CodiakTundra - Intro Build Thread
Discussion in '1st Gen Builds (2000-2006)' started by codiaktundra, Aug 30, 2017.
  1. Aug 30, 2017 at 3:02 PM
    codiaktundra
    codiaktundra [OP] New Member
    2003 Toyota Tundra 4WD Access Cab Limited
    Gutting to create custom tow vehicle / artcar.
    Hi. New member here. Just got my First Gen '03 limited Access Cab. She was a rollover, barely, and I got her to build into a tow vehicle / art car. Looking to part out a lot of the exterior, and build a custom roll cage.
    If you have a similar rig and are looking for parts, DM me :bananadance:
    silver, purplish, magnetic gray maybe?...
    Excited to start digging in to this mess....
    jfrd30, Y0TA PR0, Coolhardy and 4 others like this.
  2. Aug 30, 2017 at 3:04 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from Colorado
  3. Aug 30, 2017 at 3:12 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    welcome bud
  4. Aug 30, 2017 at 3:28 PM
    Viper3G
    Viper3G Why isn't work more like this?
    Rick
    2016 Crew Max 1794 4WD Super White
    Phillips X-treme Ultinon LED H4 bulbs, 3M Color Stable 35 tint on front doors, 3M Crystalline 40 on sunroof, OEM bed liner, OEM running boards, Morimoto fog LEDs, Fold-A-Cover G4 Elite, Husky X-Act Contour floor mats
    Welcome!
  5. Aug 30, 2017 at 3:28 PM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    jfrd30 and Eclipsed & Floating like this.
  6. Aug 30, 2017 at 3:31 PM
    Bob
    Bob Member Staff Member
    Bob
    07 Tacoma PreRunner Black
    Excited to follow that build...welcome aboard!
  7. Aug 30, 2017 at 3:53 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    This is a new intro!
    Welcome from CO!!
  8. Aug 30, 2017 at 4:00 PM
    Welcome from Texas!
  9. Aug 30, 2017 at 4:40 PM
    Tomcat
    Tomcat Ever see a motorcycle outside a shrinks office?
    2010 SR5 4X4 5.7 20" wheels Metallic Gray
    Bakflip
    Welcome from Atlanta
  10. Aug 30, 2017 at 4:42 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    Welcome from Texas
  11. Aug 30, 2017 at 5:01 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    Welcome from WI
  12. Aug 30, 2017 at 5:08 PM
    Welcome from CO! What are your plans for it?
  13. Aug 30, 2017 at 5:16 PM
    Coolhardy
    Coolhardy New Member
    Harris
    2014 black tundra
    Too many to list
    I like it when you build something out of nothing.
  14. Aug 30, 2017 at 6:11 PM
    Kdgcng
    Kdgcng Rock steady
    Kyle
    2017 Magnetic gray tundra SR5 crewmax
    Welcome from texas! Looking forward to seeing your build!!
    codiaktundra[OP] likes this.
  15. Aug 30, 2017 at 7:09 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    Welcome from AZ.
  16. Aug 30, 2017 at 7:27 PM
    nishibot
    nishibot Just2havnfun
    Perris, CA.
    2017 Tundra CM 4x4 TRD Off Road MGM
    Welcome from SoCal
  17. Sep 7, 2017 at 8:50 AM
    codiaktundra
    Thanks all. finally some updates.. :dancingbacon::dancingbacon::dancingbacon:
    pulled the lil step up guys off... (both sides, only one photo)
    pulled the front bumper... careful with that airbag sensor...
    (removed that lil guy, for now)
    here's what I am working with on the ol' lid... all the doors are sound, except the driver, which looks like the latch is the culprit...
    not looking too bad.... over all
    transmission is a little rough in and out of R... assuming this is due to being upside down... thinking new juice and seals will help her..
  18. Sep 7, 2017 at 8:56 AM
    codiaktundra
    Bed is right about ready to come off... this is a little different than pulling the bed on my 1stGenTaco... that was SIIIIIMPLE...
    this one has a couple more bolts holding the gas tank tube to the bed... and had to pull the Liner out... (which is available)
    The taco is just six bolts and the tube lives with the frame. but overall bed is in good shape for whatever is next in it's life...
  19. Sep 7, 2017 at 8:57 AM
    codiaktundra
    sittin higher already ..
  20. Sep 7, 2017 at 10:17 AM
    codiaktundra
    well, here is the loose direction.... I will append later....
    Concept
    • Artcar
      • Flatbed truck with extending panels, (ideally 3x the truck width when extended, 90* supports to meet the frame.
      • Plush outdoor fabric / cushioning for passengers.
      • Outdoor/marine speakers, subwoofers, amps and exciters (all weatherproofed or enclosed in cab) https://www.parts-express.com/auras...source=google&utm_medium=cpc&utm_campaign=pla
      • High-res short-throw outdoor projector
      • Non-Screen projection screen (surface TBD) - attached to back of cab
      • perimeter LED safety lights (w RGB controller)
      • step-up Boat Style ladder at rear
      • air bag support/suspension
      • Mounted laser
    • Tow Vehicle
      • Plate front bumper (simple as heck)
      • Plate rear bumper (also soo simple)
      • Low-to-ground-spot- lighting - as reasonably long distance as possible - front and rear.
      • Front bumper winch
      • Onboard air - OR - large compressed air tanks
      • Onboard water tank
    Exterior:
    • Driver and passenger windows
    • Driver door
    • RatRod - larger rear tires (need to learn about how this will affect other systems)
    • Roof - front 1/4 cab
    • Clad in thin gauge steel,
      • Ideally replacing all external panels with angular MadMax/NolanEra-Batmobile look feel, as a bear head, with teeth out (panels mount to existing mount locations)
      • minimally distressed with chemical seal to prevent corrosion.
      • LEDs every-damn-where
    • Custom flat bed,
      • Angle iron perimeter w tie-down points
      • 2x6 or 2x8 board floor - weather treated
      • Secure lock box for tools and gear
      • Winch to bed
      • Second Battery at rear
    Interior:
    • As this will be a desert truck, keeping the interior plushy is the goal. Leather interior is intact and clean.
    • A/C recharged as needed.
    • CB, mic, etc
    • Antenna cable, etc
    • "new" mats
    • monitor (reverse and bed cam)
    To Start:
    • Remove Rack, assess project scope.
    • Pull the bed off, everything from the cab back. Sell as many pieces of the exterior as possible.
    • Address Battery (lead acid upside down = no good ) thinking gel, probably not Optima tho.. Die Hard maybe??
    • Begin cardboard mock ups
  21. Sep 13, 2017 at 9:44 AM
    codiaktundra
    Bed is off. Woohoo. Sure is fun zipping around all nekkid like that.
    [​IMG] [​IMG]
    This was more complex than taking the bed off my first gen taco.
    But now there is a Liner and a Bed ready to go find a new home.
    Six big ass torx bolts, two for the gas tank stem, and the wires to the lights.
    Surprisingly there wasn't really anything holding the liner in...
    Next up getting the driver door to latch...
    I punded out the new angle on the upper part of the door, so everyone is meeting up nicely, but the Latch is pretty much destroyed, so I am off to YodaJims to dig around, and learn how the latch works.
    :locked: :locked:
    NewImprovedRon likes this.
  22. Sep 13, 2017 at 1:16 PM
    codiaktundra
    solved the limp gassline issue...
    just took one M12 -1.25 Fine Thread hex bolt.... in the bed bolt hole.
    and a washer, for good measure.
  23. Nov 7, 2017 at 4:41 PM
    elbaba
    elbaba New Member
    2000 tundra trd
    Great work so far. Keep it up.
  24. May 21, 2018 at 8:01 PM
    drowssap
    drowssap New Member
    Littleton, Colorado
    2012 Tundra double cab
    Any updates???
