Coachbuilder bumper shims
Discussion in '2.5 Gen Tundras (2014-2021)' started by dhdubey88, Nov 1, 2020.
  1. Nov 1, 2020 at 10:00 AM
    dhdubey88
    dhdubey88 [OP] New Member
    David
    Roseville
    2017 SR5 crew max
    Flowmaster 40 series muffler Headache rack/tonneau cover Bilstein 6112 at top notch Bilstein 5160 Coachbuilder +2 shackle Rear diff breather relocate Coachbuilder bumper shims Lower control arm skid trim Oedro bolt on sliders Raceline injector 18” wheels 35x12.5x18 toyo RT
    Ordered my bumper shims from coachbuilder on Thursday morning and received them on Saturday! Talk about fast. And gotta love the packaging. Can’t wait to put these on then get my lift and wheels/tires!
    rothmigo, GarTX526 and ShinyConcretE like this.
  2. Nov 1, 2020 at 11:29 AM
    ShinyConcretE
    ShinyConcretE New Member
    Justin
    Northern California
    2020LimitedCM
    Nice to see another Rosevillian here.
    dhdubey88[OP] likes this.
  3. Nov 1, 2020 at 11:33 AM
    BayRunner
    2017 Tundra Platinum
    Nice... Just put these on this week as well. Did it without taking the bumper off. Left one nut barely on one side (the lower 3 bolt nut) which allowed me to work the other side off just enough to slide the shims on. The reversed and did the other side. Took a little patience using this approach but can be done.
    bulldog93, rothmigo, DZ_ and 2 others like this.
  4. Nov 1, 2020 at 3:08 PM
    dhdubey88
    David
    Roseville
    2017 SR5 crew max
    Yes sir! I’ve been inactive on here for some time but getting back in. Love the cement
    ShinyConcretE[QUOTED] likes this.
  5. Nov 1, 2020 at 3:10 PM
    dhdubey88
    David
    Roseville
    2017 SR5 crew max
    Awesome. I was planning on trying it that way as well. What set up are you running?
  6. Nov 1, 2020 at 9:18 PM
    BayRunner
    Prepping for a 295/70R18 and 3/1 install. Just trying to minimize any trimming that may need to be done. Currently running 275/70R18 on a level 1.9. with no rubbing.
  7. Nov 1, 2020 at 9:38 PM
    Highsierraguy
    Highsierraguy New Member
    Nor Cal
    Will these solve rubbing on the spot pictured below? I just mounted 285/75/17 and get a lot of rubbing on this spot, both sides, when turning in reverse.
    the ER kid likes this.
  8. Nov 1, 2020 at 10:37 PM
    BayRunner
    Hard to say since it varies on the individual setup. The bumper shims gives you an additional 1/2 inch.
  9. Nov 2, 2020 at 6:14 AM
    dhdubey88
    David
    Roseville
    2017 SR5 crew max
    Nice, I currently have just a leveling kit up front with 285/65/18. The plan is to put 6112 at 2.5 up front with 5160 in the rear with icon 1.5 aal and run 285/75/18. Hoping that with my wheels and the bumper shims not much else is needed in the way of clearance.
  10. Nov 2, 2020 at 9:08 PM
    dhdubey88
    David
    Roseville
    2017 SR5 crew max
    What wheels are you running, with what offset?
  11. Nov 2, 2020 at 9:45 PM
    Highsierraguy
    Nor Cal
    Method 313, +25. After doing some more research I'm going to first attempt pushing the liners forward and re-drillng, a if that fails I'll trim them.
  12. Nov 3, 2020 at 7:24 AM
    dhdubey88
    David
    Roseville
    2017 SR5 crew max
    Nice, I heard you can get some wiggle room out of it without getting the bumper shims.
  13. Dec 1, 2020 at 7:49 PM
    GarTX526
    GarTX526 New Member
    2016 QuickSand TRD-Pro
    Many pending.....
    That’s the exact area where I get the rub. Shims to be ordered shortly. Running Nitto Ridge Graps 295/70 R18s. That’s my only contact point. Looking to go 35x12.50s soon and may need BMC at that time. For now; shim it.
  14. Apr 3, 2022 at 4:27 PM
    Tundra2Yak
    Tundra2Yak New Member
    2016 1794 4x4 CM
    Pro Comp 6" Lift Fuel Renegade d263 Nitto Ridge Grappler 35 x 12.5 x 20 Borla cat-back exhaust Volant intake Bakflip MX4
    Digging up an old thread here but curious about long term feedback. Any issues with using these after a while or do you forget about them once installed?
    Anyone have before/after pictures? Wondering how noticeable the bumper offset is.
  15. Apr 3, 2022 at 4:35 PM
    schleinj
    schleinj New Member
    James
    2018 Cement SR5 Crewmax 2wd
    Leveled (low range off road) Method 305 NV with falken wp 295/70 R18 tires Vled puddles and floorboard leds Oem tail gate lock Talons garage cat plates Charvonia tie down anchors
    just did mine. It’s noticeable but seem to blend in on my with the new wheels and tires.
  16. Apr 3, 2022 at 4:55 PM
    Tundra2Yak
    2016 1794 4x4 CM
    Thanks for the pic. Doesn't look too noticeable. Its actually way better than the current offset on my passenger side.
    The dealership will be replacing my chrome bumper caps with painted plastic due to some existing damage I didn't notice at delivery. Wondering if I should push my luck and have them install these shims while they have the bumper off instead of making them trim the new caps to eliminate rubbing.
    Running 35 x 12.5 and get a little rubbing at full lock in reverse.
  17. Apr 3, 2022 at 5:05 PM
    dvs_one_76
    dvs_one_76 New Member
    Ken
    2017 Platinum
    I didn't do the Coachbuilder shims, but still had to "massage" the inner bumper cover after install of new wheels and tires. Put 20x9 Fuel Techs with a +20 offset, and 285/65/20 BFG KO2s, so still had slight rubbing at full tilt and reverse depending on the position of the truck.
  18. Apr 9, 2022 at 12:40 PM
    Trappererick
    Trappererick New Member
    Erick
    Maine
    2014 DC SR5 TRD OffRoad
    Dobinson's 2.25" front coil overs with .25 shim, Dobinson's rear shocks and, Ironman Performance Rear leaf pack. CaliRiased Side Shooter ditch lights, 17" Icon Alloy Rebound Bronze wheels with Kenda Klever 35x10.5x17
    I don't have any pictures but I have had the shims on for two years with no issues. I am running 17" Icon Rebounds with +25 offset and 35x10.5" Kenda KR 601's no rubbing and no issues.
    Absoluterock and Tundra2Yak like this.
  19. Apr 9, 2022 at 7:22 PM
    Tundra2Yak
    2016 1794 4x4 CM
    I ended up ordering the Toytecs. Dealership is going to put them on when they have the bumper off. Hopefully that means no need to trim.
  20. Apr 14, 2022 at 7:04 AM
    PaulROahu
    PaulROahu New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    Coach Builder 1/2” bumper ship plus another 1/4” by relocating the inner fender bolt for total 3/4” extra gap for front tire to move through. Bonus is that it still keeps the factory look/Intergrity without cutting/melting the inner plastic fender liner
    ackthresher and rothmigo like this.
  21. Apr 14, 2022 at 7:53 AM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    Best thing I ever bought for my Tundra, I got my turning radius back with 35s on 20s and -20 offset and 6" lift. No more Rub :yes:
    Tundra2Yak and PaulROahu like this.
  22. Apr 14, 2022 at 8:12 AM
    Tundra2Yak
    2016 1794 4x4 CM
    Thanks for sending these.
    PaulROahu[QUOTED] likes this.
  23. Apr 14, 2022 at 9:28 AM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Here’s a pic on passenger side tire (33.1/10.8/20)clears with lots of clearance
  24. Mar 14, 2024 at 4:28 PM
    Absoluterock
    Absoluterock New Member
    What lift?
    Also, I’m hoping to get away with 35x10.5 on stock wheels/offset (I have 6112’s but on the lowest setting…1” lift … could move the clips up but hoping not to)
    I’ve been on 34x10.5’s for a while with zero rubbing.
    I’m planning to shim the bumper before trying 35’s but…Any thoughts on how well this will work or where else I might rub?
  25. Jun 9, 2024 at 5:39 AM
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    Just purchased these. Lifting my truck 3/1.75 with 6112/5260 and cb shackles. Hoping to fit 295/70/18 with no rubbing. Stock TRD off-road wheel with bora 1.25” spacers. Can’t do a BMC in my state due to inspections from what I’ve heard(NY). I think I’ll be ok. Just have to figure out what tire. I’ll take any suggestions. Prefer 3 peak rating and good wet traction. Get a lot of rain where I live. Thinking falken AT4 but they are so heavy! KO3 not out in that size until August. Toyo ATIII is another option. Ideas? Also considering 285/70/18 falken AT4: they end up being a 34” tire. But they are only C-load.
