COACHBUILDER SHACKLE HELP!
Discussion in 'Suspension' started by jcastro1, Jun 27, 2021.
  1. Jun 27, 2021 at 12:10 PM
    jcastro1
    jcastro1 [OP] New Member
    Juan
    2008 tundra
    10” lift on 24x14 wheels
    So you think by doing that the shackle will push backwards instead of being straight up and down and bring the leaf back down?
  2. Jun 27, 2021 at 12:13 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    That’s the idea
  3. Jun 27, 2021 at 12:14 PM
    jcastro1
    Juan
    2008 tundra
    Let me try that then bro
  4. Jun 27, 2021 at 1:00 PM
    Did you swap out the OEM bushings and switch to poly? I you didn't and tightened the shackles while up in the air then the OEM center bushing pin, for lack of better word, which is serrated on the ends, will bite into the shackles which contributes to bed bounce. Always torque the shackle nuts once the truck is lowered and on level ground.
  5. Jun 27, 2021 at 2:47 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    You're gonna want different shocks or move the mount regardless if/how you can get the current shocks to mount up, otherwise your ride will be ass since you'll have no down travel (and the shocks will probably get ripped in half in short order too). Looks like you'll also want to move your exhaust around or it'll go pogo sticked by your leafs. And while you're under there, make sure none of the brake lines or anything running down to the axle have any tension in them at full droop or they'll get ripped apart too. Looks like there's a couple issues that need some massaging to make the suspension happy with that much lift, the shocks is just the beginning.
    Mr Swervlin likes this.
