Coilover failed...help
Discussion in 'Suspension' started by TXMiamiFan, Mar 11, 2017.
  1. Mar 16, 2017 at 9:04 PM
    #151
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Reminds me of Materials class
    Wvmoonshiner and ColoradoTJ like this.
  2. Mar 16, 2017 at 9:13 PM
    #152
    Metallurgist? I know you work on big rigs, and have a metric assload of experience. Just wondering if that was one of your areas of expertise.
  3. Mar 16, 2017 at 11:49 PM
    #153
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Not a metallurgist, but you're right, I am a Commercial Transport Technician. The failure analysis I've learned was mostly during training courses for Eaton transmissions (10, 13, 15, and 18spd) and differentials, which is my specialty in the trade, but I have read through some material from Caterpillar on the same subject, since I find it facinating. That said, I don't claim to be an expert on the subject, I only have a fairly basic understanding of it.
    The case here with the coil spring is very much like what your customer wants you to find when they have a broken gear tooth in their transmission that is under warranty. If you have an "inclusion" in the metal, and beach marks out from it, it is considered a manufacturing defect, and parts and labour are covered. If the whole fracture is rough and granular, then it us considered a "shock load" failure, and not warrantable. It isn't terribly difficult to shock load a drivetrain when you have 1850 - 2050 ft-lbs of flywheel torque and grossing out at 140,000lbs with a set of trains. (Can I tow that with my Tundra??):D A spinning wheel suddenly grabbing traction is one easy way.
