CLOSED - Coachbuilder Shackles Group Buy #2
Discussion in 'Deals & Group Buys' started by Coachbuilder1, Nov 19, 2018.
Thread Status:
Not open for further replies.
  1. Mar 3, 2021 at 3:37 AM
    #1201
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    Had it on my Pro for 4years and can’t tell the difference from my other Tundras.
    Vang530, Rica25 and BTBAKER like this.
  2. Mar 3, 2021 at 5:19 AM
    #1202
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I will have to agree with this. I’ve had the kit for a couple years and I have seen no noticeable difference.
    Rica25 likes this.
  3. Mar 3, 2021 at 7:06 AM
    #1203
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
  4. Mar 3, 2021 at 7:07 AM
    #1204
    memario1214
    Colton
    Missoula, MT
    Wonder if there's no difference unless you're pounding on it or really lifted? :notsure:
    BTBAKER[QUOTED] likes this.
  5. Mar 3, 2021 at 7:36 AM
    #1205
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Very possible because I’m not doing either of those.
  6. Mar 3, 2021 at 8:46 AM
    #1206
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    I’m new to this. Still waiting on my tundra Pro to come in. I had lifted stuff on my Tacoma and 4Runner Pro. Are most guys going with the +2 on the tundra Pro? But you don’t touch the front correct. Only the rear?
  7. Mar 3, 2021 at 10:38 AM
    #1207
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    That sounds like you would have a 2 inch rake going that direction since that PRO is already leveled.
  8. Mar 3, 2021 at 11:55 AM
    #1208
    RusPro21
    Don
    Pa.
    Not sure Brad, I thought I read up on if you go the +2 it gives you 1.5 in the rear. Watching a you tube video also.
    BTBAKER likes this.
  9. Mar 3, 2021 at 3:01 PM
    #1209
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Well, then you’ll have a rake of 1.5 inches. Either way, it would ruin the look of that PRO if thats the case.
  10. Mar 3, 2021 at 3:22 PM
    #1210
    RusPro21
    Don
    Pa.
    Yeah I agree. I’m not touching the suspension. Unless I do the westcott. But probably leave be.
    BTBAKER likes this.
  11. Mar 3, 2021 at 6:20 PM
    #1211
    R0CKETMAN
    NGAMTNS
    Dunno
    I’ve got Two shims each side and +3 in rear on my Pro
  12. Mar 3, 2021 at 6:39 PM
    #1212
    marcelo73
    marcelo73 New Member
    So Cal
    2016 Toyota Tundra Crewmax TRD PRO QUICKSAND
    295/70 18 Coopers
    I may be interested as well.
  13. Mar 4, 2021 at 5:47 AM
    #1213
    Myke Juliet
    Myke Juliet New Member
    2016 TRD PRO
    Interested, along with the TRD kit, bumper shim, wheel spacer, steering kit.
  14. Mar 4, 2021 at 6:16 AM
    #1214
    R0CKETMAN
    NGAMTNS
    Pro “already leveled”??
  15. Mar 4, 2021 at 6:28 AM
    #1215
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Not sure I get your post?
  16. Mar 4, 2021 at 6:42 AM
    #1216
    R0CKETMAN
    NGAMTNS
    Sorry I quoted wrong post. Are you saying Pro’s come leveled?
  17. Mar 4, 2021 at 7:52 AM
    #1217
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Yes. Already leveled from the factory. If you raise the back end only you're going to reintroduce a rake.
  18. Mar 4, 2021 at 8:13 AM
    #1218
    RusPro21
    Don
    Pa.
    I questioned about some guys are adding the shackles to the just the rear of the Pro. I read up where guys are doing it to stiffen up the rear and it also does lift the rear which it makes it look like most trucks that come thru factory. I think the tundra pro looks great write from factory.
  19. Mar 4, 2021 at 12:02 PM
    #1219
    hammockking
    hammockking New Member
    Scotts Valley, Ca
    2012 Tundra Platinum 4x4
    Workin' on em
  20. Mar 4, 2021 at 12:59 PM
    #1220
    memario1214
    Colton
    Missoula, MT
  21. Mar 4, 2021 at 2:31 PM
    #1221
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    any pics ?
  22. Mar 4, 2021 at 5:57 PM
    #1222
    R0CKETMAN
    NGAMTNS
    My Pro had about .75” positive rake which corresponds to the necessary rake needed for the traction control to function properly.
  23. Mar 4, 2021 at 6:00 PM
    #1223
    R0CKETMAN
    NGAMTNS
    Nothing that really shows stance but here’s one
  24. Mar 4, 2021 at 6:15 PM
    #1224
    AZTundra
    Paul
    Phoenix, AZ
    For anyone considering jumping in on this group buy. Here's a picture of mine with the trd pro suspension, 2 coachbuilder shims on each side and the +3 shackles on the rear. No regrets. Top notch quailty parts. Tires are 295/70/18 Cooper AT3 XLT's.
    Tundrastruck91, Jmor6766 and saybng like this.
  25. Mar 4, 2021 at 6:37 PM
    #1225
    TFTundra
    TFTundra New Member
    Dude. I was like, let me check this man’s IG for some better pics of the tundra. No go on the truck pictures, but you have some hilarious videos.
    R0CKETMAN[QUOTED] likes this.
  26. Mar 5, 2021 at 1:53 AM
    #1226
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
  27. Mar 5, 2021 at 7:23 AM
    #1227
    RaptorBronco
    RaptorBronco New Member
    Drew
    2015 Platinum
    Wheels/Tires and a B.S. "lift" as of 3/5/21. More to come because I can't not F with nice things
    I am in for a set of +3"
  28. Mar 6, 2021 at 5:31 AM
    #1228
    ackthresher
    ackthresher New Member
    Jamie
    2017 cement crew max tundra pro
    Is there still a group buy discount going on?
  29. Mar 6, 2021 at 1:19 PM
    #1229
    irishpride114
    irishpride114 New Member
    Travis
    2015 SR5 TRD Double Cab
    Read a couple three posts above yours
  30. Mar 7, 2021 at 6:28 AM
    #1230
    ackthresher
    Jamie
Thread Status:
