Coil overs, what do you recommend?
Discussion in 'Suspension' started by trayday, Jul 18, 2016.
  1. Jul 18, 2016 at 5:22 PM
    trayday
    trayday [OP] New Member
    Oregon
    2015 limited CM 5.7
    I have the 7" BDS lift with the factory springs and Bilstein 5100's. I messed up my springs while driving off the pavement and now they're a bit compressed. I'm looking to upgrade to some coil overs so hopefully I don't run into this problem again. So far I've looked at the BDS and Bullet Proof's C/O's while keeping the 7" and not re-doing my setup besides eventually the UCA's. I'd like to hear your input.
  2. Jul 18, 2016 at 5:44 PM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    You already have coilovers. The truck comes stock with coilovers. The BDS kit just adds s preload spacer and an extension to the lower shock mount. Not entirely sure what you are trying to fix but a photo would help.
    If you are looking for premium coilovers (something rebuildable, tunable, and height adjustable with preload) King and Fox also are options.
    boostedtrdpro, jlee and T-Rex266 like this.
  3. Jul 18, 2016 at 5:54 PM
    trayday
    Oregon
    2015 limited CM 5.7
    Premium, something with a stronger spring. Shouldn't be the shocks, I have less than 10k miles on the setup and the shocks are dry. It's mainly a bunch of rubbing that wasn't there before.
  4. Jul 18, 2016 at 7:06 PM
    bandit
    bandit New Member
    2011 Supercharged Mazzulla Long Travel Rock Warrior
    Duh Tundra
    I'm running fox 2.5 coil overs with 2.5 triple bypasses in the front. I love mine and they take a beating!
    ColoradoTJ likes this.
  5. Jul 18, 2016 at 7:08 PM
    LML 3500HD
    Hard to go wrong with a properly tuned King or Fox.
    jberry813 and bandit like this.
  6. Jul 18, 2016 at 7:10 PM
    bandit
    bandit New Member
    Duh Tundra
    +1
    As far as the two companies who have the most experience and R&D behind their products. King and fox are going to be tough to beat. Unless you can talk ohlins into building some offroad shock porn
  7. Jul 18, 2016 at 7:43 PM
    jberry813
    Lake Tahoe
    New coilovers won't fix rubbing. None of the geometry changes.
    bandit likes this.
  8. Jul 18, 2016 at 7:55 PM
    trayday
    Oregon
    2015 limited CM 5.7
    The rubbing didn't happen until after the damaged parts.
    Do you know if with these brands that I'll be able to keep my clearance? I looked at the Kings but couldn't find that info.
  9. Jul 18, 2016 at 7:58 PM
    bandit
    bandit New Member
    Duh Tundra
    You can have them make you anything your heart desires if you want. Considering you're just running 5100's all you'd need is the OEM replacement coil overs from them which are just stronger and more serviceable and tunable. OEM Replacement means same length your current ones are without the propensity to break as easily. They come in all shapes and sizes.
  10. Jul 18, 2016 at 8:17 PM
    jberry813
    Lake Tahoe
    Again. Photos of said damaged parts? I've hucked my pile of shit all over the place and broke all kinds of shit, but never a coilover.
    As @bandit said, King and fox will build you whatever the hell you want. But it requires a lost art of using your phone as a phone...to call a vendor, not click to buy. If you need suggestions on real shock resellers, I have suggestions. But its up to you and what you want to achieve. I've got over 4 grand in just shocks in my toy truck, and none of it was availible as an off the shelf purchase on a web site.
  11. Jul 18, 2016 at 8:19 PM
    bandit
    bandit New Member
    Duh Tundra
    I'm right there with you....you want fancy shit....Gotta make phone calls. It's so worth it in the end though :D
    jberry813[QUOTED] likes this.
  12. Jul 18, 2016 at 8:24 PM
    jberry813
    Lake Tahoe
    I have no idea what you are taking about :anonymous:
    airosey and bandit[QUOTED] like this.
  13. Jul 18, 2016 at 8:27 PM
    bandit
    bandit New Member
    Duh Tundra
    :anonymous::boink:
  14. Jul 18, 2016 at 8:28 PM
    bandit
    bandit New Member
    Duh Tundra
    2.5 front and bypass?
  15. Jul 18, 2016 at 8:29 PM
    jberry813
    Lake Tahoe
    Fox vs King :duel:
    Aww who am I kidding :cheers: :drunk:
    2cID and bandit[QUOTED] like this.
  16. Jul 18, 2016 at 8:29 PM
    jberry813
    Lake Tahoe
    Yup
    bandit[QUOTED] likes this.
  17. Jul 18, 2016 at 8:30 PM
    bandit
    bandit New Member
    Duh Tundra
    twinsies!:drunk::taco:
  18. Jul 18, 2016 at 9:05 PM
    trayday
    Oregon
    2015 limited CM 5.7
    I didn't know that the companies would build per request, this is good to know. I was talking with another member earlier about buying his coil overs when he upgrades and replacing my current suspension isn't on the top of my list, but I'll start looking.
  19. Jul 18, 2016 at 9:11 PM
    jberry813
    Lake Tahoe
    When you are ready for real shocks, Look up a company called Downsouth Motorsports. Talk to Micah and he will help you with whatever brand you want. If you want a good discount, tell him I sent you and tell him to eat a dick. That's like shock contra code. Up up down down left right left right b a start.
  20. Jul 18, 2016 at 9:33 PM
    trayday
    Oregon
    2015 limited CM 5.7
    Good to know, thanks. I'm about saving a buck when I can. I might do it just for the hell of it..
  21. Jul 18, 2016 at 9:49 PM
    LML 3500HD
    As the others have stated, need to make some calls. Now the lift you have just uses the factory strut system if I remember correctly. Any of the 0-3" King or fox shocks will bolt right in.
    However, I haven't put eyes on a lift like yours in a few years, so I could be more screwed up than a soup sammich.
  22. Jul 19, 2016 at 9:46 AM
    trayday
    Oregon
    2015 limited CM 5.7
    You're correct, uses the factory setup. I'm in need of new springs as well, something more durable; this is the reason that I'm planning on using an after market setup. After I install my bumper, winch, and light bar, the C/O's should be next.
  23. Jul 19, 2016 at 10:16 AM
    LML 3500HD
    While my welds cool in the garage, I have a few minutes to chat.
    Then a good set of Kings/Fox will do nicely. The even better part is you can get the estimated (or actual) weight you are adding with the winch, bumper and light bar so you can get the right springs for the weight/ride height you want.
    Remember....eat a dick for a good discount...@jberry813 you're fucking hilarious.
  24. Jul 19, 2016 at 10:26 AM
    GTABurnout
    GTABurnout New Member
    Not as cool as Long Travel but Icon makes pretty good stuff.
  25. Jul 19, 2016 at 10:31 AM
    LML 3500HD
    ADS Suspension also makes some great shocks.
  26. Jul 19, 2016 at 10:33 AM
    jberry813
    Lake Tahoe
    God do they ever. The internals are a work of art. Probably the best machining I've seen in shocks
  27. Jul 19, 2016 at 10:37 AM
    LML 3500HD
    Yep. I may have went that route on my Jeep if I wouldn't have just went with Kings. There are a few guys I know that run them. If you can spring for them, might want to look into them OP.
  28. Jul 19, 2016 at 10:40 AM
    TheBeast The Beach
    Toytec coilovers are nice too. No res.
    T-Rex266 likes this.
  29. May 4, 2018 at 7:41 PM
    Like a PRO
    Like a PRO New Member
    Rodney
    Slidell Louisiana
    2016 lifted 4×4 SR5
    6 inch Rough Country lift fuel 20×9on 35s , TRD Pro Grill TRD Pro exhaust dual Extang 2.0 tonneau cover
    I have a weird mark on both sides of the back of the spring on my 2.5's have you experienced this me course I'm on a 6" RC with the 7" bds/fox coilovers
  30. May 4, 2018 at 7:59 PM
    LML 3500HD
    Aaron hasn't been on in some time. I haven't received a call from him in 6 months.
