CLOSED - Spring '21 Coachbuilder Shackle GB/Sale
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by memario1214, Mar 19, 2021.
Thread Status:
Not open for further replies.
  1. Mar 22, 2021 at 10:47 PM
    PRO5
    PRO5 New Member
    2019 Tundra Limited TRD
    In for +2s
    Coachbuilder1 likes this.
  2. Mar 23, 2021 at 3:28 AM
    737fixer
    737fixer New Member
    I see members getting all three sizes available. Could the members please post examples of what they are adding these too.
    - Bilstein set to 1.9"
    - Bilstein set to 2.5"
    - Falcon at different levels
    - What do you have where +3 would be needed?
    Thanks
    cdavi060 and Djone27 like this.
  3. Mar 23, 2021 at 6:01 AM
    I’mYourHuckleberry
    I’mYourHuckleberry New Member
    I am in. I am not quite sure which I am in for, but I am in. ;)
  4. Mar 23, 2021 at 7:17 AM
    memario1214
    memario1214 [OP] Hotshot Offroad Staff Member Vendor
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Got everyone on the list updated!
  5. Mar 23, 2021 at 7:35 AM
    irishpride114
    irishpride114 New Member
    Travis
    2015 SR5 TRD Double Cab
    I am getting the +3’s. I only got about 1" with my current toytec’s (top settings). I also have a camper shell on my truck which puts a constant load on my rear. So I only have about 1/2" of rake with the factory leaf springs (I also have kings all around); and that is before I put anything else in the back. Ie tools/materials, hunting/camping gear etc. So I am adding the +3’s to get a little more rake.
  6. Mar 23, 2021 at 7:48 AM
    sl06
    sl06 New Member
    I'm in for a +2
  7. Mar 23, 2021 at 8:12 AM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    wtf.... I just bought a pair two weeks ago.
    Order#4726 still in the box.
    2013TundraTSS and Coachbuilder1 like this.
  8. Mar 23, 2021 at 10:27 AM
    cdavi060
    cdavi060 New Member
    Virginia Beach, VA
    2017 Super White Tundra Platinum CM
    285/70r18 NITTO RG | Method NV 18x9 | Bilstein 6112 @2.5" w/CB shims, SPC UCA, 5100 & CB +3 Shackles | Entune 3.0 Swap | 2018+ Platinum grille + Pro LED Headlights
    Planning on going with 6112's in front on top setting (2.5ish) plus the CB 1/2" shim on each side to try and reach 3in. Should I go with a 1" or 2" CB rear shackle to match the front?
  9. Mar 23, 2021 at 10:39 AM
    irishpride114
    Travis
    If you get the 3" up front; that means you will be low in the rear by an inch. As the trucks are 2" high in the rear stock.
  10. Mar 23, 2021 at 10:43 AM
    cdavi060
    cdavi060 New Member
    Virginia Beach, VA
    So you are suggesting the 1" CB shackle then?
  11. Mar 23, 2021 at 11:10 AM
    irishpride114
    Travis
    I’m not really suggesting any. Just letting you know what the rough outcome will be before you add shackles. As I don’t know what your wanting for the outcome or what you do with your truck.
    He doesn’t have 1" or 2" shackles. His +1 shackles are only 0.625 of lift. +2 are 1.25". +3 are 1.75" of lift.
    if you can give more information. We can probably help you get squared away.
  12. Mar 23, 2021 at 11:42 AM
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    Do 2 shims L one shim right with +3
    Should give u about 1” forward rake.
  13. Mar 24, 2021 at 6:53 AM
    cdavi060
    cdavi060 New Member
    Virginia Beach, VA
    In for +3
  14. Mar 24, 2021 at 6:20 PM
    R0CKETMAN
    NGAMTNS
    In for +0
    yo @Coachbuilder1
    Got tons of your stuff on both Tundras. Need +0 please/tnx
  15. Mar 25, 2021 at 9:15 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    In but talking directly with David as I am up north in Canada.
  16. Mar 25, 2021 at 9:33 AM
    woodlandFF
    woodlandFF New Member
    2019 SR5 Cement Tundra CrewMax 4x4
    Black Rhino 20s
    In for a +3! Thank you
  17. Mar 25, 2021 at 11:20 AM
    HONEYBADGER
    HONEYBADGER New Member
    Fox Coils Camburk Kinetik Uppers Stealth Customs Cooper AT3
    Im in for a +1
  18. Mar 25, 2021 at 2:47 PM
    Zed
    Zed New Member
    Houston Texas
    2017 Brown 1794 Tundra
    in for +1
  19. Mar 25, 2021 at 4:31 PM
    #49
    Cox3497
    Cox3497 New Member
    Toyota Tundra Crewmax
    In for +2 or +3, still undecided on exact height.
  20. Mar 26, 2021 at 7:28 AM
    #50
    RogueAngler
    RogueAngler New Member
    @NESURFPRO
    2021 MGM TRD Pro DC
    Tint (3M) to VA limits TRD rear sway bar AJT Design chrome delete; all black TRD shifter Coachbuilder trd pro kit with Bora spacers Toyo OC AT3s CBI overland rock sliders Ordered: UpTop overland Alpha roof rack with Baha lights Considering: RSi SmartCap
    In case helpful to anyone following, here are pics of my 2021 MGM DC with recently installed CB trd pro kit and 295/70 (34") Toyo Open Country AT3. Exactly as advertised, got 2" on front and 2.75" in rear (including 1" gain from increased tire diameter). Absolutely love the height and stance. At 5'8" myself, must admit that can't wait for my running boards to come in!
    David collaborated with my top notch installer (David Off Road for any of you in Richmond, VA area) and I couldn't be happier with outcome. Ride is sweet, as is look, IMHO.
  21. Mar 26, 2021 at 7:32 AM
    #51
    cdavi060
    cdavi060 New Member
    Virginia Beach, VA
    Looks good man! Love Davis Off-Road! What part of VA are you in specifically? I grew up in Chesterfield/Matoaca area. Now in Virginia Beach.
  22. Mar 26, 2021 at 8:09 AM
    #52
    Bama
    Bama Member
    2016 MGM Tundra 2015 MGM Sequoia 2014 LX
    Looks perfect! The exact look I'm going for, just not a Pro. What spacers are you using?
  23. Mar 26, 2021 at 8:19 AM
    #53
    RogueAngler
    @NESURFPRO
    2021 MGM TRD Pro DC
    I'm in Midlothian, VA but surf fish coast of DE to MA.
    On the spacers question, Bora 1.25" which is specifically what David at CB recommends in tandem with his kit.
    Here is pic of CB shackles vs. the factory units removed. Sorry don't have side by side but definitely man vs. boy scenario.
  24. Mar 26, 2021 at 12:50 PM
    #54
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    David
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    Yes, with the OE wheels being a +60 mm offset you will need to use our BORA 1.25" wheel spacer kit.
  25. Mar 26, 2021 at 12:57 PM
    #55
    Coachbuilder1
    David
    Salt Lake City UT
    With the 6112's on the top setting I would ddef recommend using 2 shims driver and 1 shim passenger to get you to 3.00" as well as driver side lean correction. We also need to take into consideration your 38 gal fuel tank and would recommend using our +3"s in order to have just a touch of rear rake. This way your truck will visually look level but will measure about 1.00" taller in the rear. Hope this helps. If you'd like ot go over in better detail fee free to call in . 801.635.4872
  26. Mar 26, 2021 at 1:00 PM
    #56
    Coachbuilder1
    David
    Salt Lake City UT
    We have listed a few helpful methods for sizing on the website. Let me know if you need any of info. thanks!
    How Do I know what Size To Order?
    We have a few great tips we use in order to size shackles correctly...
    1. Park on a flat level surface, Using your tape measure pull a measurement from the Center of the Front and Rear wheel openings down to the ground or top of tires. "Write these measurement's down"
    2. Using your floor jack raise the rear of the truck by jacking up on the trucks tow hitch until you're happy with the stance or at least .750" - 1.00" higher in the rear than the front.
    3. Take a second measurement and compare the difference in the two. The difference in the two measurements will tell you exactly how much lift you need to add.
    memario1214[OP] likes this.
  27. Mar 26, 2021 at 1:02 PM
    #57
    Coachbuilder1
    David
    Salt Lake City UT
    We're happy to ship to CAN, be sure to get in on the GB and when ordering from the website you'll have a international shipping option. thanks!
  28. Mar 26, 2021 at 1:05 PM
    #58
    Coachbuilder1
    David
    Salt Lake City UT
    100% spot on!
    cdavi060 likes this.
  29. Mar 26, 2021 at 2:02 PM
    #59
    R0CKETMAN
    NGAMTNS
    Damn skippy sensei
    Ps I need a set of +0 please Tnx
  30. Mar 26, 2021 at 3:34 PM
    #60
    woodlandFF
    Black Rhino 20s
    He’s here! Actually, if I decide to go 5” zone or 7” BDS, what should I get?
Thread Status:
