Clunking noise when coasting to a stop and pressing on accelerator
Discussion in '2.5 Gen Tundras (2014-2021)' started by Andhon, May 17, 2024.
  1. Jun 19, 2024 at 11:15 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  2. Jun 19, 2024 at 11:16 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I don't think it's your U-joints. They look tight from the videos. A better test might be to crawl under it when it's in neutral (chock the wheels so you don't run yourself over) and shove something in the joint to pry it back and forth and see if you can see anything, but from the videos I don't see any (obvious) slop. The backlash looks pretty normal.
    I'd be more inclined to look at the leaf spring hangars and shackle and pry on those and see if there's slop there. Another thing you could try is if you have the rear driveshaft removed, take it for a spin in 4WD so it's effectively a front wheel drive vehicle (in offroading this is called front dig) and see if the noise persists. Though ultimately that would only tell you if the noise is indeed from the rear or not, but if the noise still happens then you know for sure it's not from the rear driveshaft---albeit I suspect you wouldn't hear the noise anyway since there'd be no torque going through the rear end. But you also said it happens when you go from reverse to drive, so if you're pulling the driveshaft to do the U-joints then that's an easy driveway test.
    As for what U-joints, I run Spicer on my buggy. Never touched the Tundra ones, so I'd also lean towards OEM being fine. Toyota U-joints don't often wear out, not to say it doesn't happen.
    reywcms, texasrho83 and Andhon[OP] like this.
  3. Jun 19, 2024 at 11:24 AM
    Andhon
    Andhon [OP] 2014 Platinum MGM CM
    Andy
    2014 Tundra Platinum MGM CM
    Sounds like I have a busy weekend! Thanks for the suggestions, ill let you guys know if I find anything!
    texasrho83 likes this.
  4. Jun 19, 2024 at 11:32 AM
    BiiigTruck
    BiiigTruck New Member
    2016 TRD Off Road Limited
    I was going to suggest carrier bearing, I had a very similar issue in my Tacoma, and replacing that solved it.
  5. Jun 19, 2024 at 11:34 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I have driven in FWD on a solid axle platform but didn't know it could be done in IFS. Very interesting.
  6. Jun 19, 2024 at 11:37 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    This ^^
    Andhon[OP] likes this.
  7. Jun 19, 2024 at 11:51 AM
    snivilous
    SW UT
    Yea shouldn't make any difference. If the driveshaft is pulled the rear transfercase output will spin, but that's it. Up front the differential will behave the same like in a car. On fancy transfercases this is an explicit option to be able to do, so you have RWD, 4WD, and FWD. Truck should be totally fine, and there won't be any binding since the rear end is just free spinning since it's not coupled to the front anymore.
    I would have zero issue driving down the interstate even if needed. It's just like driving in 4Hi except you won't bind up the driveshafts. I guess that's the only thing to be crystal clear about to OP @Andhon is the rear driveshaft must be removed completely since the transfercase will still spin, if you leave it on and just disconnected from the rear axle it'll flop around and destroy everything. But if you remove the driveshaft completely, it may as well be a Camry then.
  8. Jul 10, 2024 at 7:19 PM
    Andhon
    Andy
  9. Jul 11, 2024 at 9:26 AM
    BiiigTruck
    yes. its supposed to be bolted to the frame... :p
    but honestly, I'm not sure if its supposed to have that much lateral play, even un-bolted, my uneducated opinion is that its probably worn, and new one would probably help.
  10. Jul 11, 2024 at 9:38 AM
    bflooks
    bflooks New Member
    Metrowest MA
    This just happened to me, but I was fighting a new sound that I couldn't find for the life of me, until I decided to check every bolt and nut on the chassis. Turns out the knuckleheads at the alignment shop didn't torque down one of my cam nuts. Took it back, the addressed it, been silent every since. Checking every bolt is cheap and easy to do and may help you find something you weren't expecting.
  11. Jul 15, 2024 at 1:27 PM
    Andhon
    Andy
    I went in to grease my slip yolk and come to find out, it was drier than Africa! Put some grease in and reassembled and the clunking noise is non-existent! I guess the dry slip yolk was causing the clunking noise I've been trying to fix:bananadance:
