*** COILOVER DROP AT TOYTEC ***
Discussion in 'Suspension' started by Toytec Lifts, Aug 29, 2017.
  1. Aug 29, 2017 at 5:10 PM
    malveman
    malveman New Member
    New jersey
    2022 Limited long bed MGM
    ToyTec what would be excellent affordable shocks for a 2016 crew cab 1794 black shocks. Truck is mostly street driven thanks in advance
    Black Wolf likes this.
  2. Aug 29, 2017 at 5:15 PM
    Be prepared to tell David if you are looking for "leveling out" look...or a true "lift", no lift, your budget..David will ask you anyways.
  3. Aug 29, 2017 at 5:29 PM
    malveman
    malveman New Member
    New jersey
    Thanks Matluth. No lift this tundra is a lease not happy with the ride now if it can ride much better I might buy it at end of lease
  4. Aug 29, 2017 at 5:31 PM
    Stig
    Stig New Member
    I was referring to the OEM spring, not OME. I guess the biggest difference most people will notice is the inch difference in lift?
  5. Aug 29, 2017 at 6:07 PM
    PermaFrostTRD
    Northern NY
    Oh man. So much for not needing to lift my truck.
  6. Aug 31, 2017 at 8:26 AM
    Toytec Lifts
    Toytec Lifts [OP] New Member
    Denver, CO.
    Sorry miss typed it, I did mean to put in OEM, not OME
    Edited original reply.
    The biggest difference is going to be in the overall ride quality, the aftermarket coilover will come with a taller coil spring which will reflect the quality of ride only with travel of suspension.
    Preloading Factory OEM springs will ultimately reflect in loss of travel since you are already pre loading the coil spring X amount.
    -David
    T-Rex266 likes this.
  7. Sep 3, 2017 at 10:51 AM
    HOTDAM
    HOTDAM Feeling Dangerous
    2013 Crewmax 4x4
    @ToyTec Lifts will these settle over time and if so how much settling?
    Toytec Lifts[OP] likes this.
  8. Sep 3, 2017 at 12:26 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    How do these compared to the Boss set?
    Can these be a good match w boss rear shocks?
    These have any more travel than the stock shocks and would UCA's benefit any?
  9. Sep 3, 2017 at 4:27 PM
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2022 Tundra 1794 Supersonic Red
    Nitto Ridgegrapplers 175/60/20
    How are these on the highway VS stock set up? Would I be loosing out on any ride comfort or is it all gravy great upgrade? Thanks. D
  10. Sep 5, 2017 at 6:05 PM
    Quartermeter
    Quartermeter New Member
    James
    Alabama
    2014 SR5 DC WHITE
    FOX 2.0 REARS, OME FRONTS FIRESTONE AIR BAGS RCI SKID PLATE
    @ToyTec Lifts you need to put your SPC UCA's on sale to go with these 3" lift coilovers.. You cant get them aligned w/o them. So It just makes sense.
  11. Sep 5, 2017 at 7:22 PM
    Toytec Lifts
    Denver, CO.
    We have seen them settle right around the 3" mark, it's hard to pin point measurement due to each vehicle being a little bit different.
    What is nice about these is that Eibach engineers amd Toytec engineers paired up tohelped design the boss shocks so these will be a nice comparison with when it comes to valving and zinc coated shock bodies. A main difference would be is that these coilovers are going to be a non adjustable 3" lift as a the boss coilovers are a full adjustable coilover along with a valved specific shock.
    These shocks will help with the body roll along with great on road and off road manners. The shocks do offer a nice comfortable valving system to help keep things nice and stable for you and your truck.
    A different drop is always a good peace of mind to have for only $30, it just helps decrease the angles of your cv axles so you are not pretty maturity wearing them out. Same thing when it comes to your upper control arms, 3" of lift in the front is right around the "grey area" with alignment specs with the factory uppers. It is a good recommendation to get them when installing.
    At this moment in time we are unable to put the SPC uppers on sale, hints why we offer free shipping on them, we have seen however alot of people get into factory spec with the factory uppers just fine.
    Thanks for the love guys!!!
    -David
  12. Sep 7, 2017 at 5:03 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    Anyone running these coilovers yet? Looking for some real world feedback.
    Currently running bilsteins with a leveling spacer, stock rear. Truck sits perfectly level. Spacer looks to be 2" (was on the truck when I bought it).
    I would like to maintain the current stance, thinking adjustable may be the best option, but always considering other routes.
  13. Sep 7, 2017 at 6:12 AM
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    Me too. Look like a great option I just hate going first.
    JerseyTundra1260 likes this.
  14. Sep 7, 2017 at 4:52 PM
    OBXTundra
    OBXTundra Member
    Southeast USA
    Well now that I know I currently have a "3-1" leveling kit on my truck, consisting of a spacer up front and block in the rear, I am taking these a little more seriously. They would be a direct swap for my front, keeping the truck stance the same.
    What sort of actual performance improvements would I be looking at with these compared to my current TRD coilovers with the top mount spacer?
  15. Sep 7, 2017 at 6:01 PM
    Toytec Lifts
    Denver, CO.
    What's nice about these is they are not only going to improve your ride quality over stock, but will give you the full amount of travel with a taller coil spring and a shock designed specifically for that spring giving it the range of travel without compromising your suspesnion components.
    The spacer kit you have is forcing your whole assembly down, pretty much having the truck sitting at full "droop" all the time. There has been alot of problems with those kinds of lifts causing over extention of the factory coilover causing either the shock body and lower stem to separate and blow through the bottom of the body and or having the shock shafts and body separate.
    -David
    757TUNDRA and PermaFrostTRD like this.
  16. Sep 7, 2017 at 6:16 PM
    be77solo
    be77solo New Member
    2017 Silver Crewmax 4x4 5.7L
    KO2's on ENKEI ST6's, BakFlip MX4
    So, any updates, can I install these on my '17???
    Thanks!
  17. Sep 8, 2017 at 3:42 AM
    Quartermeter
    James
    Alabama
    2014 SR5 DC WHITE
    These aren't adjustable unless you have a spring compressor stand. toytec already said for this price they're not going to change the height. You will probably more than likely also need UCA for these.
  18. Sep 8, 2017 at 4:23 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    @ToyTec Lifts thanks for the reply. These will be the route I end up going. I'll PM you with any other questions.
  19. Sep 8, 2017 at 5:13 AM
    #49
    Quartermeter
    James
    Alabama
    2014 SR5 DC WHITE
    What's the load rating on those Springs
  20. Sep 8, 2017 at 7:08 AM
    #50
    Toytec Lifts
    Denver, CO.
    Sounds good buddy!
    These springs are about a 640-660lb spring rating.
    -David
  21. Sep 8, 2017 at 9:18 AM
    #51
    JerseyTundra1260
    JerseyTundra1260 08 Silver streaking!!!!!
    Marc
    New Jersey
    08 Silver Tundra DC Limited 4x4
    Too many to list.....
    If you don't mind me asking what are the stock Toyota Springs rated at?
  22. Sep 8, 2017 at 9:27 AM
    #52
    Toytec Lifts
    Denver, CO.
    If I remember correctly they are a 590 - 600lb spring? Don't quote me on that though, it should be right around there.
    -David
  23. Sep 8, 2017 at 10:39 AM
    #53
    Quartermeter
    James
    Alabama
    2014 SR5 DC WHITE
    What are the OME 613 SPRINGS rated?
  24. Sep 8, 2017 at 11:54 AM
    #54
    Toytec Lifts
    Denver, CO.
    They state the 613 spring to be 740 lb
  25. Sep 8, 2017 at 11:59 AM
    #55
    1BadTundra
    1BadTundra New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    Would you consider promo-ing a set or two of these out here? We could do a full review for you, boosting the sale of these if they are as good as they seem to be... In turn you knock a few bucks off in exchange for said review...
    MistrRoboto likes this.
  26. Sep 8, 2017 at 12:01 PM
    #56
    Toytec Lifts
    Denver, CO.
    At this moment we are unable to do promos of any kind, but we do offer a pretty sweet discount code for all active members :thumbsup:
    https://www.tundras.com/threads/tundras-com-toytec-discount-code.117/
    -David
    zcarpenter92, OBXTundra and T-Rex266 like this.
  27. Sep 14, 2017 at 7:10 AM
    #57
    MistrRoboto
    Virginia Beach, VA
    Who's biting on these first? I'll make the leap and write a thorough review with some incentive ;)
  28. Sep 14, 2017 at 7:15 AM
    #58
    JerseyTundra1260
    Marc
    New Jersey
    Debating myself... Not sure if I go this route or the Boss kit route. This one is definitely more affordable $$$ but will that show in the performance compared to the Boss kit? That old expression you get what you pay for o_O
    OBXTundra likes this.
  29. Sep 14, 2017 at 7:24 AM
    #59
    MistrRoboto
    Virginia Beach, VA
    Yep. It's also .5 inches higher out of the box than BOSS. Kind of worries me as 3in lift is right in that UCA upgrade sweet spot. In my basic brain, 2.5in lift works with stock UCA. So cheaper coil + UCAs ends up being more expensive than a BOSS setup with stock UCAs. All theory of course... As it seems to be debatable when UCA upgrade is needed.
  30. Sep 14, 2017 at 7:54 AM
    #60
    JerseyTundra1260
    Marc
    New Jersey
    Isn't the Boss kit set 3 inches as well upon receiving it? I have read that can go up to 3.5 inches but not sure if it's recommended. Regardless if I get these coilovers or the boss kit I plan on getting the SPC Uca's anyway for one just to play it safe and for two for the adjustability of the alignment. I was just quoted $1699 shipped for the Boss coilover kit, SPC Uca's and Toytec shackles. Not bad
    zcarpenter92 and davezlowkey like this.
