Coachbuilder VS Toytec Shackles
Discussion in 'Suspension' started by Slp82, Jul 26, 2018.
  1. Dec 23, 2018 at 10:32 AM
    #91
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Okay, I might need to do that. My full size spare is under now but it touches one side of the shackle I installed yesterday.. I might do that
  2. Dec 23, 2018 at 10:39 AM
    #92
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    Yep, I tried doing one and it helped a little but both were needed. It was kind of a bitch drilling out the studs. Be sure to wear eye protection because hot metal is flying.
    Jsena[QUOTED] likes this.
  3. Mar 27, 2019 at 10:44 PM
    #93
    IvandGreat
    IvandGreat New Member
    Ivan
    2017 Tundra Platinum Crewmax Supercharged// 2007 Tundra Limited Crewmax
    Supercharged, Exhaust, Leveling Kit, Toyo MT
    Did you have to modify your trd sway bar?
  4. Mar 28, 2019 at 5:04 AM
    #94
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    No but I’ve seen them installed behind the axle instead of below on lifts.
    Rica25 likes this.
  5. Feb 18, 2020 at 2:29 PM
    #95
    junior
    junior Member
    Zach
    Santa Cruz, CA
    2016 Tundra TRD Off Road
    Black Rhino Rapid 17" 35x12.5 Mickey Thompson Baja Boss Fox Performance Elite 2.5 DSC at 3" with Coachbuilder 1/4" shim on driver side JBA UCAs Fox Performance Elite 2.5 DSC rear shocks Dobinsons HD Leaf Springs Firestone Airbags + Daystar Cradles Prinsu Cab Rack 2024 Four Wheel Camper Project M Camper Mods: Goal Zero Yeti 4000 house battery 200w solar IceCo fridge Truma Propane Heater
    Im looking at getting a set of the Toytec's—I think 1.5" will be perfect on my truck.
    If I currently have CB +2's, does anyone know if CB poly bushings work with the Toytec shackles? From the pics I feel like they do.
  6. Feb 18, 2020 at 2:40 PM
    #96
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    I don't see why not since the bushing goes into the eyelet of the leaf spring.
    junior[QUOTED] likes this.
  7. Feb 18, 2020 at 3:45 PM
    #97
    Bob_Wiley
    Bob_Wiley I feel good, I feel great, I feel wonderful...
    Eric
    AZ
    2016 Black SR5 Crewmax 5.7 FFV
    Ok, really ignorant question....when installing shackles, do you install at the rear joint only, or do you install at both the front and rear of the leaf spring? In other words, do you install 4 shackles or only 2 shackles?
  8. Feb 18, 2020 at 4:11 PM
    #98
    TXTundra2722
    2015 Black Tundra
    It's only the rear shackles.
    Bob_Wiley[QUOTED] likes this.
  9. Feb 18, 2020 at 4:49 PM
    #99
    matictundra
    Franco
    AZ
    There are no front shackles.
    1lowlife and Bob_Wiley[QUOTED] like this.
  10. Feb 24, 2020 at 3:56 AM
    #100
    Bad Cow
    Bad Cow GOD Bless The USA
    Georgia USA
    2019 TRD PRO - SUPER WHITE
    Leather Steering Wheel, +1.5" Shackles
    Okay, I'm going out on a limb here and asking a question that might seem dumb to some. When going with ToyTec or CB shackles, is it necessary to replace the factory leaf spring bushings with poly? Or, if your truck is fairly new like mine, can you just run the factory bushings? What are the Pro's & Con's?
  11. Feb 24, 2020 at 7:20 AM
    #101
    junior
    junior Member
    Zach
    Santa Cruz, CA
    Its not necessary for the Toytecs. With the CB shackles you have to because of the way they are designed (why they come with them)—but with the toytecs it will just improve the ride quality/reduce bed bounce slightly with the poly bushings.
    Bad Cow[QUOTED] likes this.
  12. Feb 24, 2020 at 8:13 AM
    #102
    Bad Cow
    Georgia USA
    10-4, but I don't get any bed-bounce now with the factory bushings. Slick as glass. Only reason I am considering them is for towing my boat. The PRO's tend to sit VERY level.
  13. Feb 24, 2020 at 2:30 PM
    #103
    They are cheap enough that I would swap them to the polys.
  14. Feb 25, 2020 at 9:35 AM
    #104
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    Random do you need longer shocks if you put A. Shackles B. Blocks. C. Leaf springs for lift
  15. Apr 11, 2020 at 9:36 AM
    #105
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    Pulled up this thread looking for info after installing my Toytec adjustable shackles. I installed the new poly bushings in the leaf spring and when I torqued the lower bolts to 75 ft-lbs and there are no threads showing - the nut is flush with the end of the bolt. It’s the same on both sides. I have 1 washer between both the bolt head and nut and shackle.
    Something just doesn’t seem right and wanted to ask if anyone else’s install is like this? It seems the bolt should be about a 1/2” longer. See pics.
    @Toytec Lifts ?
    7A76725F-C233-491B-9DC1-B51E39348FF0.jpg 088A9F76-6A8D-41E2-921A-2E1465863115.jpg
  16. Apr 11, 2020 at 9:44 AM
    #106
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
  17. Mar 20, 2021 at 1:29 PM
    #107
    cdavi060
    cdavi060 New Member
    Virginia Beach, VA
    2017 Super White Tundra Platinum CM
    285/70r18 NITTO RG | Method NV 18x9 | Bilstein 6112 @2.5" w/CB shims, SPC UCA, 5100 & CB +3 Shackles | Entune 3.0 Swap | 2018+ Platinum grille + Pro LED Headlights
    Are the “poly bushings” mentioned here the “Toytec Adjustable 1-1.5" Lift Shackles with Spring Bushings” on the Toytec website? Or something separate?
  18. Mar 20, 2021 at 1:54 PM
    #108
    You have the option to add them when you add shackles to your cart.
  19. Oct 27, 2021 at 6:41 PM
    #109
    BCTRD
    BCTRD New Member
    B.C.
    2021 MGM Tundra TRD Sport
    18"BBS Forged wheels, factory running boards, VLED's, Rigid Pro Led mod (D2 SAE), diff breather mod, Husky mats, DIY Cquartz UK 3.0, Husky liners, OCD organizers,
    You guys getting any driveshaft vibration with the toytec shackles set at 1" or 1 1/2", or the CB 1" .625" kit?
    Wondering how much of a pinion angle change these shackles create and at what point the typical crewmax needs a carrier drop shim or see vibrations.
    Should be installing the Elka 0-2" kit at 1.5" in a few months and looking at shackle options to maintain a slight rake for towing.
  20. Oct 27, 2021 at 7:53 PM
    #110
    I would install the carrier bearing kit to eliminate the vibrations. It's only $15.00 or so.
    BCTRD[QUOTED] likes this.
  21. Oct 28, 2021 at 5:05 PM
    #111
    BCTRD
    BCTRD New Member
    B.C.
    Agree.
    Looking at the Deaver or Icon 1.5' leaf packs as another option. Not sure if these require the drop as well.
    For a couple of bucks and a few minutes I'd definitely give it a try.
  22. Jul 8, 2022 at 2:11 PM
    #112
    Tundra694
    Tundra694 New Member
    AJ
    2021 Tundra Crew Max Trd Off Road
    Yes. Me. Lol set at 1.9” and was happy. Then a friend did his at 2.5” with add A leaf and I instantly wished I did the same ‍♂️
