*** COILOVER DROP AT TOYTEC ***
Discussion in 'Suspension' started by Toytec Lifts, Aug 29, 2017.
  1. Nov 5, 2017 at 7:14 AM
    #151
    JerseyTundra1260
    JerseyTundra1260 08 Silver streaking!!!!!
    Marc
    New Jersey
    08 Silver Tundra DC Limited 4x4
    Too many to list.....
    Beat you.......
  2. Nov 5, 2017 at 7:15 AM
    #152
    Mr. Rogers
    Mr. Rogers New Member
    Forsyth, Ga.
    2017 MGM Tundra TRD 4x4 SR5
    Toytec/Eibach 3"coilovers, JBA uca's, 1" rear blocks with bilstein 5100's, Nitto RG's 295/70/18
    haha! nice bro. did you do UCA's?
  3. Nov 5, 2017 at 7:19 AM
    #153
    JerseyTundra1260
    Marc
    New Jersey
    Yes SPC uppers
  4. Nov 5, 2017 at 7:32 AM
    #154
    JerseyTundra1260
    Marc
    New Jersey
    Honestly I had to go get to alignments. Because Toyota screwed up the first one. But something still just doesn't feel right I don't know what it is. I can feel vibration in the steering wheel. And my driver front wheel is more tucked under the fender flare than my passenger side which is not right. As for the ride definitely seems a little stiffer then my 5100's felt. I don't know maybe if I go back and try and have things adjusted one more time it'll get a little better. I just don't want to wear my tires out. The guy at the alignment shop said I should be okay. But I don't know how if one wheel is more under one Flair than the other that doesn't seem right to me and it bothers me. Honestly right now at this moment I think I like the 5100 ride a little better but that may only be because I'm not fully set up properly. Not saying it's a bad ride though. I'm thinking the beefier rear shackles as well maybe stiffening the ride also.
    aperezsh likes this.
  5. Nov 5, 2017 at 9:50 AM
    #155
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    @JerseyTundra1260 those camber numbers are wacky. Also too much toe in my opinion.
    Check out my numbers from last week. Truck rides perfect. You should easily be able to get these numbers with your setup. Maybe others will chime in on your numbers, but I wouldn't be happy with them. I would tell the tech exactly what you want your numbers to be, "within spec" is not good enough.Alignment.jpg
    aperezsh and 4x4_Angel like this.
  6. Nov 5, 2017 at 10:06 AM
    #156
    JerseyTundra1260
    Marc
    New Jersey
    Will do... Thanks
  7. Nov 6, 2017 at 1:22 PM
    #157
    JerseyTundra1260
    Marc
    New Jersey
    This is my carrier bearing drop kit correct? I am still experiencing vibration and shutter while taking off from a dead stop. Any ideas why? I also still have to go back Friday to try and get my alignment straightened out better. I can feel a vibration steering wheel as well.
  8. Nov 6, 2017 at 1:23 PM
    #158
    gan
    gan New Member
    Rgv Texas
    2021 Black Tundra Pro
    that is the front diff drop kit the carrier bearing is part of the driveshaft
  9. Nov 6, 2017 at 1:24 PM
    #159
    JerseyTundra1260
    Marc
    New Jersey
    If I get under there will it be pretty easy to see if I have it? Maybe that's the issue maybe I do not have it I thought it came with the toytec kit
  10. Nov 6, 2017 at 1:25 PM
    #160
    gan
    gan New Member
    Rgv Texas
    Generally those don't come with the lift kit, I had to purchase mine separately in the past when I did the rear shackles
  11. Nov 6, 2017 at 1:27 PM
    #161
    JerseyTundra1260
    Marc
    New Jersey
    Good to know., I'm actually looking at them on the toytec website right now they're like 13 bucks. Thanks a lot appreciate the info
  12. Nov 6, 2017 at 1:30 PM
    #162
    gan
    gan New Member
    Rgv Texas
    Sure thing gald I could help, they are easy to install and takes away the shudder you have when you start to move.
    JerseyTundra1260 likes this.
  13. Nov 6, 2017 at 1:32 PM
    #163
    Ted4311
    Ted4311 Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    A LOT... NEVER ENDS
    So in my Tacoma I had the same thing after I changed out my U-joints and reinstalled the driveshaft. I had put the carrier bearing upside down.
    so you have one way to mount it right, if you get vibrations then go under your truck, take out the 2 bolts droop your shaft just enough to spin the carrier bearing 180 degrees.
    That was the issue I had, could be the same for you. Just a thought and its easy to test.
  14. Nov 6, 2017 at 1:33 PM
    #164
    JerseyTundra1260
    Marc
    New Jersey
    Great. Thanks
  15. Nov 9, 2017 at 11:48 AM
    #165
    JerseyTundra1260
    Marc
    New Jersey
    Anyone know what to torque the bolts at after I install my carrier bearing spacers?
  16. Nov 10, 2017 at 3:43 PM
    #166
    JerseyTundra1260
    Marc
    New Jersey
    Well my freakin nightmare Tundra alignment story continues.... Here is my latest print out after my third alignment in 2 weeks. Now this shop I just bought A2 comes highly recommended. And he assured me it's a good alignment. Funny thing is the print out sheet I showed him from the last alignment I had done last Saturday after Toyota butchered it said totally different than what the truck was actually showing he said. So he was basically like I don't know where they got those numbers from or whose print out that was. So that's not the end of the story. I proceeded to drive out from the place at a slow speed and the truck starts hopping so much so that my daughters were making that sound as if somebody hits your back as was I. So I called him immediately and told him something is not right so I have to bring it back again Monday. Originally when I put my wheels and tires on they stuck out just a hair past my flares. When I got it back from the alignment shop last Saturday the driver side front was tucked in more than the passenger side front. When I just picked it up tonight he said they took them back under when they did the alignment so they're just about even with the flares maybe a hair under which I don't want. He told me his Tech took it down the highway at 80 miles an hour and it drove good there might have been a slight little vibration. Well whatever the hell they did is not right. I just installed the carrier bearing drive shaft spacers yesterday and it drove light years better than it did coming home tonight. Here are the specs on the three current alignments I just had done from most recent to Toyota alignment . To be continued....... :mad:
  17. Nov 11, 2017 at 5:52 AM
    #167
    OBXTundra
    OBXTundra Member
    Southeast USA
    Sounds like you have 2 unrelated issues.
    The most recent alignment looks better. I still don't like -.4 camber on the left front. I would worry about the alignment being spot on more than the appearance or "eye-balling" which tire looks exposed in reference to the wheel well, there are too many factors that could effect how the alignment "looks" vs. what the numbers actually say.
    As far as the hopping or vibration. Maybe a broken belt on a tire? Maybe bearings going in your front CV axles, maybe these were compromised when the coilovers were installed? Maybe the carrier bearing itself? The bearing drop wouldn't solve the problem of a carrier bearing that has actually failed.
    At this point I don't think any of your issues are related to the coilovers or UCA's.
    Meanwhile. I've got about 300 miles on my Toytec/Eibach coilovers and JBA UCA's now and love them. The ride is great. They really take the edge off the sharp hits and make the front feel plush enough. Daily driving is perfect. Offroad is good, the front end is stable and the coilovers keep the front tires planted through corners. I haven't bottomed them yet, but I also don't push the truck that hard off-road. The fact that I have $1062 total into the front end makes it even better.
  18. Nov 11, 2017 at 7:24 AM
    #168
    JerseyTundra1260
    Marc
    New Jersey
    My tires are brand spanking new. Everything else as well seems to be tight on the truck only has 47000 miles on it. Before I drove it to him it drove fine. Just a little bit of a vibration when you get up to speed at the wheel with a very slight pull to the right. The carrier bearing spacer actually helped with vibration while taking off so that improved before I even got there. It's clearly has to be something they did I would think. I have to bring it back Monday. But I will say I was starting to get used to the ride as well. I actually hit a few speed bumps on a road that's near my work and compared to just the 5100's I had much better rebound . Much smoother transition over it. Once I get this thing figured out I think I'm going to really enjoy the ride more and more as I go. One thing I will say is I love this stance and how the truck looks now :D
  19. Nov 13, 2017 at 4:00 PM
    #169
    JerseyTundra1260
    Marc
    New Jersey
    Well took the truck back to shop today. In true fashion or my luck (take your pick) I pull up to place. The mechanic jumps in to drive it with me in passenger seat. Go down the road and it stops :mad: We drive around some. Drops me off and says drive it. If it starts again bring it back. Go into work late. Pull into parking lot and park. Get out and I smell burning brakes smell. My back drivers side break is hot as hell. Take it back to shop and turns out back caliper is locking up off and on...... Explains the shudder I think. No truck until tomorrow with 2 new rear calipers and break lines. All hopefully working well minus the hit to the wallet :annoyed:
    TheBeast likes this.
  20. Nov 13, 2017 at 4:58 PM
    #170
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    What a nightmare ! Can't imagine all, or any of this is related to the Toytec parts, but maybe the install?... I'm sure the whole thing is bumming you out. At least in the end you will have a sweet suspension!
  21. Nov 13, 2017 at 5:14 PM
    #171
    JerseyTundra1260
    Marc
    New Jersey
    Yes.... I think it's just coincidence. Hope it drives good tomorrow :thumbsup:
  22. Nov 13, 2017 at 7:20 PM
    #172
    TheBeast The Beach
    sometimes you notice certain things because you just had new parts installed. I know I am the same.
  23. Nov 17, 2017 at 5:38 AM
    #173
    Matthewkort
    Matthewkort New Member
    Any 3rd gens running this with the toytec schackle.. curious how it will sit, thanks in advance!
  24. Nov 17, 2017 at 6:45 PM
    #174
    A-A-Ron
    A-A-Ron Done messed up
    Aaron
    Seattle
    2021 Ford F-250 Lariat Diesel
    I will in about a month! :)
    The shackle can be used for 1" or 1.5". From what I've seen on this site 3" coils with 1" shackles will put you around level, 1.5" would be a small rake. I'm going 1.5" to compensate for my canopy.
  25. Nov 25, 2017 at 8:18 PM
    #175
    JerseyTundra1260
    Marc
    New Jersey
    Update after driving few weeks with the Toytec /Eibach coilovers, SPC Uca's and Toytec shackles and Boss extended rear shocks here is my take on them . First off I love the stance. I think it sits at a perfect height. With the Toytec shackles I am sitting with a little rake I believe on the top setting . Second the ride has grown on me. Seems to be a little bit stiffer than my 5100's were. But in a good way. Feels tighter overall as well in the turns. I think the Toytec shackles tighten up the rear over the Flimsy stock shackles. 3rd the eye candy factor :D those pretty silver coilovers compliment my Silver sky quite nicely. And the rear Boss shocks are nice and shiny :thumbsup: Overall I recommend them. For the price you can't go wrong. I am sure after they break in a little more I may even enjoy them better.
    A-A-Ron, TheBeast and T-Rex266 like this.
  26. Nov 26, 2017 at 8:25 AM
    #176
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    A few miles out of alignment isn’t going to do anything to your wear
  27. Nov 26, 2017 at 8:28 AM
    #177
    JerseyTundra1260
    Marc
    New Jersey
    All good now :thumbsup:
  28. Apr 25, 2018 at 10:49 AM
    #178
    pclaunch
    pclaunch New Member
    So is the general consensus on these that they are a good middle ground between 5100s and 6112s? Would it be worth the extra $300 or so to get 6112s for light offroading and mostly street driving?
  29. Oct 2, 2018 at 1:26 PM
    #179
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Looks like 30 foot-pounds.
  30. Oct 5, 2018 at 12:06 PM
    #180
    Halfjap
    Halfjap New Member
    Reno, NV
    2015 White Tundra Crewmax
    Had these Eibach Coilovers for over a year sitting in my garage. With two young kids, I never got a chance to install until now. Man, I wish I didn't wait so long. What a difference. Went from a readylift spacer to these. Ride is so much smoother. Definitely feels more planted. Overall, handles 100% better. Cant wait to test these out on some of the trails. Anybody that is on the fence about getting a coilover for a 3 inch lift, that doesn't break the bank and rides just as good as stock, if not better, I suggest you go with these. Also, for all you DYI's, the install was a breeze. It took me about 3 hours from start to finish by myself. A big thank you to all the info that you forum members posted on tips and tricks for installation. It made it really easy.
