clicking when in 4wheel after leveling kit
Discussion in 'Suspension' started by BigGuy31, Mar 25, 2016.
  1. Mar 25, 2016 at 1:01 AM
    BigGuy31
    BigGuy31 [OP] New Member
    2017 tundra trd pro
    I installed a leveling kit and when I am in 4 wheel drive I notice a clicking noise going from the front when I am turning but not a hard turn either. but I don't notice it when going staight any suggestions?
  2. Mar 25, 2016 at 4:07 AM
    ColoradoTJ AMSOIL Snob Staff Member
    Ford F-350, Roush Mustang, Jeep Crawler
    I want to say it is a half shaft going bad, but you have a 2014 truck with most likely under 100k miles.
    One thing I have done in the past is:
    -get the front two wheels off the ground. Chock the rear wheels, parking brake on.
    -turn steering wheel until it stops (left or right) and pull key to lock steers wheel.
    -spin front tires by hand to locate noise.
    This might help you find any binding up that might be going on. Hope that helps.
  3. Mar 25, 2016 at 4:48 AM
    BigGuy31
    2017 tundra trd pro
  4. Mar 25, 2016 at 4:49 AM
    BigGuy31
    2017 tundra trd pro
    you thinking the cv shaft is bad and needs replaced.
  5. Mar 25, 2016 at 4:56 AM
    Could be, would be surprised though
  6. Mar 25, 2016 at 9:06 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    What kind of ground are you on?
  7. Mar 25, 2016 at 9:07 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    First thing that comes to mind for me is a cv joint. If the joint was pulled out a bit and not set back correctly it could cause the clicking.
    This is what happened to my Tacoma. Drove with it that way for a little bit until the entire bearing blew out when i put load on it in 4X4 in sand.
    ColoradoTJ likes this.
  8. Mar 25, 2016 at 11:00 AM
    BigGuy31
    2017 tundra trd pro
    see that what I am thinking I had issue when doing that side with the cv popped out and I thought I had everything in correctly. until I used 4 wheel. under 2 wheel conditions you have no issue it's when you are only in 4wheel or under a load ... I'm hoping that's all it is really dont do anything else with that leveling kit..
