Cold start up noise?
Discussion in '2.5 Gen Tundras (2014-2021)' started by boatzNhoez, Jan 8, 2020.
  1. Jan 8, 2020 at 11:24 AM
    boatzNhoez
    boatzNhoez [OP] Owner / Operator of MS MOTORSPORTS
    Cypress, CA
    2019 Platinum CMSB LT
    Too many hahahaha
    Hey guys I got 2019 platinum I recently bought. When I start up cold and go into drive and give it gas, even a slight amount, I hear like a small but noticeable pop/thud. It almost sounds like a vacuum sucking up a ball and losing suction if that's the most accurate way of describing it. I don't really notice it once the engine is warm and running at normal temps. Anyone else experience this?
  2. Jan 8, 2020 at 11:35 AM
    HidetownRed
    HidetownRed Buffalo Hunter
    Top O Texas
    2020 Sky Silver Limited 4x4
    3/1 285/60/20 RG tint and red toes
    Coming from the front of the truck? I believe it may be the ABS system doing its self check. I experience a similar sound on every takeoff after starting the truck.
  3. Jan 8, 2020 at 11:41 AM
    boatzNhoez
    Cypress, CA
    Too many hahahaha
    yup. front of the truck for sure. same situation. sometimes like a very very dull squeak sound.
  4. Jan 8, 2020 at 11:43 AM
    Jersey Rugger
    Jersey Rugger New Member
    KJ
    Jersey
    2019 SR5 TRD off road CM, cement
    Is that normal? My 19 makes a similar sound, once everytime after starting the truck the first time I move the steering wheel. I thought maybe it's a pressure issue in the power steering. But it is literally heard only once everytime I start moving after a start, so I haven't been worrying about it.
  5. Jan 8, 2020 at 11:54 AM
    HidetownRed
    Top O Texas
    Very normal, considering everything I have read. Mine does it right at 12-15mph.
  6. Feb 13, 2020 at 11:07 AM
    boatzNhoez
    Cypress, CA
    Too many hahahaha
    my friend's truck, a recently purchased SR5 TRD 4x4, does not make this sound...
    is it only on the 19s?
  7. Feb 13, 2020 at 11:12 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    It does the sound on the 2020. It's also the air pump sound that you're hearing. Same thing with my 16. And 05. Completely different truck, but similar DNA.
  8. Feb 13, 2020 at 11:13 AM
    boatzNhoez
    Cypress, CA
    Too many hahahaha
    air pump? the one located in the passenger fenderwell?
  9. Feb 13, 2020 at 11:16 AM
    SprinterAE86
    Ian
    Yup, you'll here it everytime especially if you're parked next to a wall.
  10. Feb 13, 2020 at 11:17 AM
    boatzNhoez
    Cypress, CA
    Too many hahahaha
    What baffles me is that why some trucks make that noise and others don't
  11. Feb 13, 2020 at 11:30 AM
    SprinterAE86
    Ian
    They do make the same noise some might just be faint than others or depending on how open or closed off an area they are.
