Coachbuilder Shims and Fastener Kit
Discussion in 'Marketplace - Other' started by Tacogeuse, Oct 6, 2016.
Thread Status:
Not open for further replies.
  1. Oct 6, 2016 at 8:03 AM
    Tacogeuse
    Tacogeuse [OP] New Member
    CO
    SOLD.
    dcsleeper408 likes this.
  2. Oct 24, 2016 at 9:03 PM
    PMG
    PMG New Member
    I don't even know if I'll go this route, but I'm a hoarder and so why not. Would you consider $50 shipped? If not, cool and have a good one ☺
    PMG
  3. Nov 21, 2016 at 7:13 PM
    Quartermeter
    Quartermeter New Member
    James
    Alabama
    2014 SR5 DC WHITE
    FOX 2.0 REARS, OME FRONTS FIRESTONE AIR BAGS RCI SKID PLATE
    What r these for?
  4. Nov 21, 2016 at 8:00 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    To lift the truck front end.
    These shims are 1/4" thick and go at the top of the front struts. Each 1/4" shim will raise that corner 1/2".
  5. Dec 3, 2016 at 6:04 AM
    PMG
    PMG New Member
    Just got my wheels and 5100s. Now I'm thinking I'll need these now lol
    PMG
  6. Dec 3, 2016 at 7:54 AM
    Quartermeter
    James
    Alabama
    2014 SR5 DC WHITE
    How will a 1/4 " shim raise the body 1/2"??
  7. Dec 3, 2016 at 2:35 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I'm not smart enough to explain it. Several times I've had the control arm geometry explained to me but between my age, general lack of intellect and all of the scotch I drink any explanation would probably be wrong. Hopefully one the young smart suspension gurus will chime in.
    MistrRoboto, veg hed and rons23 like this.
  8. Dec 3, 2016 at 9:11 PM
    Cutter29
    Cutter29 ...
    Utah
    2015 Super White TRD PRO
  9. Dec 3, 2016 at 9:14 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Sarcasm?
  10. Dec 3, 2016 at 9:23 PM
    Cutter29
    Cutter29 ...
    Utah
    Just the easiest way to explain how 1/4" gets you 1/2" of lift
    gosolo[QUOTED] likes this.
  11. Dec 4, 2016 at 7:02 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    . Coachbuilder shims are 0.25 inches thick but will give you 1/2 inch lift in the front. They were originally intended to correct the side-to-side leaning on Tundras (most Tundras are lower on the driver side). But some use them to give a slight lift. Definitely get the diff drop if you go this route.
  12. Dec 4, 2016 at 9:46 AM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    The shim is the same as compressing your spring. The more the spring is compressed the tighter it is and the more the lift. If you look at a Bilstein 5100 adjustable shock, the clip grooves for the spring seat is very minimal compared to the actual lift. Oh hell............Yaaaa, it's magic. Hope this helped.
  13. Dec 4, 2016 at 10:19 AM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    I thought the shims sit on top of the top hat?
  14. Dec 4, 2016 at 10:44 AM
    AxelsHumanDad
    AxelsHumanDad Get off my lawn.
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
    Quoted from another forum, not my conversation:
    *QUOTE
    I had the same question, how could two shims, which measure 1/4" each (1/2" combined), equal to 1" of total lift. This was the explanation I got from Coachbuilder.
    "The shims do work a little odd
    If you notice where the upper and lower control arms bolt to the frame. This is your pivot, from the pivot out to where the tires touch the ground is your contact. The area where the shims install, just above the strut assembly is about in the center of the pivot. If the pivot were vertical it would be a 1:1 ratio but is actually about a 1:1.120. hope this makes sense. 2 shims will provide 1" of total lift.
    David"
    *END QUOTE
    There is another detailed explanation floating around I stumbled across once, I'm digging for that one.
    If all else fails, ask The Man himself, David is a nice guy.
    SouthBoundSteve and gosolo like this.
  15. Dec 4, 2016 at 11:54 AM
    CM-LENNY
    San Diego, CA
    The shims do sit on the very top. I just used the bilstein snap ring clip location as an example. Look at any other aftermarket shock set up. Moving the adjustment on the coil does not equal a 1:1 ratio. In other words you dont move the coil bottom or top adjustment 3" the gain 3" of lift. Think David explained it pretty good. He's the engineer guy. Hope this helps with my original post.
    gosolo likes this.
  16. Dec 27, 2016 at 8:15 PM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    You have a pm.
  17. Mar 28, 2017 at 3:39 AM
    Quartermeter
    James
    Alabama
    2014 SR5 DC WHITE
    Not magic its Trig
Thread Status:
