Clearing XM Radio Stations
Discussion in 'Audio & Video' started by PapaRoe, Jun 3, 2017.
  1. Jun 3, 2017 at 10:11 AM
    PapaRoe
    PapaRoe [OP] New Member
    Jack
    Is there a way of removing radio stations once you have saved it? I have accidentally selected a couple of duplicates, and would like to remove them.
  2. Jun 3, 2017 at 12:38 PM
    nowayout
    nowayout New Member
    NY
    17 CM
    I can think of two options. Either put another station in its place or disconnect the battery which will reset all of them.
  3. Jun 5, 2017 at 7:53 PM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    It's been a while since I had my battery disconnected, but I'm pretty sure the radio has non-volatile memory for the presets. I think it held on to my presets after my audio system upgrade. You can change the number of presets displayed from 6 to 36 in increments of 6 (through the Setup\Audio menu) or you can overwrite with another channel.
  4. Oct 7, 2018 at 11:01 AM
    NikNoid
    NikNoid New Member
    I have the same question. Another option, I think I haven't tried it yet, is to go into the radio setup screen. From there I think you can clear all of your presets. Again, a work around to something that should be an obvious feature, IMO.
