Clicking Noise from IBC box in cab
Discussion in 'Towing & Hauling' started by Coffee2go, Nov 12, 2020.
  1. Nov 12, 2020 at 9:51 AM
    Coffee2go
    Coffee2go [OP] New Member
    2017 Tundra Platinum
    When I plug in a trailer to my 2017 Tundra, I get a clicking noise coming from the IBC. It is about the cadence of hazard lights. It only does it when the truck is turned off. Once I insert the key and turn it to the "ON" position, it stops. It does not do it with the truck running. The IBC appears to work as it should when I use it to tow. Any ideas on how to fix this? I saw a similar thread but there were no responses.
  2. Jul 16, 2022 at 10:17 AM
    Opa1953
    Opa1953 New Member
    2016 Tundra CrewCab
    Tow package
    Noted this post and wanted to report that I have the exact symptoms in my 2016 with tow package. Did not note until our last trip towing trailer. Wonder where I should start to investigate
  3. Jul 16, 2022 at 12:10 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    The clicking is the brake controller testing for a brake magnet load on the circuit. If it senses the brake magnets it knows a trailer is connected and there are brakes it can activate. The noise is the magnets in the assemblies momentarily touching the drum of the hub as they activate slightly.
    No idea why it would make any noise with truck off vs on/running.
  4. Jul 16, 2022 at 3:03 PM
    Opa1953
    Opa1953 New Member
    2016 Tundra CrewCab
    Tow package
    Thanks and interesting. Clearly not there when truck is running. I need to see if there is a noise at the brake drums on trailer. The rhythmic ticking is coming from under the steering column near the controller as best I can tell. The controller seems to operate the same otherwise.
  5. Jul 16, 2022 at 3:40 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Sounds like a short somewhere in the trailer brake harness.
  6. Oct 24, 2022 at 2:44 PM
    Japurd04
    Japurd04 New Member
    Russ
    2017 tundra
    Did you ever find the fix or problem that was causing this? My 2017 Toyota just started doing this also. Exactly the same, plug the trailer in, clicking noise at brake controller box in the truck, turn on the truck, goes away and trailer brakes function correctly.
    Thanks
    Russ
