Coach builder TRD Pro Kit
Discussion in 'Suspension' started by jtorres83071, Sep 18, 2020.
  1. Sep 18, 2020 at 5:42 PM
    jtorres83071
    jtorres83071 [OP] NY TRD Pro
    Jay
    2020 Tundra TRD Pro
  2. Sep 29, 2021 at 9:51 AM
    TruPatriot
    TruPatriot New Member
    Lee
    Northeast Texas
    2020 TRD Pro MGM Mall Crawler & Trail Riding Queen
    I'm interested in this as well. I'm leaning toward Westcott Design Pro Lift Kit front & back, but the more I read, I may want to use Coachbuilder shackles in the rear versus the block from Westcott. My Pro is a daily driver and used off road just for camping and light trails. I tow a camper and bass boat occasionally. any advise would be greatly appreciated.
  3. Sep 29, 2021 at 9:59 AM
    Lost in the East
    Lost in the East New Member
    Derek
    Voodoo Blue TRD Pro
    I went with CB +3 shackles in the rear, but I have the Westcott Designs Pro lift in the front. I really like how mine came out.
  4. Sep 29, 2021 at 10:03 AM
    WinterWarlock21
    WinterWarlock21 New Member
    South Jersey
    2016 Quicksand TRD Pro CrewMax
    https://gearproject.co/profile/SandShark21
    This is as my plan as well! what tires are you running? If you have a full size spare does it hit the shackles?
  5. Sep 29, 2021 at 10:06 AM
    Lost in the East
    Derek
    Voodoo Blue TRD Pro
    I'm running 295/70-18 on +25 wheels. Had to trim the liner a little to stop the rubbing. I'm running the original spare and its fine. Not sure about a 295/70-18 spare fitting.
  6. Sep 29, 2021 at 11:14 AM
    jtorres83071
    Jay
    2020 Tundra TRD Pro
    So as an update, I did install the Coachbuilder kit on my 2020 TRD Pro truck. They claim that no modifications are required but if you’re running 35’s like me, the front will rub on hard turns in reverse. This is even with the bumper shims, which should be at least another 1/2”
    Coachbuilder1 likes this.
  7. Sep 29, 2021 at 12:05 PM
    TruPatriot
    Lee
    Northeast Texas
    Sweet...can you share some pics?
  8. Sep 29, 2021 at 12:06 PM
    TruPatriot
    Lee
    Northeast Texas
    Could you share some pics?
  9. Sep 29, 2021 at 12:12 PM
    Occidentalis
    Occidentalis Out Snakin'
    North Florida
    2015 Inferno TRD Pro
    Where does it rub? Passenger side sway bar tube?
  10. Sep 29, 2021 at 3:33 PM
    Lost in the East
    Derek
    Voodoo Blue TRD Pro
    Westcott & +3 shackles
    295/79-18
  11. Sep 29, 2021 at 4:25 PM
    WinterWarlock21
    South Jersey
    love the voo doo!! That’s the color I originally wanted. Just looks so good.
  12. Sep 29, 2021 at 4:43 PM
    TruPatriot
    Lee
    Northeast Texas
    Very Nice!!!
  13. Oct 3, 2021 at 4:06 PM
    jtorres83071
    Jay
    2020 Tundra TRD Pro
    On the front inner well plastic on a hard turn in reverse
  14. Oct 16, 2021 at 3:48 PM
    TruPatriot
    Lee
    Northeast Texas
    I went with Westcott and couldn’t be happier. The guys at Westcott spoke highly of Coachbuilder and stated they use some of their products also.
  15. Oct 16, 2021 at 5:35 PM
    Lost in the East
    Derek
    Voodoo Blue TRD Pro
    Very Nice!!
    TruPatriot[QUOTED] likes this.
  16. Feb 5, 2022 at 4:32 PM
    TruPatriot
    Lee
    Northeast Texas
    Thank you, sir!
  17. Jul 12, 2022 at 9:59 PM
    Luke_Skywalker
    Luke_Skywalker New Member
    Luke
    2020 Tundra TRD Pro
    Eibach TRD Pro Front Springs, Dirt King UCA's Coachbuilder +3 shackle (poly bushings)/carrier bearing drop, steering upgrade, bumper shims, White Knuckle Sliders, Leitner Designs, Baja Designs, Switch Pro, Victron Solar, BORA 1.25", BFG KO2s, Wheelers Superbumps, VLED interior lights, 12" Sub, Window Tint.
    We need pics man! Are you running spacers?
  18. Jan 28, 2023 at 11:25 AM
    Petergoose1
    Petergoose1 New Member
    2020 pro army green
    I have a 2020 pro with westcott front and Coachbuilder shackle’s. If you like the way your pro rides, I wouldn’t advise the westcott front kit. I’m taking it off
  19. Jan 30, 2023 at 4:04 PM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    David
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    Thanks for posting, Contact up front normally happens if the caster is set too high even with 35"s. how's your clearance at the body mount?
    Alignment specs we use and recommend with our PRO kit.
    Camber +.2 Degrees Per Side.
    Caster +2.2 - +2.5 Degrees Per Side.
    Toe +.07 - +.10 Degrees Per Side, Not to Exceed +.20 Combine.
  20. Jan 30, 2023 at 4:06 PM
    Coachbuilder1
    David
    Salt Lake City UT
    Sadly we see this often, anytime you add preload to a tuned coilover it rides rough and choppy.
  21. Jan 4, 2024 at 11:53 AM
    Born-Riding
    Born-Riding New Member
    Barrett
    2021 Tundra crewman TRD PRO
    If i Have the CB kit, and i decide to add a bumper with winch, can i install different springs for weight and still function regularly?
    Are there any Upper control arms that allow more range of adjustment if using wheels without spacers?
    thanks, B
  22. Jan 4, 2024 at 12:18 PM
    Coachbuilder1
    David
    Salt Lake City UT
    What year is your PRO? there are springs options you're able to use with added weight.
    Most often you wont need a UCA thats adjustable but def can use them. SPC and Icon (Billets) are adjustable but would also recommend Total Chaos or JBA. Feel free to call in if you'd like to go over in better detail.
    David 801,635,4872
  23. Jan 4, 2024 at 1:22 PM
    Born-Riding
    Barrett
    Awesome. Thank you so much for the info! The tundra is a '21 pro model. I will reach out to be sure everything is compatible with the kit before i order. Thanks again,
    B
