Cold air intake or no?
Discussion in 'Performance and Tuning' started by Travis, Mar 20, 2016.
  1. Mar 20, 2016 at 9:35 AM
    Travis
    Travis [OP] New Member
    Travis
    Fort Benning, GA
    2014 Tundra SR5
    Blacked out badges and bumpers, 3/1 leveling kit, 5" oval nerf bars, carbon fiber tailgate inserts, LED interior lights, 33' tires, rockstar II wheels, tinted windows, rain guards over windows
    I've been contemplating installing a K&N cold air intake in my 2014 SR5 but I keep hearing and seeing negative comments about it. Does anyone here have one in there truck? Pro's? Con's?
  2. Mar 20, 2016 at 10:48 AM
    AMRE2ME2
    AMRE2ME2 New Member
    2016 DC 4x4 Limited TRD
    Your truck already has a CAI. Just do a search about CAI and you can read all you want about it. Just ask yourself why the manufactures of the CAI products won't/don't post up dyno results.
  3. Mar 20, 2016 at 11:09 AM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    This.
    Tundralicious and zcarpenter92 like this.
  4. Mar 20, 2016 at 12:43 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    No
    BestGen likes this.
  5. Mar 20, 2016 at 1:10 PM
    watsonc3
    watsonc3 New Member
    Sumter, SC
    2014 Tundra 1794 Edition 4x4
    6 in Skyjacker Lift 24x12 Rockstar II's LT315/50R24 Nitto Grapplers Gibson Performance Dual Exhaust Fabfours Veangeance Series Front and Rear Custom bumpers Fabfours side steps Fabfours roof rack with 4 pod face plate Fabfours headache bar 10 Rigid Industries 2x2 lights
    I researched the same things, and I can't find any justifiable reason to spend money on any of the aftermarket CAI's. The way the stock one is made, if you put a higher flow filter in the stock box you basically have an aftermarket CAI. I thought about buying that AFE stage 2 one that is $425 but there was another member that posted that it had caused a CEL to come on. Definitely doesn't seem worth it.
    Travis[OP] likes this.
  6. Mar 20, 2016 at 2:23 PM
    tat2ude39
    tat2ude39 MYota
    Robert
    San Tan Valley, AZ
    2021 Tundra SR5 Crewmax ~ ARMY GREEN
    What's the best high flow filter for our stock Tundra intake boxes?
  7. Mar 20, 2016 at 2:53 PM
    Travis
    Travis
    Fort Benning, GA
    2014 Tundra SR5
    Perfect. Thanks for the info, i'll probably just leave it as is then or go with the high flow filter
    watsonc3[QUOTED] likes this.
  8. Mar 20, 2016 at 3:42 PM
    TruckyTruck
    Gary
    Even the filter being changed messes with the truck. The computer will eventually adjust to compensate for the higher flow, but you will lose low end tq unless you use the stock paper filter. The best setup is literally the one that comes with the truck.
  9. Mar 20, 2016 at 4:39 PM
    I you decide to go that route, go for the best filtration, not HP gains, which only occur at high RPMs. S&B has the best filtration #'s per CPM for aftermarket CAI's. As far as loss of low end torque....not much at all at the end of the day. 4.3:1 rear gear + option of "manual" shifting pretty much eliminates any small torque loss at low RPMs.
    Derf77 and TXTundra89 like this.
  10. Apr 12, 2016 at 9:44 PM
    freerider8
    freerider8 Trucks Rule
    Fairview PA
    2014 Tundra, Lift Kit aftermarket wheels and tires. One Badass Toy!!
    Fuel Wheels. Lift Kit. Duel Exhaust.
    I just installed a K&N filter on my truck. I have always used K&N filters and like the long life they provide along with more air flow. I have thought about the CAI as well but cannot justify the cost over the benefits. Plus I am sure the engineers at Toyota have put together a package for these trucks that works well on it's own. Of course they have emission standards they have to comply with so there's that but I am sure they do everything they can so the trucks run well. It all comes down to personal preference after that.
    Black Wolf likes this.
  11. Apr 24, 2016 at 8:14 AM
    CBums
    CBums New Member
    2015 Tundra TRD 4x4 Crew Max
    None, as of now.
    I'm probably :deadhorse: on this but, doesn't a CAI benefit better with other aftermarket parts? ie; exhaust, chip, etc. ... Usually when a CAI is installed on any vehicle by itself its not much of a gain. Getting 5-10hp seems normal if you don't have any other bolt on mods. Now I haven't messed with mods on a vehicle in quite some time and I have a feeling I will be getting back into it with my truck and I would love to help put this case to rest. Hopefully I will have a more justifiable outcome in the near future. Time to do some research boys and girls! :headbang:
  12. Apr 24, 2016 at 8:32 AM
    TruckyTruck
    Gary
    Yeah if I was going to buy a different one, it would be the s&b or the trd CAI. Probably the s&b with a dry filter.
  13. Apr 24, 2016 at 5:21 PM
    Agree^^^ but go with wet not dry. IMHO
  14. Apr 24, 2016 at 5:30 PM
  15. Apr 24, 2016 at 5:39 PM
    No man like things too dry.. (Sean... post some pics of your truck with the STT's. Has to look very cool......!)
  16. Apr 25, 2016 at 6:20 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    I made my own intake and it was actually quite simple. I bought a 3" hole saw and cut a hole in the air box next to the factory tube that goes into the fender and I also cut a hole into the fender wall. I bought a rubber hose from a plumbing store and sealed it into the air box connecting through the new cut hole in the fender wall. Just make sure to remount your ground wire and spray paint the metal where you just cut to prevent rust. I'm also running an AFE dry filter.
    Miller29 likes this.
  17. Apr 26, 2016 at 12:47 PM
    SNOWBIRD
    SNOWBIRD New Member
    rodney
    2013 trd limited
    minimal gains but that sound... its cool to be loud! i like my tundra loud!
    2 mpg better with the s&b and when i put the pedal down it sounds mean as fuck!!!!!!!!!!!!!!!!
    https://youtu.be/MeP6K_vzDxU
  18. Apr 26, 2016 at 2:19 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    I have mixed opinions about cais... yes a stock intake grabs "cold " air form inside the fender. A cai grabs the same air from inside the fender or is supposed to based on shroud design. What I will say is, cais use a smoother, alot of times larger tube increasing air velocity. Yes, with every aftermarket part, there's always a possibility of side effects. The occasional c/e light will piss some people off. It irritates me a little but I get over it because how the intake helps me. And i can clear the code with my fingers using my ultra gauge.
    What the cai did for me was give me slightly better mpg. Like 1... but what it really did was help my throttle response. I drive stock trucks just like mine every day, mine rips compared to theirs....
    Trd made a cai, if it were a bad idea why would they spend money on r&d for one?
    Derf77, KUD, TXTundra89 and 1 other person like this.
  19. May 14, 2020 at 5:23 PM
    Tundralicious
    Tundralicious New Member
    Toytoy
    2020 Tundra TRD Sport Premium
    Stock for now
    Thanks for your video. I'm getting one just for the mean sound! I've only had positive outcomes from CAI so I don't believe many people on this forum being anti-cai. With a V8 5.7 32 valves, I can only see some fun coming out of this!
    Cheers mate!
  20. May 14, 2020 at 5:25 PM
    Waste of money.
    Rex Kramer likes this.
  21. May 14, 2020 at 5:30 PM
    Tundralicious
    Toytoy
    Stock for now
    I rather be optimistic about the situation and see it as a way to get the most potential out of the engine. That's like saying exhausts are a waste of money. It might not be your cup of tea and I respect that, but what you're saying is not true. It makes the drive more fun.
  22. May 14, 2020 at 5:51 PM
    This^^^ I got a great deal on an aFe cai. $150. Put it on my 07. Sounded kuul. Nothing else. Been there done that. Expensive thrill sound but not much else...zero fun factor. A supercharged 5.7 is a fun factor.
    Rex Kramer and Tundralicious like this.
  23. May 14, 2020 at 5:56 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Agree here there is a mighty car mods episode that dynos an S2000 with stock and different intakes and you actually lose horsepower and they tried different variations including sticking it out of the car. My car has it and besides drowning in the rain, it sounds pretty cool under load... other than that, that's it.
    Tundralicious and Black Wolf like this.
  24. May 14, 2020 at 5:59 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    TRD airflow accelerator, Stock air box mod
  25. May 14, 2020 at 6:03 PM
    and....to nip this in the bud.....throttle body spacers make a great paper weight. I take that back. Aluminum is light. Not even good for a paper weight.
  26. May 14, 2020 at 6:05 PM
    Pitbull410
    Pitbull410 New Member
    2020 TRDPro CM MGM, 2018 LC200 MGM
    A lot of opinions in here and no actual proof of anything
    Tundralicious likes this.
  27. May 14, 2020 at 6:06 PM
    RayMcGee
    RayMcGee New Member
    2016 Tundra
    I did the TRD airflow accelerator and AFE filter and noticed a difference. I recently switched it out with the TRD intake and difference is really noticeable.
  28. May 14, 2020 at 6:08 PM
    blackdemon_tt
    Fact: If the stealership installs the TRD CAI they do an ECU flash, which can unlock some hp, so is the CAI really adding anything or is it the flash???
  29. May 14, 2020 at 6:09 PM
    It's a forum. Many posts here are anecdotal from personal experiences from our members. What proof are you looking for? From who?
  30. May 14, 2020 at 6:11 PM
    That's a good combo. I'm a K&N drop in fan but going with drop in aFe air filter when it's time.
