Coilovers hitting steering arm - Toytec / Radflo 2.5 *solved*
Discussion in 'Suspension' started by BlueBottle, Dec 10, 2017.
  1. Dec 10, 2017 at 5:02 PM
    BlueBottle
    BlueBottle [OP] not a PRO
    '16 Platinum 4x4
    See fine print
    dcsleeper408 likes this.
  2. Dec 10, 2017 at 5:04 PM
    Ooooh no bueno...hope it gets solved
    BlueBottle[OP] likes this.
  3. Dec 10, 2017 at 5:16 PM
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    Both sides?
  4. Dec 10, 2017 at 5:30 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Yup
  5. Dec 10, 2017 at 5:31 PM
    Vizsla
    Vizsla ☠️☠️☠️
    Camburg UCAs add a lot of castor, might be the problem?
  6. Dec 10, 2017 at 5:32 PM
    TheBeast The Beach
    alignment done ?
  7. Dec 10, 2017 at 5:38 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I do not have that problem at all. I have Total Chaos UCS. Not sure if the problem is not switching to an after market UCA or something is out of alignment on yours.
  8. Dec 10, 2017 at 5:41 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I have Camburg uca.
  9. Dec 10, 2017 at 5:43 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    If that’s the case then everyone running Camburg uca and 2.5 coilovers will have the same issue.?
  10. Dec 10, 2017 at 5:47 PM
    LML 3500HD
    Holy positive caster Batman.
  11. Dec 10, 2017 at 5:49 PM
    csuviper
    Broomfield, CO
    Wow caster is 7. Thought mine was high at 4-5
    TheBeast and ColoradoTJ like this.
  12. Dec 10, 2017 at 5:53 PM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    I'd say it looks like you need to take some of the caster out, leaning the top of the spindle forward would move the tie rod off of the coilover.
    BlueBottle[OP] and dcsleeper408 like this.
  13. Dec 10, 2017 at 5:53 PM
    LML 3500HD
    No kidding right.
    There in-lies this problem. The knuckle is rotated up...a lot.
  14. Dec 10, 2017 at 6:19 PM
    TheBeast The Beach
    yep..thats a lot of caster. I think I'm at 4 with TC UCAs. I would start first with getting proper alignment.
  15. Dec 10, 2017 at 6:28 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Damn I guess there goes the saying get the most caster you can while maintaining camber/toe. @dcsleeper408 ?
    HBdirtbag, TheBeast and dcsleeper408 like this.
  16. Dec 10, 2017 at 6:38 PM
    T-Rex266 Moderator Staff Member
    Caster is way too high
    TheBeast, dcsleeper408 and ColoradoTJ like this.
  17. Dec 10, 2017 at 7:29 PM
    TheBeast The Beach
    actually just checked my last alignment sheet and it's 3.1 caster. Not sure why the guy let you go with 7 and in the red. :notsure:
  18. Dec 10, 2017 at 7:37 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    A lot of people recommend high caster for better handling.
  19. Dec 10, 2017 at 7:41 PM
    TheBeast The Beach
    I know but I could see 4 or 5 max but 7 seems excessive. :notsure:
  20. Dec 10, 2017 at 8:00 PM
    Vizsla
    Vizsla ☠️☠️☠️
    That is how Camburg arms are, you will not be able to get it down much either, maybe enough not to rub?, hard to say. 3-4 degrees castor is fine.
  21. Dec 10, 2017 at 8:54 PM
    Vizsla
    Vizsla ☠️☠️☠️
    No, they work fine with other 2.5 coilovers. 7 degrees is too much imo.
  22. Dec 10, 2017 at 9:15 PM
    LML 3500HD
    Keep us posted on what you come up with @BlueBottle
    dcsleeper408 and TheBeast like this.
  23. Dec 10, 2017 at 9:15 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Will do. I’ll check clearance w lower caster. Thanks for all the responses.
  24. Dec 10, 2017 at 9:24 PM
    TheBeast The Beach
    alignments can be a PIA...always have hard time finding a good shop that knows what they are doing. Had to take my truck to 3 different shops to get it right...grrr
  25. Dec 11, 2017 at 8:50 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    So here are my numbers maybe you should stick with @BlueBottle
    Mine very slightly wanders right but I am sure that is road crown. On some streets it goes straight for a good while. The truck does chop a bit on tight u turns and lock outs.. We have similar setups- only different is tires and uca
    Now I can’t say that these are ideal numbers to go by. I just can’t tell my actual wear anymore because all the tires are just chunking from the off pavement schenanigans. Also at 4.7 degrees I was grazing my cab mount even with my chop, but that was also with really bad toe and a hair more camber.
    As we all know positive caster is good for our trucks but too much can cause steering rack issues. Everyone’s truck is not all the same.
    You should post the numbers you got from les schwab after A.I maybe someone can help with the current #’s
    I never knew the camburgs yield 7-8. I can see what @Cuzican is saying as far as the top being rotated causing it to touch the tie rods. When I checked out the suspension Saturday I didn’t see any signs of wear. I’m sure the les schwab tech possibly tweaked it worse especially now since you are rubbing cab mount.. at 7 degrees I would think you would be further away.
  26. Dec 12, 2017 at 3:45 PM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    David
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    The Camburgs add 2.5 Degrees of additional caster, just as mentioned, if possible pull your cast down, this will open up clearance between the coilover. The Tundra usually aligns at high 2 degrees with factory UCA so even when adding the camburgs you should be able to pull it down to 5.5 which IMO is still too much for pavement driving but will help.
  27. Dec 12, 2017 at 3:54 PM
    csuviper
    Broomfield, CO
    Here is my alignment sheet:
  28. Dec 12, 2017 at 5:13 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Thanks for the advice. I’m removing the Camburg for now and reinstalling the stock a arms. If I reduce caster I rub my cab mount. I don’t have time to make aftermarket uca work for now. Like you said that’s a lot of caster for pavement. My truck is 99.9% pavement pounder and 0.01% mall crawler so I should be fine until I get my cab mount chop.
    If I wanted to go aftermarket uca without adding a lot of caster but keeping my tires away from the cab mount what would you recommend?
    What uca you running again?
  29. Dec 12, 2017 at 5:51 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Reducing caster will move the top of the wheel forward and should, in my mind, help keep it from rubbing the cab mount. I had 6* of caster and it drove well and didn't hit the tie rod or cab mount after the chop. It was close to the C/O so when I switched to @Coachbuilder1 tie rods I talked with Dave before buying . They're bigger and straight but He told at 2-3* caster they wouldn't hit and they don't. The alignment shop should be able to reduce your caster to 4-5*.
    dcsleeper408 and Coachbuilder1 like this.
  30. Dec 12, 2017 at 5:53 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Well shit something’s wrong w my truck then....
