Coil suspension pics
Discussion in '3rd Gen Tundras (2022+)' started by frichco228, Mar 11, 2021.
  1. Mar 11, 2021 at 11:31 AM
    frichco228
    frichco228 [OP] Valued Member
    2016 Crewmax 4WD, TRD Offroad
  2. Mar 11, 2021 at 11:32 AM
    frichco228
  3. Mar 11, 2021 at 11:38 AM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    They had to go to coil springs in the rear. Pretty excited about this. No more rear end ass jiggling.
  4. Mar 11, 2021 at 11:41 AM
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    Very nice, should ride like a dream. Now just put back in a 5.7 w/ forced induction.
    note the snubber inside the coil.
    I have just added these to my leaf spring setup for sway / roll and increased capacity for load.
    Tundra_361 likes this.
  5. Mar 11, 2021 at 11:43 AM
    Looks like the fuel tank is on the right side and muffler towards the left side?
  6. Mar 11, 2021 at 11:48 AM
    Tundra_361
    Victor
    2019 Black 1794 4x4
    Agree, they should still have the 5.7 as an option.
    specter208 likes this.
  7. Mar 11, 2021 at 12:09 PM
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    I heard rumors of this wayyyy back, cool to see it might be a thing.
    I think I see the little poke of a rear cab spoiler up there too.
    Tundra_361 and Mountun Goat like this.
  8. Mar 11, 2021 at 12:24 PM
    typerlegend
    typerlegend Will work for Mods
    Will
    SoCal, North Orange County
    2020 Super White Tundra SR5 TRD Sport
    Kicker sound system. Kings 2.5 Adjustables Total Chaos UCA Total Chaos 3/4' Rear Shackles 17' Methods 703s KO2 35/12.5/17 Baja Design Amber Squadron Sport Fogs
  9. Mar 11, 2021 at 12:28 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    There’s no way that’s a 5.5 box crew cab. Has to be a 6.5
  10. Mar 11, 2021 at 12:47 PM
    Nowhereman
    Al
    Monterey Bay area
    Can't wait to see the coil suspension swap kit for aftermarket.
  11. Mar 11, 2021 at 1:05 PM
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    Doesn’t look quite big enough to be a crewmax though. Maybe they’re gonna do what Chevy and dodge are with that almost full size back door and then the actual full size option.
  12. Mar 11, 2021 at 3:02 PM
    Cpl_Punishment
    Cpl_Punishment Young men never die.
    Rosy
    2020 MGM SR5 CM 4X4
    Doesn't Toyota already have that with the DC?
    specter208 and snivilous like this.
  13. Mar 11, 2021 at 3:22 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Did a little research on the pros/cons of coil springs vs leaf springs. Looks like Toyota is addressing Tundra low payload ratings while maintaining a smooth ride for the urban cowboy. This from the Dodge Forum:
    Leaf Springs: Pros and Cons
    The upside to the leaf springs is that they are very strong, being comprised of a series of thick metal strips – or leafs – strapped together and fastened to the underside of the truck...
    When (engineers) needed a stronger spring, they could simply add another leaf or two to the assembly, improving the strength of the suspension without adding significantly to the cost of the setup. Also, the basic design of a multi-leaf spring allows for some measure of variable rate dampening, as more force applied to the leaf springs leads to more friction between the strips of metal and that leads to increased spring resistance. Of course, that stacked-up metal is also strong and durable, with each layer essentially supporting the next...
    The other key upside to the leaf setup is that it has fewer parts than a coil setup, so whether you are repairing or modifying, leaf springs cost less as a system than coils...
    The biggest downside to the leaf setup is that it offers limited tuning capabilities. This is old school technology and there is only so much that today’s engineers can do to make a load-rated leaf spring setup ride smoother. This is why many older trucks offer a rough ride to those seated in the back, as the rear leaf setup doesn’t handle bumps as evenly as the front suspension setup with a coil spring and damper.
    Coil Springs: Pros and Cons
    Since a multi-link coil setup uses a variety of different components, the system has a higher cost than the leaf setup, so a truck with rear coils is generally going to cost more than one with a rear leaf setup. Also, since the coil spring only handles the weight of the vehicle and not the axle location, some coil setups begin to wobble a bit in some situations...
    The biggest advantage is that with the various components of the coil setup, engineers can tune the suspension to offer a better mix of functionality and ride quality. By making adjustments elsewhere in the suspension, engineers can increase the load-carrying abilities without causing a rock-hard ride and along those same lines, the handling of the truck can be improved without killing the working abilities...
    Finally, since the coil spring offers a much greater range of movement than a leaf spring, (the truck) has greater wheel travel when off-roading, so the coil spring is better on-road, off-road and when carrying a load, but it costs a bit more.
    https://dodgeforum.com/articles/ram...The Ram 1500 is the,all use rear leaf springs.
  14. Mar 11, 2021 at 3:46 PM
    JohnLakeman
    Now we know what those shields low on the bottom of test mules were hiding, and it wasn't a hybrid battery. :D
    The shields in front of the wheels were hiding those bigass track bars that tie the rear axle to the frame on each side. They look pretty low to me. I believe I would have tried to locate them higher for more ground clearance. I only see one single transverse bar tying the axle to the frame laterally. Interesting scoop @frichco228.
  15. Mar 11, 2021 at 3:53 PM
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    Not exactly, the DC is a weird half door with the handle up high. Dodge and Chevy copied their longer cabs as far as design, and just made them a little shorter.
  16. Mar 11, 2021 at 4:11 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Can’t really mount them higher on a factory vehicle. The higher the frame mount the more front to back play the axle has when articulating. Causing more stress on the driveline and panhard bar. FYI.
  17. Mar 11, 2021 at 4:14 PM
    NWPirate
    NWPirate Tesla kool-aid connoisseur
    Zach
    WA
    2017 SR5 TRD CM 2004 TRD Snow Goat
    Trd.jon says Crewmax with the 6.5 so it's gotta be true!
  18. Mar 11, 2021 at 4:15 PM
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    Maybe the camo is messing with me, but the cab just doesn’t look long enough to be a crewmax :monocle:
  19. Mar 11, 2021 at 4:17 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I bet it’s legit crew cab..
    I hope the conspiracy theories drive you insane :anonymous:
  20. Mar 11, 2021 at 4:19 PM
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    I already can’t sleep, this won’t help!
    :tinfoilhat:
  21. Mar 11, 2021 at 4:19 PM
    JohnLakeman
    At first, I thought it was a DC, but I think it's the window cutout in the cover that misleads. Look at the distance from the front door rear edge to back of cab...it's nearly the same like a crewmax. Also, you can see the standard door handle bulges in the cover. DC has nearly flush handles.
    Mountun Goat likes this.
  22. Mar 11, 2021 at 4:19 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Hahahah get the tinfoil!!!
  23. Mar 11, 2021 at 4:21 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    A DC without the fugly back door would be great. I don’t mind the DC cab configuration but damn that door leaves a lot of aesthetics on the table. :crapstorm:
    Cpl_Punishment and NWPirate like this.
  24. Mar 11, 2021 at 4:21 PM
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    I really don’t see them having the handles high anymore like the DC now, so I’m tossing out the door handle argument :D
  25. Mar 11, 2021 at 4:21 PM
    NWPirate
    Zach
    WA
    Agree, looks a little shy
  26. Mar 11, 2021 at 4:21 PM
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    Way ahead of you man :rofl:
    Mountun Goat[QUOTED] likes this.
  27. Mar 11, 2021 at 4:21 PM
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    Can confirm. I’m sure they’ll drop that with the redesign!
  28. Mar 11, 2021 at 4:34 PM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    If driver is not a midget, you can see how much space is behind him, that is a true crewmax imho
    JohnLakeman likes this.
  29. Mar 11, 2021 at 4:47 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    299.9k Supercharged 2008
    That's how most linked suspensions are, proper link geometry is much more complicated than any leaf spring setup. Trying to optimize link separation, triangulation, anti squat, roll axis, etc. doesn't leave many options for mounting locations. If you look at a 4Runner or Land Cruiser they look the same roughly. The track bar is the lateral load reacting member that goes left to right (also referred to as a panhard).
  30. Mar 11, 2021 at 4:49 PM
    JohnLakeman
    To be fair, the driver looks like a woman or a small person, but that's definitely a crewmax. You can see the rear door outline in the camo, and the door frame at the rear leaves hardly any area for the C? pillar, unlike the current DC which has a big wide C pillar. :D
