CM Rear seat stuck in upright position - Helllp
Discussion in '2.5 Gen Tundras (2014-2021)' started by Sands101, Mar 1, 2020.
  1. Mar 1, 2020 at 8:03 AM
    Sands101
    Sands101 [OP] New Member
    What the heck is going on and how can I fix it?
    The passenger side rear seat is stuck in the up position. The release handle is not loose, but operating it does not release the seat bottom to the lowered position.
    help!
  2. Mar 1, 2020 at 10:29 AM
    AZBoatHauler
    So.Arizona
    Does the handle feel normal? Try pushing the seat towards the rear window while squeezing the handle then see if it will swing down. I’ve had it stuck down when it is squeezing something and releasing the tension has always worked to get the latch released.
    GODZILLA likes this.
  3. Mar 1, 2020 at 12:11 PM
    Sands101
    I did that. I also found what appeared to be a vinyl cable that moved with the handle movement.
    I wiggled the cable, the seat went down, NOW IT won’t go up!
