CNC Machines
Discussion in 'Sports, Hobbies & Interests' started by BB Stacker, Jan 17, 2021.
  1. Feb 1, 2021 at 10:06 PM
    #61
    nlaroy
    nlaroy New Member
    Nick
    So Cal
    2017 Inferno Crewmax
    LED bulbs, RCI Underwear, WKOR Sliders, Fox 2.5 w/ resi Front and back, Deaver leaf springs,
    Secrets out, and i'm late!
    ToyoMafia[QUOTED] likes this.
  2. Feb 1, 2021 at 10:45 PM
    #62
    jwatt
    jwatt I heart men
    Jack
    Oregon
    Cool thread. I run Linux now, but when I ran winblows I liked to use an older version of Inventer. Can t remember what version it was, but it came with Fusion before it became Fusion 360, and was just a free addon. Fusion was quite a revelation, and it didn t take autodesk long to figure that out, change the name, and start charging for it. What I liked about inventor was I could make my solid in Inventor, and import ipt file directly into mastercam. I used an old dos based mastercam, v9, with only surfaces, so Inventor made it a whole lot easier, Before I got Inventor I was making surfaces in mastercam, and was pretty daunting. Patching them together, and subsequently creating toolpaths off of them was so time intensive, (especially when the program crashed, which it did occasionally, and I d have to start all over), but I learned a lot. A few years ago I was planning on buying a Tormach PCNC 440 mill, but my situation turned shyty, and I ended up moving to a second floor apt, so a mill is out of the question. I m still hoping though...
  3. Feb 1, 2021 at 10:49 PM
    #63
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Oh. My. God. It’s Disneyland.
    TNTundra16[QUOTED] likes this.
  4. Feb 1, 2021 at 11:36 PM
    #64
    jwatt
    jwatt I heart men
    Jack
    Oregon
    I ran an old emco 3 axis desktop mill when I worked in a cabinet shop. I was machining wood making small stuff for the shop, and a few craft items. I ended up turning out some nice projects.
    I was going to go back to making this kind of stuff when I got my own mill, but that s not happened yet.
  5. Feb 1, 2021 at 11:50 PM
    #65
    jr1016
    jr1016 New Member
    Ric
    Sacramento, CA
    2020 CM TRD Sport
    That was satisfying to watch. Which machine do you have. I started looking into CNC but I don't want anything too big. Just something to DIY stuff on and possibly make a little bit of money on the side to help pay for the machine.
  6. Feb 2, 2021 at 12:12 AM
    #66
    jwatt
    jwatt I heart men
    Jack
    Oregon
    This is the machine I was going for. It s not a big footprint, but the build quality is good, has a 10,000 rpm spindle, and the premium package includes an auto tool changer.
    jr1016[QUOTED] likes this.
  7. Feb 2, 2021 at 3:31 AM
    #67
    Notarobot
    Notarobot Jagged lines!
    2013 CM
    Dang, ATC Tool setter AND probe? That's not a bad price if the size is right. What's the work envelope?
    My only concern would be rigidity, it looks a little thin between the table and cabinet.
  8. Feb 2, 2021 at 3:38 AM
    #68
    jwatt
    jwatt I heart men
    Jack
    Oregon
    If you click the picture it will take you to their website. I think it s like 12"x10' or something like that.
  9. Feb 3, 2021 at 6:57 AM
    #69
    BB Stacker
    BB Stacker [OP] New Member
    So. Cal
    2016 White 1794 TRD 4X4
    Sway Bar, TRD Catback Exhaust, Morimoto LED fog lamps, running boards, paracord wrapped oh-shit handles, Bak-Flip bed cover.
    I went with a OneFinity Woodworker. It takes up a 48" X 48" worktop not including space for the controller and drawers for all of the things associated like Bits, wrenches, measuring equipment, clamps. It is a great tool that was very easy to assemble. Nice thing is it is easy to disassemble and take someplace else, set it up and be up and running within an hour or so.
  10. Feb 3, 2021 at 7:13 AM
    #70
    YorkT
    YorkT New Member
    Boy this is bringing back memories. I was a machinist for 30 years and ran both Mazak CNC mills and lathes. Lost my job when the economy went south in 2008. The thing I miss the most was making anything that I needed at the time.
  11. Mar 2, 2021 at 9:21 PM
    #71
    BB Stacker
    So. Cal
    Just some fooling around I was doing, things to keep me on track when my brain don't work. This was on a piece of MDF with a few coats of Pecan Poly Stain. Still trying to learn optimal feeds and speeds....
  12. Mar 20, 2021 at 3:59 PM
    #72
    jwatt
    jwatt I heart men
    Jack
    Oregon
    Anyone know how to project an array, (drawing), onto a curved surface in inventor? I m trying to extrude-cut the array so that it s normal to the entire surface.
  13. Mar 20, 2021 at 4:19 PM
    #73
    Notarobot
    2013 CM
    I don't use inventor, but is there an option in the project menu to project to surface/plane?
    I found this on the Google web:
    "On the ribbon, click 3D Model tab Sketch panel Create 3D Sketch . On the ribbon, click 3D Sketch tab Draw panel Project to Surface ."
    Edit:
    Would it be easier to extrude THROUGH the surface then do a surface cut?
  14. Mar 20, 2021 at 5:36 PM
    #74
    jwatt
    jwatt I heart men
    Jack
    Oregon
    What I m trying to model is a sub woofer grill. It s basically an array of 6 sided polygons. I can make the part, and I can make the array, but it s behond me how to put the two together, and make it come out right. Here is a pic.
  15. Mar 20, 2021 at 5:44 PM
    #75
    Notarobot
    2013 CM
    I would make the part and use the sketch to do a cut thru-all.
  16. Nov 20, 2022 at 5:00 AM
    #76
    AxelsHumanDad
    AxelsHumanDad Get off my lawn.
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
    I dig my OneFinity :thumbsup:
  17. Feb 11, 2023 at 7:40 PM
    #77
    BB Stacker
    So. Cal
    A retirement gift for a friend. It was a combination of disciplines, woodworking, CNC, and mechanical. Took way more time than I anticipated as the weather would not cooperate with me putting on a finish. Finally gave up and put some Odies Oil on the wood.IMG_5799.jpg
    Notarobot likes this.
  18. Aug 31, 2023 at 4:20 PM
    #78
    Talon2006
    Talon2006 New Member Vendor
    When I was in grad school I became obsessed with the idea of building a cnc plasma table. Shortly after graduating I made one.The wife was not super thrilled at me building this in our one bedroom apartment. It’s funny how the tables have turned though.
    brownmike and ZappBrannigan like this.
  19. Aug 31, 2023 at 7:51 PM
    #79
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Tables have turned huh, I see what you did there.
