Coincidence? Dash lights after windshield replacement
Discussion in '2.5 Gen Tundras (2014-2021)' started by Brian0414, Nov 6, 2018.
  1. Nov 6, 2018 at 6:18 PM
    Brian0414
    Brian0414 [OP] Doomsday
    Tucson, AZ
    2017 Tundra Limited 4x4
    - Winjet Black/Smoke Fiber Optic LED Tail Lights Bilstein 5100
    I just had my windshield replaced. The company came to my work and replaced it very quickly. As Im leaving work I turn on the ignition and notice all these lights on. My seat belt light will not turn off even though I am buckled in. The air bag and traction control will not turn off either. Also I am unable to lock my doors with my fob!!! WTF. This cant be a coincidence right? Did they break a sensor somewhere? Do I need to reset something? Im pissed!!! Everything was fine when I got to work. WTF did they do? Any ideas?
    dcsleeper408 likes this.
  2. Nov 6, 2018 at 6:26 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Start with a system reboot: simply disconnecting your battery ground for 3 minutes and reconnecting it.
    NewImprovedRon, Trd307 and OR18TRD like this.
  3. Nov 6, 2018 at 6:41 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    That sucks brother, hope you get it figured out. These trucks have weird electrical systems.
  4. Nov 6, 2018 at 6:49 PM
    Brian0414
    Tucson, AZ
    No luck
    OR18TRD likes this.
  5. Nov 6, 2018 at 6:55 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    I had the same thing happen to my 2014 after I installed an aftermarket stereo. The stupid stereo worked but a couple of the dash lights were lit. I ended up taking it to the dealer. 550 bucks fixed it..
  6. Nov 6, 2018 at 6:58 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Wtf
    Brian, you better get these pics over to that glass company asap so they don't hang that kind of bill on your head
    OR18TRD likes this.
  7. Nov 6, 2018 at 7:01 PM
    Brian0414
    Tucson, AZ
    WTF!!!!! HELL NO!! Im calling first thing in the morning
  8. Nov 6, 2018 at 7:04 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    correct me if I'm wrong, but the only electrical wiring that's close to the windshield should be in the area of the mirror..
    831Tun likes this.
  9. Nov 6, 2018 at 7:06 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Maybe side curtain air bag?
    joonbug and jeremyd[QUOTED] like this.
  10. Nov 6, 2018 at 7:08 PM
    Pudge
    CT
    Breakage sensor?
    Brian0414[OP] likes this.
  11. Nov 6, 2018 at 7:09 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    The repair dude definitely had to take off that mirror..
  12. Nov 6, 2018 at 7:19 PM
    Brian0414
    Tucson, AZ
    Is this for certain? I have cameras on my truck at work. Ill see exactly what they did.
    OR18TRD likes this.
  13. Nov 6, 2018 at 7:22 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Curious. Keep us updated.
    Did you check the mirror wiring just in case?
    Try the hard rest to find out?
  14. Nov 6, 2018 at 7:37 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Do you have a Toyota or aftermarket alarm system or starter installed?
  15. Nov 6, 2018 at 7:38 PM
    Brian0414
    Tucson, AZ
    Toyota Factory
  16. Nov 6, 2018 at 7:39 PM
    Brian0414
    Tucson, AZ
    Ill do that now
  17. Nov 6, 2018 at 7:44 PM
    Just call them. Probably pinched a wire.
    MotoTundra and jeremyd like this.
  18. Nov 7, 2018 at 4:03 AM
    Elevatormatt
    Elevatormatt New Member
    19 cement crewmax
    Do you have the heated windshield, if so they probably had do some wiring.
    G10dra and NewImprovedRon like this.
  19. Nov 7, 2018 at 6:01 AM
    WrigglingWilly
    WrigglingWilly Well used Member
    2018 Tundra 4x4 5.7 8.1bed
    LineX
    Next question, Are we sure this truck is not a Ford? This IS normal Ford behavior.
    panicman likes this.
  20. Nov 7, 2018 at 6:11 AM
    ed3trd
    ed3trd New Member
    2017 Silver Crewmax 4x4 Off Road
    There are different windshields for the truck,make sure if you have the one with the 2 leads that they are plugged in.they are located by the upper fire wall.
    Good luck!
  21. Nov 7, 2018 at 6:17 AM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    When I acquired about a windshield the woman asked what "accessories" were on it, I told her it had the wiper heater and she replied with "good, most people don't know that or fail to tell us and we order the wrong windshield".
  22. Nov 7, 2018 at 8:24 AM
    Brian0414
    Tucson, AZ
    Update... Called the company. They are sending out a technician to check it out.
    Moon Puppy, Pudge and NewImprovedRon like this.
  23. Nov 8, 2018 at 10:44 AM
    Brian0414
    Tucson, AZ
    No luck. They told me to take it to the dealership and if it turns out its something they did they will pay for it.
  24. Nov 8, 2018 at 10:49 AM
    stripperclip
    stripperclip New Member
    COS
    2016 White Tundra DC SR5 TRD
    Wow that sucks....
  25. Nov 8, 2018 at 10:54 AM
    WrigglingWilly
    LineX
    You have a lovely truck, that thing is super fixable. Have you had many new vehicles? Did you buy this one new?
  26. Nov 8, 2018 at 11:10 AM
    stripperclip
    COS
    Guy I work with had weird lights and indicators on when mice ate his wiring harness.
  27. Nov 8, 2018 at 12:51 PM
    G10dra
    G10dra Not a New Member
    One of the guys in the other forum said "If you have the heated mirrors than your windshield is heated also. Just a strip that runs under the wiper blades to melt ice." So there is a possibility they didn't attach it and now MAYBE touching each other shorting out causing a Christmas tree lighting on your dash.
    jeremyd and Brian0414[OP] like this.
  28. Nov 8, 2018 at 12:59 PM
    Brian0414
    Tucson, AZ
    I do have heated mirrors. That might be the problem! Thank you for that.
  29. Nov 8, 2018 at 1:01 PM
    Rica25
    Ricardo
    Tulare
    Do you have a camera on the front windshield that sits near the rear view mirror?
  30. Nov 8, 2018 at 1:01 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Good luck...please keep us posted what the out come is.:popcorn::popcorn:
