Climate control question
Discussion in '2.5 Gen Tundras (2014-2021)' started by Trevman2, Feb 12, 2018.
  1. Feb 12, 2018 at 6:30 PM
    Trevman2
    Trevman2 [OP] New Member
    I've got a 2015 Platinum and when I put the climate control air source switch to the floor, barely any air comes out from the floor vents even with the fan on it's highest setting. The air also still blows out from the dash vents and it seems like it is blowing harder through those vents than the floor vents. Is this normal? I've only had this truck since Thanksgiving and it's been bugging me lately. Usually, the vehicles I have owned make my feet nice and toasty when I put it on floor vents.
  2. Feb 12, 2018 at 8:05 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    Not sure how the diverter works on these trucks, but I used to have a Jeep that did this and it was caused by a vacuum leak under the hood. Sounds to me like the diverter door isn't working correctly.
    Wvmoonshiner likes this.
  3. Feb 13, 2018 at 4:32 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    I am pretty sure that everything is controlled by small electric actuators like on most other newer vehicles. The actuators receive the signal from the BCM aa you change settings on the HVAC panel. You may have to take it to the dealer and it maybe something as simple as a software fix.
    Probably not what you wanted to hear but there just isn't that much anymore we can do because of all the electronics involved.
  4. Feb 13, 2018 at 6:37 AM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    Mine does the same thing. Barely any air comes out at the feet.
    Seems like defrost/windshield + feet combo setting works best for me. Still not great though.
    Either we have the same issue, or it’s normal.
  5. Feb 13, 2018 at 6:56 AM
    MacCTD
    MacCTD New Member
    2010 CM 4x4
    5100s
    Same here on my '10 thought it was the blower motor so I ordered a new OEM unit and replaced it, made no difference..., the HVAC on these trucks is not very good, takes forever to blow hot air in the winter and the AC is marginal in the summer.
  6. Feb 13, 2018 at 7:04 AM
    boostedtrdpro
    Jeremy
    When you guys turn it on feet or any setting but defrost, try pushing the recirculate button and see if it helps.
  7. Feb 13, 2018 at 1:15 PM
    Trevman2
    Thanks for the inputs. Sounds like it may be normal but I've got a mechanic buddy at the Toyota dealer and I will see what he says. Ill update the post once I get to the final outcome...
    Y0TA PR0 likes this.
  8. Feb 20, 2018 at 1:06 PM
    Mo_Martz
    Mo_Martz New Member
    Great Country of Texas
    2017 White Tundra CM
    I have the issue of air bleeding through the dash vents when I switch it to the floor. I also get bleed by when I have it off. Sometimes it seems like it's on the low setting even when off.
    I spoke to the service manager at my dealership and he said that it would take an entire day if they needed to change out the system because they have to remove the entire dash. He also said that it may be as easy as just adjusting the diverter doors because they occasionally get out of sequence or are a tad off. It can get annoying though especially if it's cold outside.
  9. Feb 20, 2018 at 3:26 PM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    15 Platinum here also. Same thing. The climate control system in the Tundra is a bit of a POS. The vents are always bleeding air no matter which setting you have it on. It drys out your contacts if you ware them. It has bugged me since the day I purchased the truck. You just learn to live with it.
  10. Feb 20, 2018 at 6:59 PM
    Trevman2
    That's what I expected to hear. I dont want to take it in since it is out of warranty to have them feed me a line of crap to take it apart and look at it and not fix it and charge me an arm and a leg for standard ops.
  11. Feb 20, 2018 at 7:06 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Mine does same thing. But when I put it in defrost it blows pretty good, but still leaks form vents a little, I usually have it defrost and feet and keeps me warm that’s all I care lol.
  12. Feb 20, 2018 at 7:07 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Look on the bright side we have the best colour. :D
    Trevman2[QUOTED][OP] and 71_340 like this.
  13. Feb 21, 2018 at 4:41 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    My 2018 does the same (dual zone auto HVAC) but it really doesn't bother me much as long as it gets warm and it does. Reading post #8 suggests that the BCM which controls the HVAC can be updated/adjusted via software, my Ram was certainly like that and on a 2001 Grand Cherokee I could access the controller myself by pushing a series of buttons in a certain sequence which would redo the calibration of the blend doors.
    I am taking my truck in for the first service on Friday and will ask the service writer about it.
    On a side note to @SR5TRDTUNDR you are incorrect because I have the best color.
  14. Feb 21, 2018 at 6:12 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    When it gets fixed......
  15. Feb 21, 2018 at 8:07 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    https://www.tundras.com/threads/why-doesnt-the-air-turn-off.13886/
    There some related stuff here.
  16. Feb 21, 2018 at 8:28 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    2010 here, I have found the HVAC air output fairly pathetic as well. Glad to see it's just by design and not a problem. My controls all work, switching the air flow from each designated setting. It just seems like unless you have the fan speed cranked to max you barely get a breeze.
    I guess toyota must have something figured out though because I find that the truck still cools off very quick, this is in a hot/humid coastal NC climate.
  17. Feb 21, 2018 at 8:33 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    I haven't had a chance yet to try the A/C since it is cold in Missouri. I do think that the heat works well, like I said I always leave mine on AUTO and 72 degrees both zones.
    Toyotoholic likes this.
  18. Feb 21, 2018 at 9:39 AM
    jstrenn
    jstrenn New Member
    2017 Toyota Tundra Double Cab 4X4 TRD Off Road
    I don’t have the dual zone HVAC, but I live in Phoenix Arizona and my A/C is very cold and cools the truck down quickly.
  19. Feb 21, 2018 at 10:03 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    That's good to know. Our winter are cold as hell and summer is hot and humid.
  20. Feb 21, 2018 at 7:11 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    I agree that AUTO is the way to go... It tends to put the fan on higher than when I would set it manually.
