CLOSED - Coachbuilder Shackles Group Buy #2
Discussion in 'Deals & Group Buys' started by Coachbuilder1, Nov 19, 2018.
Thread Status:
Not open for further replies.
  1. Apr 22, 2019 at 2:21 PM
    #451
    Coachbuilder1
    Coachbuilder1 [OP] Industry Leader Vendor
    David
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    *** Please only torque to 70 ft lbs,
    Our First design back in 2009 required a higher torque spec and have gone down to 70 Ft Lbs after updating to our fully machined Coachbuilder shackle. Let me know if you have any questions or need a hand with anything else.
    David
    Ekstrom Design.
    801-635-4872
    Rica25 and 15whtrd[QUOTED] like this.
  2. Apr 22, 2019 at 3:56 PM
    #452
    15whtrd
    15whtrd Mr. Blonde
    Ok thanks! I split the difference and went 80 ft lbs before you posted. I should probably loosen and re-torque to 70?
    Btw these things are badass! I immediately felt the difference. If feels much smoother. I have stock pro suspension no shims or anything. It’s like the rear matches the front now as far as feeling goes. Much more plush.
    If someone wants to upgrade their stock suspension ride, I suggest they go with +1s and one shim on each side in the front. It would pretty much be stock but would feel so much better.
    Funny when I loosened the rear stock shackles up. I heard a pop because they were in a bind from those strange stock bushing serrations.
    The only problem I have now is at full droop my leaves contact the edge of the sway bar. Looks like I’m going to need some extended links.
    And no everybody, I’m not going to remove my rear sway bar. I like it too much!
  3. Apr 29, 2019 at 9:26 PM
    #453
    EBenke
    EBenke I’m Ready To Go!
    Everett
    2007 Toyota Tundra DC, 5.7, 4x4
    3/2 lift, Icons, 35's, 3" CB's shackles
    Hi Coach, EBenke here. I bought shackles back in 2012, (Tundra Talk), they are holding up beautifully. At the time you weren’t offering the dropped carrier bearing with the 2” shackles or the grease fittings on my bolts. Are these items I should think about adding? I do four wheel a bit.
    I’m considering going a bit higher in the rear.
    Great product for sure
  4. Apr 30, 2019 at 9:04 AM
    #454
    Coachbuilder1
    David
    Salt Lake City UT
    Awesome!!! glad to hear they are doing the job :)
    If you have a few mins feel free to give me a quick call and we'll go over it. 801.635.4872
  5. Apr 30, 2019 at 9:09 AM
    #455
    Coachbuilder1
    David
    Salt Lake City UT
    Its def worth backing off on your torque a touch, This will allow a smoother feel as your leafs cycle. Im happy to hear your keeping the rear sway bar, the sway bar and shackles really compliment each other and share the stress.
    15whtrd Thanks for posting!
    15whtrd[QUOTED] likes this.
  6. Apr 30, 2019 at 9:54 AM
    #456
    15whtrd
    15whtrd Mr. Blonde
    I did go back in and loosen then re-torque to 70 ft lbs. I went out this last weekend with the new shackles. The highway ride on the way there was noticeably better. Out on the trail it was much more smooth than it ever was. Highly recommend this set up to everyone. I think any system would benefit from a coach builder shackle with poly bushings.
    Did I mention they are dead sexy!
  7. May 1, 2019 at 8:02 PM
    #457
    Travo60
    Travo60 New Member
    Travis
    Austin, TX
    2018 Limited CM Cement
    Any one have pictures to share of 6112 with shims and the shackles?
    Rica25 likes this.
  8. May 1, 2019 at 8:16 PM
    #458
    Rica25
    Ricardo
    Tulare
    What questions u got bro?
  9. May 1, 2019 at 8:28 PM
    #459
    15whtrd
    15whtrd Mr. Blonde
    Thanks man, I got it all sorted. Coachbuilder contacted me. The original CB shackles torque to 90, the current design 70 ft lbs. I got it all installed now and it’s awesome. Really enjoying them!
  10. May 1, 2019 at 9:05 PM
    #460
    Rica25
    Ricardo
    Tulare
    Yup I have same ones now for about 6 months and much better ride now
  11. May 1, 2019 at 10:59 PM
    #461
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Do you recommend installing the carrier bearing drop with +3s? Even if there’s no vibrations?
    Coachbuilder1[OP] and Rica25 like this.
  12. May 13, 2019 at 12:35 PM
    #462
    Coachbuilder1
    David
    Salt Lake City UT
    Yes, As you drive and the pinion angle constantly changes the CB drop kit will position the driveline in the sweet spot and have more range in either direction. install it :)
    Rica25, 15whtrd and Sephon like this.
  13. May 13, 2019 at 12:45 PM
    #463
    Coachbuilder1
    David
    Salt Lake City UT
    This setup is with out a doubt our most popular. What setting are you thinking up front and will post up pics. Usually if we set the 6112s on the 3rd click (1.9") we use 2 shims driver side and 1 on the passenger side and then use a set of our +2"s. This ends up sitting at about 2.5" up front and 1.25" in the rear. If you prefer 3" up front you'll want to set them up on the top setting (4th click 2.5") using the same shim setup and then a set of +3"s in the rear. This will sit at 3" up front and 1.75" in the rear.
    Travo60[QUOTED] and Krewcial like this.
  14. May 13, 2019 at 2:00 PM
    #464
    Grendel
    Grendel New Member
    2016 Quicksand TRD PRO
    OK. I know this is wrong thread to post in but I'll ask anyway since I have been meaning to call and ask. Coachbuilder. I have a 2016 pro with ALCAN springs with 2 inches of lift. I am looking at leveling the front. I'm assuming I should purchase your PRO shim kit with bumps stops, is this correct. and should I buy your carrier bearing drop for the 2 inch lift? I have not purchased shackles.
    Coachbuilder1[OP] likes this.
  15. May 13, 2019 at 2:30 PM
    #465
    Coachbuilder1
    David
    Salt Lake City UT
    No Problem at all, With 2" in the rear Its worth adding our small CB drop kit, Steering kit and Shim kit up front. This way you're addressing everything front to rear and the truck will sit and drive nice and balanced. We have setup some specific alignment specs for this application please jot them down and ask your alignment shop to use them https://shopcoachbuilder.com/collections/frontpage/products/coachbuilder-trd-pro-kit-2015
    https://shopcoachbuilder.com/products/trd-pro-shim-kit-w-bump-stop-extensions-provides-1-00-of-lift
    https://shopcoachbuilder.com/products/coachbuilder-oe-replacement-steering-kit
    https://shopcoachbuilder.com/products/coachbuilder-carrier-bearing-drop-kit-rear-lift-0-2
    Give me a heads up if you need any other info :)
    mtndds98 likes this.
  16. May 13, 2019 at 3:22 PM
    #466
    RW-3
    RW-3 May the Mods be with you
    Rob
    16 Black TRD CM 4x4
    Lights: 2018 OEM Black Chrome LED’s Morimoto XB Fogs Interior LED upgrade - VLED’s LED reverse / cargo - VLED’s Footwell lights, vanity lights, break lights, rear turn signals, 3rd break light - All VLED’s 30” Rough Country light bar hidden in bumper w/ Rago Fab Brackets Matt Gecko LED bed lights (red & white) and hood lights Exterior: Truxedo Lo Pro QT WeatherTech in-channel window deflectors Interior: Husky X-Act Contour front & rear Front, back and rear windows all tinted 10% Ceramic Heat Film on Windshield 70% OCD console organizer OCD console tray TRD 4x4 inserts on Husky mats by Achuop Tacoma TRD Pro shift knob with TRD leather boot AJT Design vent ring trim - chrome delete Center console wireless charger Drivers side grab handle Performance: Dirty Deeds BA Muffler 12” Budget Standard System TRD Rear Sway Bar AFE Pro Dry S Air Filter Bilstein 6112 1.9” clip Bilstein 5100 - rear Coachbuilder +1’s Nitto Ridge Grapplers 285/70/18 Audio: Infinity dash speakers Tech12Volts custom center dash speaker Hertz Uno door speakers JL Audio RD 900/5 amp 2 JL Audio 10w-0 v3 10” subs in custom Tech12Volts box Protection: McGuard Tailgate Anti theft lock OEM tailgate lock w/ Dynamat TRD Pro skid plate SNS ARB sensor guards Misc: TRD key fob case AJT Designs Rear diff breather mod Fortin remote start with Car Link CL6 TRD battery bracket by Coupe TRD valve stem caps TRD interior handle inserts by abomb60 (Adam)
    Hey @Coachbuilder1
    I’ve got the 6112’s @ the 1.9 setting, 5100 for rear, CB +1’s and 1 CB shim for drivers side sitting in the garage to be installed May 28th. Going to add 285/70/18 Nitto Ridge to complete the package. I’ve heard the 5100 can be adjusted 0-1”, is that true? I’m worried I’m going to want more rake but if the 5100 can give me .5” I will be ok. Should I have gone with your +2’s? Thanks for all your input here!
  17. May 13, 2019 at 3:39 PM
    #467
    Coachbuilder1
    David
    Salt Lake City UT
    With 1.9" up front and our +1"s out back you'll have about 1.00" of rear rake. The rear 5100's won't provide any additional lift just dampening control. This is a great stance and would be exactly what I'd recommend. Post up a few pics after your install. Excited to see it come together for you.
    RW-3[QUOTED] likes this.
  18. May 13, 2019 at 3:42 PM
    #468
    RW-3
    Rob
    16 Black TRD CM 4x4
    Thanks for the confirmation! Exactly what I was hoping you’d say. This is the first time doing a lift/level and getting a little nervous of the outcome. Appreciate the quick reply!!
  19. May 13, 2019 at 3:44 PM
    #469
    Doylfish
    Doylfish New Member
    2016 Tundra 1794 Crewmax
    @Coachbuilder1
    I seem to recall a thread asking if anyone was interested in a list of local shops familiar with install of your product, did this ever come together?
  20. May 13, 2019 at 4:14 PM
    #470
    Coachbuilder1
    David
    Salt Lake City UT
    Glad you asked, Yes.. We've started a state by state list on our FB page and will be adding to the website soon too. Most States we've worked with your Local Toyota Dealerships but have some very specialized shops from coast to coast we've been able to setup as well. Even if you're on any of the HI islands we have you covered.
    Doylfish[QUOTED] likes this.
  21. May 13, 2019 at 4:28 PM
    #471
    Blueknights75
    Ron
    Clayton, NC
    Rica25 and Faht Nocker like this.
  22. May 13, 2019 at 6:26 PM
    #472
    Travo60
    Travo60 New Member
    Travis
    Austin, TX
    I will most likely go top setting with only one shim to even out the lean on driver side, any pictures would be much appreciated leveled or slight rake
  23. May 13, 2019 at 7:02 PM
    #473
    Doylfish
    Doylfish New Member
    Anything in the 02771 area? Closest I’ve seen in the posts is PA and NJ
  24. May 15, 2019 at 9:46 AM
    #474
    SK_Tundra
    SK_Tundra New Member
    Stockton Ca
    2015 Tundra Mall Rated
    Any chance for another group buy? Interested in +2 shackles and shims for the front.
  25. May 15, 2019 at 9:59 AM
    #475
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    So do the +2 shackles require CB drop?
  26. May 15, 2019 at 10:44 AM
    #476
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
    it comes with it the order. I had it installed. I think people install them to make sure there is no vibration.
  27. May 15, 2019 at 10:52 AM
    #477
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    24 limited hybrid offroad
    Just put in an order for the +1 shackles. I have 6112 at 1.3inches and 5100's in the back. Do I need anything else with the +1? poly bushings, CB drop kit? How about the rake?
  28. May 15, 2019 at 10:55 AM
    #478
    Faht Nocker
    Woody
    Milky Way
    Poly bushings come with the order. I do not believe that you need a cb drop with the +1, and I don't think that @Coachbuilder1 has them in the +1 kit.
  29. May 15, 2019 at 1:39 PM
    #479
    Coachbuilder1
    David
    Salt Lake City UT
    Yes, we include the CB drop kit in with your shackles. ( +2''s and +3"s )
    Omohundro[QUOTED] likes this.
  30. May 15, 2019 at 1:41 PM
    #480
    Coachbuilder1
    David
    Salt Lake City UT
    Awesome,Thank you!
    Your shackle kit will include everything needed for a perfect install. With 1.3" up front you will still have a bit of rear rake.
Thread Status:
