Cold Air Intake
Discussion in 'Performance and Tuning' started by mannyc84, Jul 29, 2020.
  1. Jul 29, 2020 at 1:05 PM
    mannyc84
    mannyc84 [OP] New Member
    2020 Black Tundra SR5
    What’s going on guys! New to the forum as I just purchased my first Tundra this past Friday. I’m thinking about replacing the CAI it has with a aftermarket one? Any suggestions!? I’ve been thinking of the aFe Cold Air Intake along with the Throttle Body Spacer. Takes?
  2. Jul 29, 2020 at 1:08 PM
    RobertD
    Robert
    DFW, Texas
    mannyc84[OP] likes this.
  3. Jul 29, 2020 at 1:13 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    299.9k Supercharged 2008
    TB spacer is a complete waste of money. CAI is also a waste of money unless you get a snorkel or just like your truck to be insanely loud. Zero performance gains from either.
  4. Jul 29, 2020 at 1:16 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Just throw in a afe dry filter and the airbox accelerator.
    Other than that, a cai is just for adding some bling to the engine bay.
    Tundyfundy and mannyc84[OP] like this.
  5. Jul 29, 2020 at 1:17 PM
    13igtymer
    13igtymer New Member
    2016 toyota tundra crewmax limited
    save your money. spend it elsewhere. I bought the trd CAI because it was 40% off and it looks cool when i open the hood. I open the hood maybe once every few months to check fluid levels. also depending where you live the TRD is probably your only option due to smog regulations.
  6. Jul 29, 2020 at 1:33 PM
    mannyc84
    Wow. I’m seeing a ton of 50/50. I was hoping to add a little extra kick and to help the MPG. Looks like I have a ton to research. Thanks everyone
  7. Jul 29, 2020 at 1:36 PM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    there's no way to get better MPG in this truck other than not driving it.
  8. Jul 29, 2020 at 1:37 PM
    mannyc84
    Hahahaha! 110% real news!
  9. Jul 29, 2020 at 1:48 PM
    speckmon
    Thornton, CO
    if you want any gains for cheap, grab exhaust from @dirtydeeds
    nags likes this.
  10. Jul 29, 2020 at 1:48 PM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    I upgraded my stock intake with TRD drop-in air filter and airflow accelerator for a few months hoping the mpg will improve but it didn't.
    Now, I have an eye-candy TRD Cold Air Intake to pair with my TRD exhaust, mpg still the same. Love the sound though especially with nannies off.
    Tundyfundy likes this.
  11. Jul 29, 2020 at 2:16 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Stillen intake for the 3rd gen looks good.
    DoMoToyota, steezy and prevent like this.
  12. Jul 30, 2020 at 12:36 PM
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    If you study the factory airbox... you will see it is already an efficient cold air intake system... as it draws air from the wheelwell area outside of the hot engine compartment.
    It also has a baffle incorporated in the tube to cancel out the intake noise.
    "back in the day"... we use to flip the air cleaner lid on a quadrajet 4bbl for the extra noise. I think I was around 16 or 17 at the time... and have since grown to appreciate NOT having that noise.
    The only thing gained from the TRD kit or any aftermarket kit is intake noise... and the perceived impression that you have more power because of it.
  13. Jul 30, 2020 at 1:20 PM
    mannyc84
    @Dragracer_Art awesome! Thanks for the information boss. After popping opener then hood and checking out the air filter system, you’re right. Does draw air from wheel wall
    Dragracer_Art likes this.
  14. Jul 30, 2020 at 2:07 PM
    Dragracer_Art
    Dawsonville, GA
    2020 Crewmax 4x4
    You may gain a little more airflow if you pluck out that white plastic charcoal layer in the airbox lid. I did that the first day home with the truck.
  15. May 30, 2021 at 7:14 PM
    Marco
    Marco New Member
    Aftermarket cold air intake manufacturers want you to believe that the factory intake is substandard because it restricts airflow into your engine. What they fail to tell you is that the throttle body and valves are the biggest restrictions in the engine. You can’t overcome those restrictions by using a larger intake pipe or larger exhaust pipe. You’re still limited by the size of the throttle body and the size of the valves.
    Aftermarket cold air intakes actually reduce performance
    Factory intake systems are already [​IMG]designed to give maximum performance. First, they already take in cold air from outside the engine compartment.
    Rex Kramer likes this.
  16. Jun 14, 2021 at 7:12 AM
    steezy
    steezy New Member
    2021 Tundra TRD Pro
    I've got the Stillen. I don't care what people say - the box is bigger and filter has greater surface area, and the Stillen doesn't take in air from the engine bay, it takes it from the wheel well and from the grill, and all components are made of HDPE so overheating components --> overheating air isn't an issue.
    I live in a part of the country where it's HOT the majority of the year. I bypassed the throttle body coolant and added the Stillen CAI and recorded anywhere from 2 to 8 degree cooler temperatures over intake manifold coils after 15 minutes of driving. It could be the TBCB and/or the CAI - I didn't control for one or the other, but logic forces me to believe that I'm improving intake temps if I'm taking more, cooler air from outside of the engine bay, into it.
  17. Jun 14, 2021 at 7:30 AM
    Elduder
    Elduder New Member
    Guess I missed that memo. I cant speak for the Tundra, since I dont really see a need to dyno it, but heres a dyno from my s2000 showing the opposite of your claim. Red is with a K&N, without a cover on over the filter.
    Im currently running a K&N on the Tundra and havent noticed any downsides other than it didnt make more noise than my DD budget dual, so I cant really hear it.
    dadjazz, joseph_womack and steezy like this.
  18. Jun 14, 2021 at 8:56 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I added the aFe Magnum FLOW Pro DRY S Air Filter to the stock CAI, it works as advertised.
  19. Jun 14, 2021 at 9:34 AM
    SteyrM40A1
    SteyrM40A1 New Member
    Gregg
    2018 Toyota Tundra Crew Max SR5 TRD Sport, Magnetic Grey
    Air flow accelerator mod, charcoal filter delete. LED interior lights.
    I have the stillen intake combined with dirty deeds 10in exhaust. Love it!
    prevent, DoMoToyota and nags like this.
  20. Aug 20, 2021 at 6:09 PM
    dadjazz
    dadjazz New Member
    CO
    05 SCLB Tundra 4x4
    Did you just justify a claim that cold air intakes reduce performance with a meme?
  21. Aug 20, 2021 at 6:20 PM
    AggiePhil
    AggiePhil Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
    Get a stainless snorkel.
