Clicking/clacking sound Please help
Discussion in '2nd Gen Tundras (2007-2013)' started by M1khale, Apr 11, 2017.
  1. Apr 11, 2017 at 10:51 PM
    M1khale
    M1khale [OP] New Member
    2008 Desert Sand Mica Crewmax TRD 4x4
    Custom Black Headlights / Taillights Amp Research Automatic Steps Transfer Flow 50 Gallon Tank Pro Comp Leveling Kit Slotted/Drilled Disk Brakes
    hey guys new to the forum...
    I have researched for weeks trying to solve and issue with my Tundra.
    I have a intermittent sound coming from under the Tundra that is getting more frequent and louder.
    At first it was once in a great while and always while deceleration never when turning, accelerating, going over bumps.
    I've taken it in to have an inspection of my steering components and undercarriage, no loose bolts, nothing of that sort.
    Basically here the issue.
    Whenever I am letting off the gas pedal I hear a loud clicking/clacking sound it's not constant, sometimes one click sometimes it's 20, it sounds metal on metal, it sounds like a cv joint going out but only does this when going straight and only when slowing down.
    I had them inspect everything and they couldn't find anything at all except my carrier bearing is a little loose.
    $500 repair later still makes the sound, so that wasn't it.
    I'm stumped so if anyone has any ideas that would greatly be appreciated.
    Last guy who looked at it said maybe torque converter or pressure plate.
    Idk if that's a solution or just a crazy guess, my truck runs fine shift fine had tons of power for 140k miles.
    For the basic info,
    2008 Tundra Crew Max 4x4
    Has leveling kit on front 2" not causing the issue they were installed at 5k miles.
  2. Apr 11, 2017 at 11:14 PM
    M1khale
    Thanks but not my issue, this thread is for a noise coming out of the dash my noise is under the truck and loud like metal on metal not a tick inside the truck it's definitely under and loud like a cv joint clicks when it's going out in a turn only this isn't when I'm turning but whenever I slow down
  3. Apr 11, 2017 at 11:41 PM
    M1khale
    Only when pulling off accelerator
    CV joints and Bearings are perfect not causing the issue had that checked out today
  4. Apr 12, 2017 at 12:01 AM
    M1khale
    It's not injectors that would be engine this feels like it's solid part of the suspension not engine at all its like a cv joint sound if you've ever heard that loud and annoying but definitely not injectors that would be noticeable compared to this I can take a video of it tomorrow for reference
  5. Apr 12, 2017 at 12:38 AM
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
    Way back when I was a kid I heard of cases that the internal parts of the muffler or catalyst came loose and rattled around.
    GNTundra likes this.
  6. Apr 12, 2017 at 7:22 AM
    Any sound clips?
  7. Apr 12, 2017 at 10:25 PM
    tangent
    tangent New Member
    2007 Timberland Mica double cab 5.7 TRD
    Auburn pro limited slip, Leer 100XL cap, backup cam
    I just bought an 07 Tundra 5.7, 144k miles and I think I had the same noise. It was a tapping noise from the rear, sometimes a single tap, sometimes a series of taps. Sounded like metal on metal, not very loud. It happened at the wheel rotation frequency, only when feathering the throttle, between 30-60 mph. Took it a couple miles in the cold to start doing it. Turns out it was the differential, the cross pin had somehow loosened and would slap around when the drive train was slack. I took the opportunity to put in an Auburn Pro limited slip and change the axle bearings. It drives perfectly now, quiet and the limited slip is awesome.
  8. Apr 12, 2017 at 10:31 PM
    Try finding a buddy with a gopro or try strap your phone or old extra phone n vid it i say its cv joints
  9. Apr 12, 2017 at 10:47 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Seatbelt in the cabin? No joke I heard rattling and the belt was twisted and hitting the panel
  10. Apr 14, 2017 at 3:20 AM
    Berettafan
    Berettafan New Member
    2017 CM
    You know the 1st gen had s carpet type section where the seatbelt metal part would rest. Now I have to tuck it in after every time kids ride in back.
    Doubt it's ops problem but darn irritating.
  11. Feb 14, 2019 at 5:04 AM
    TundraCaper
    TundraCaper New Member
    2007 Tundra limited 4X4
    leveling kit
    I have the same problem as M1khale. Even replaced the rear drive shaft...no luck. Definitely hard clunking /clacking metal on metal. Sometimes one clunk, sometimes several, when decelerating.
    Seems to be in the front end.
    Has anyone solved this problem?
    Any help would be appreciated.
    Thanks
  12. Feb 14, 2019 at 5:49 AM
    Joe Dirt
    Joe Dirt New Member
    Don
    Sunriver, Oregun
    Silver 2018 SR5 4X4 DC
    Broken TPMS? I hit a 4' ditch so hard one time it snapped the tpms off at the stem. It made noise like that starting, deceleration. But not always repeated, the dealership found -0- but took the truck in months later to rotate the tires and the local Les Schwab found the issue. Jack up a tire and spin it, no sound go to the other. I was deer hunting over by Crater Lake, a flash flood had washed the road out, I was driving@45 after leaving my tree stand and had no time to react. I could skid to a stop and fall into the 4' by 4' ditch or accelerate across like dukes of Hazzard style. I was 75 miles from home, dark so I hit the gas. Extreme but I made it home, never let anyone tell me my truck ain't tough. The front end hit about 1' low but since the truck weighs 6,000 lbs it just plowed thru like a tank. Next day went to have it aligned the skid plate and frame were covered in gravel.
  13. Feb 14, 2019 at 5:54 AM
    Mnorris1206
    08 tundra
    Check all heat shields ? I had this kinda problem from one of mine. It ended up coming completely off. Just a thought you may check those.
    Stormtrooper81 likes this.
  14. Feb 20, 2019 at 8:43 AM
    TundraCaper
    leveling kit
  15. Feb 20, 2019 at 8:47 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I had a terrible clicking sound once. The little plastic tab where bottom of the bumper screws to skid plate had broken. The screw fell out and the tab was vibrating against skid plate
  16. Feb 20, 2019 at 8:48 AM
    TundraCaper
    leveling kit
    Has this problem been solved? Still have the exact problem....still no luck finding a solution.
    The front end is tight, no shields are loose, doesn't do it over bumps. Just when decelerating, and not always repeatable under same conditions.
    Rear driveshaft has been replaced with no change.
    Thanks.
  17. Apr 4, 2019 at 7:16 PM
    Jerguy
    Jerguy New Member
    Hey Everyone. I am
    Having a similar problem. Except mine is brand new. Well it has 4000 miles on it now but heard the noise at 400 miles.
    It’s a 2018 Platinum. Just bought in November.
    I have had it to the dealer twice. They can’t find anything wrong with it and the noise in the front is driving me crazy.
    Same clicking/clacking noise, not repeatable in same conditions always. I do notice when I roll up onto my driveway over the rollover curb there is 1 noticeable clack that’s sounds like it is coming from the same source.
    Any solutions?
    P.S
    I have read on another forum it could be from the trd skid plate installed after the fact. I do not have one.
  18. Nov 29, 2020 at 11:57 PM
    LA184
    LA184 Living the Dream
    2014 4x4, 4.6L Radiant Red Tundra
    4 in lift, 35s, Black Rhino Armory Wheels, Custom Rock Sliders, SDHQ ABS Guards, Warn Winch Bumper, Warn Evo VR 12-S Winch, 4.88 Re-Gear, Rear E-Locker.
    Wheel bearing? They have a deceptive sound that begins as static/grinding, metal to metal noises.
  19. Feb 27, 2021 at 1:46 AM
    Nate21420
    Nate21420 New Member
    2007 5.7v8 tundra
    Hey guys same deal here I know my differential is bad but the loud ticking and slapping has to be the fly wheel and pressure plate I'm saving up to replace the transmission and differential at the same time my dad just passed down the truck to me so I'm more determined then ever!!!! 2007 5.7v8 2wd 191,000 miles
  20. Feb 27, 2021 at 1:05 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    Your truck doesn't have a pressure plate or flywheel if it's an automatic. It only has flex plate and torque convertor.
  21. Mar 18, 2021 at 4:25 AM
    mike11895
    mike11895 New Member
    2010 tundra doublecab long bed
    Make sure to grease your 3 grease fittings along driveshaft!!!!!
  22. Dec 17, 2021 at 2:44 PM
    Primosoup
    Primosoup New Member
    2008 RCSB Tundra 5.7
    None
    The problem is the crosspin # 413420-OCO22 is loose in the pinion shaft. The pin that is supposed to keep it from moving sheers off. # 9025006085.
    I'm guessing because I use my 08 Tundra for towing it wore the pin and the slack broke the retaining pin.
    But...it was loose as hell and hitting the ring gear and the pinion gear.
    I replaced it with an Auburn Pro LSD.
    Hit me up if you need any help.
    Take a look at attached pic. The pin is sticking out. It should be flush in the shaft.
    THIS IS THE PROBLEM PEOPLE FACE AND CANT FIGURE OUT!
    Can it be repaired? I don't know..maybe a new crosspin and retaining pin..but I'm thinking the shaft is too wallowed out.
  23. Dec 22, 2021 at 1:15 AM
    Lickskillet
    Lickskillet New Member
    I had something similar in my 2010. Just started doing it one day. Turned out to be a piece of gravel in between two of the leafs in the rear. Was very happy to hear that it went away after removing the rock. It would pop intermittently. Sometimes 2-4 real quick pops. Hope this helps
  24. Mar 28, 2023 at 7:16 AM
    Gmccool
    Gmccool New Member
    None
    For me it was the four vertical bolts that fasten the transmission center mount to the cross member, one bolt was loose, the other three needed torquing a bit too, these bolts are in recessed holes on the cross member side they are hard to see unless you get directly under them.
