Coilovers hitting steering arm - Toytec / Radflo 2.5 *solved*
Discussion in 'Suspension' started by BlueBottle, Dec 10, 2017.
  1. Dec 12, 2017 at 6:24 PM
    Tundra4us
    Tundra4us New Member
    "D"
    Try this little experiment, swap sides of tie rod. That kink going in the other direction may give a little more clearance.
    dcsleeper408 likes this.
  2. Dec 12, 2017 at 7:13 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I've heard of doing that.
  3. Dec 13, 2017 at 2:26 PM
    BlueBottle
    BlueBottle [OP] not a PRO
    '16 Platinum 4x4
    See fine print
    I haven’t seen @ToyTec Lifts in here. I’m sure they install lots of these. Wondering if they have any insight or info.
  4. Dec 13, 2017 at 2:29 PM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    David
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    The new ZONE UCA is great for this application, it uses a Moog greasable ball joint. Josh at SV Customs has awesome pricing for our forum guys.
    aperezsh, froggy78, Vizsla and 2 others like this.
  5. Dec 13, 2017 at 2:38 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Thanks David. Do you happen to know how much more extra caster these give compared to the oem units
  6. Dec 13, 2017 at 2:44 PM
    Vizsla
    Vizsla 2 = 2.5
    I have Zone uppers, and have had them at 4”(don’t ask), 3”, and 2.5”. Caster has run around 4.5 to 5.5 degrees, but they only add caster, no camber. So you are maxing your cams for camber out no different than stock, with probably decent numbers, albeit with more caster. I am slowly trying different arms, and Total Chaos was the best for me, mark cams, lift 3”, set cams on marks, almost perfect.
  7. Dec 13, 2017 at 2:48 PM
    Coachbuilder1
    David
    Salt Lake City UT
    Zero, they are based off the factory UCAs but position the ball joint up to decrease the angle.
  8. Dec 13, 2017 at 2:48 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I have the total chaos UCAs and was able to achieve ~4 deg caster angle. Rides great. No coilover interference.
    The SPC Light Racing UCAs are very adjustable if you want that flexibility to ensure the correct alignment.
    BlueBottle[OP] and Coachbuilder1 like this.
  9. Dec 13, 2017 at 2:54 PM
    Coachbuilder1
    David
    Salt Lake City UT
    The Zones shouldn't be adding any extra caster but 4.5-5.5 is high compared to what they normally align at. We normally see mid 3 degrees. The TC are really nice:headbang:
    BlueBottle[OP] likes this.
  10. Dec 13, 2017 at 2:55 PM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    Sorry for the delay in responses So the issue that is clear here is you have way to much posititve caster going on there... I would highly recommend getting that dialed back in accordingly.
    Just Like Csuviper stated, the SPC uppers are going to be the best bet to insure proper Caster spec the first time without any issues.
    BlueBottle[OP] and T-Rex266 like this.
  11. Dec 13, 2017 at 2:55 PM
    Vizsla
    Vizsla 2 = 2.5
    Zone and my directions state otherwise, just want to know cause all I have seen in alignments is caster. Mine added 1.5 degrees of caster.
  12. Dec 13, 2017 at 3:37 PM
    Coachbuilder1
    David
    Salt Lake City UT
    Thanks for the correction and post, When they released this design we were told the only difference was the angle of the ball joint. Def not the case.
    Vizsla[QUOTED] likes this.
  13. Dec 13, 2017 at 4:09 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Nice. So it’s a nice medium between stock and Camburg/TC.
    Anyone know how much JbA uca adds? Another one I would consider.
  14. Dec 13, 2017 at 5:33 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I don't know how much caster the TC arms offer but I've been told by Keith, @dirtydeeds , that Camburg adds the most caster. That said, a lot of people are successfully running Camburg arms.
  15. Dec 13, 2017 at 5:40 PM
    Vizsla
    Vizsla 2 = 2.5
    At 3” with Total Chaos I had 3.2 driver, 3.6 passenger degrees caster. I talked with the JBA guy and he had similar numbers.
  16. Dec 13, 2017 at 5:46 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Those sound like good numbers.
  17. Dec 13, 2017 at 5:52 PM
    Vizsla
    Vizsla 2 = 2.5
    I think they are, and keep in mind with the TC, the alignment cams were basically in the stock position, so you have lots of room to run more or less caster, and have greater flexibility of wheelwell placement.
  18. Dec 13, 2017 at 6:05 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Sure, I just bought Icon's with the delta joint and now you tell me? lol
    Vizsla[QUOTED] and dcsleeper408 like this.
  19. Dec 13, 2017 at 6:14 PM
    #49
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Great info! This has turned into a UCA thread which is great because there is not much info out there regarding UCa’s Wish there was though.
    dcsleeper408 and Vizsla[QUOTED] like this.
  20. Dec 13, 2017 at 6:14 PM
    #50
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Nothing wrong w the delta joints especially since your getting the numbers and ride you are happy with.
    dcsleeper408 and Vizsla like this.
  21. Dec 13, 2017 at 6:19 PM
    #51
    TheBeast The Beach
    with my TC I'm at 2.9 driver, 3.2 passenger from my last alignment iirc
  22. Dec 13, 2017 at 6:25 PM
    #52
    Vizsla
    Vizsla 2 = 2.5
    Basically, where I am at, on 2 out of 3 sets of arms. My Zones are aligned fine, but my driver side cams are maxed doing so. This means my camber defines my caster setting, that’s it your stuck with that number. The passenger side on our trucks follows up accordingly, without being completely maxed. It seems like most use this approach from first hand experience. This is why I think Total Chaos is better, I personally don’t consider Camburg because I don’t want to chop, and I have to run mudflaps. Now have TC make an arm with oe style bushings, and my tundra life is complete. Don’t be afraid of uniballs, I was, it was just a ball joint I maintained with my garden hose instead of grease gun.
  23. Dec 13, 2017 at 6:40 PM
    #53
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Wow! :amen:
  24. Dec 15, 2017 at 4:55 PM
    #54
    BlueBottle
    '16 Platinum 4x4
    See fine print
    *update*
    Re-installed my oem uca and got a new alignment. Caster is 2.8* and the shocks clear the tie rods by a good fat finger now. Not sure what really caused the issue if it was the camburg arms or the alignment but either way I’m good for now.
    4C8DA57F-8963-4360-8FA9-ACF76F8D7024.jpg 2B76FDB4-D8B9-4FA0-883D-AC6568C0C686.jpg
    Newm, PermaFrostTRD, TheBeast and 4 others like this.
  25. Dec 15, 2017 at 5:05 PM
    #55
    nowayout
    nowayout New Member
    NY
    15 Dbl
    So in the end there really is no need for new UCA's. Thanks for working this out @BlueBottle
  26. Dec 15, 2017 at 5:08 PM
    #56
    BlueBottle
    '16 Platinum 4x4
    See fine print
    It still ideal to go aftermarket UCA. The stock ball joints won’t last that long because of the angle it’s at with a lift. I just don’t have time to deal w this at the moment.
  27. Dec 15, 2017 at 5:11 PM
    #57
    nowayout
    nowayout New Member
    NY
    15 Dbl
    Are you still at 3in up front? If you're down to 2.5 I think you will see that the stock UCA's will hold up just fine. Ive had 2 lifted 4runners in the past with 2.5 inch up front without aftermarket UCA's that had no issues in the long run.
  28. Dec 15, 2017 at 5:32 PM
    #58
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I’m not sure how high I am anymore. I’m somewhere between 2.5-3”
    froggy78 likes this.
  29. Dec 15, 2017 at 5:33 PM
    #59
    TheBeast The Beach
    great it worked out !
    froggy78 and BlueBottle[OP] like this.
  30. Dec 23, 2017 at 10:50 AM
    #60
    Ps3udonymous
    Ps3udonymous Who is the smart ass that changed the title?
    I LOL'ed
    HBdirtbag, Newm, 831Tun and 2 others like this.
