestGen and Black Wolf like this.
  7. Dec 22, 2018 at 5:50 AM
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    2018 Silver Tundra TRD Off Road Crewmax
    RC 1.75” Front, 1” Rear, TRD Dual Exhaust, Nitto RGs 275/70/18, TRD Center Caps, Rugged Cover Hard Tonneau, Rhino Liner, LED interior/exterior upgrade
  8. Dec 22, 2018 at 6:20 AM
    Bprose
    VA
    17 Tundra CM TRD
    Thought of Amazon but leaving in an an hour. Cheap vodka will be in the truck but not the washer tank. Only thing I could think of that I have on hand was the isopropyl alcohol.
    Walmart in Yuma, AZ doesn’t have any of the below freezing stuff. We get about a month and a half of winter, which is 70 degree days, 40 at night. Then back to just hot.
    Thanks for the responses
    Black Wolf and Jengel451 like this.
  9. Dec 22, 2018 at 6:25 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    I picked some 0* washer fluid from a local dollar general store in South Texas about 2 days ago.
    Black Wolf likes this.
  10. Dec 22, 2018 at 6:28 AM
    Bprose
    VA
    17 Tundra CM TRD
    I could probably find some here if I looked harder, but leaving in a few. Only gone for a couple days then back to sunny Yuma.
  11. Dec 22, 2018 at 6:57 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Isopropyl alcohol will work, get the highest percentage you can.
  12. Dec 22, 2018 at 7:01 AM
    Casper421
    In the woods
    06 DC
    Most, if not all, gas stations in Utah should have at least 0* wiper fluid.
  13. Dec 22, 2018 at 7:20 AM
    Bprose
    VA
    17 Tundra CM TRD
    I’ll try to remember to grab some while I’m there
  14. Dec 22, 2018 at 7:29 AM
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    I used to work with a hardcore alky who rerouted the washer line to just under his dashboard. With the push of a button he'd dispense vodka right into his big gulp. Genius!
    Bprose[OP] and Black Wolf like this.
