Cleaning gauge cluster plastic...
Discussion in 'Detailing' started by cornwall325, Jun 29, 2019.
  1. Jun 29, 2019 at 3:39 PM
    cornwall325
    cornwall325 [OP] Work in Progress
    2018 Tundra TRD Offroad Limited Crewmax
    What methods are you using to clean the gauge cluster plastic? It’s time to clean mine and I’ve read horror stories about clusters getting scratched bad. I’ve heard swiffer dusters as well as a wet microfiber. Would like to avoid all of the scratching that I can.
    Thanks in advance
  2. Jun 29, 2019 at 3:53 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    The swiffer will work, I use one now and then. Also I have a soft brush for end of the vacuum that works better. Make sure your MF towel is super clean. I like shine supply clean and shine, also aerospace 303
  3. Jun 29, 2019 at 3:58 PM
    cornwall325
    Is swiffer alone better or damp microfiber? I took canned air and blew off what I could. I’m guessing that what’s left is where dealer put something on there when the truck was delivered.
  4. Jun 29, 2019 at 4:06 PM
    Pudge
    CT
    Swiffer will at least grab the dust and remove it. Blowing it will just move it elsewhere. I like to vacuum or swiffer them using a clean, wet, MF towel wipe it down. Itll inevitably get a scratch but you can be careful and try to prevent as many as possible
  5. Jul 9, 2019 at 4:14 PM
    cornwall325
    I read a post online where someone uses olive oil on the gauge cluster. I don’t think I can bring myself to doing that. What other methods do you guys use?
  6. Jul 9, 2019 at 4:16 PM
    Shanesyota
    Shanesyota Midnight
    Shane
    Ohio
    2019 Black Tundra Platinum
    Weather tech Floor mats Weather tech bedliner and tailgate liner Black TRD shift knob Tonneau cover Match front window tint
    I have less than 600 miles on mine and it scratched with a window cleaning towel go figure
  7. Jul 9, 2019 at 4:17 PM
    cornwall325
    Did you have it the towel damp when it happened? I still need to take care of cleaning mine.
  8. Jul 9, 2019 at 4:17 PM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    No ammonia NO AMMONIA! NO AMMONIA!!!!! It may, or will turn it chalky white. Water or non ammonia cleaner with a soft towel.
    Shanesyota likes this.
  9. Jul 9, 2019 at 4:20 PM
    Shanesyota
    Shanesyota Midnight
    Shane
    Ohio
    No it was dry...I'm afraid to use anything else right now
  10. Jul 9, 2019 at 4:51 PM
    cornwall325
    That stinks man. Yeah I’ve read the horror stories so I have yet to touch mine. Would be nice if they weren’t so fragile and scratched so easily.
  11. Jul 9, 2019 at 5:05 PM
    P-Factor
    P-Factor New Member
    Clear View Plastic & Glass Cleaner by Aviation Laboratories
    AVL ClearView glass and plastic cleaner is safe on all plastics and glass - it contains no ammonia. This foaming cleaner leaves a shiny finish with no residue. This product is better than Plexus and at less than half the price!
    NorCalBear78 likes this.
  12. Jul 9, 2019 at 5:31 PM
    Shanesyota
    Shanesyota Midnight
    Shane
    Ohio
    Where can you get this at?
  13. Jul 9, 2019 at 6:10 PM
    P-Factor
    P-Factor New Member
  14. Jul 9, 2019 at 6:11 PM
    Shanesyota
    Shanesyota Midnight
    Shane
    Ohio
  15. Jul 9, 2019 at 6:13 PM
    P-Factor
    P-Factor New Member
  16. Jul 9, 2019 at 6:14 PM
    Shanesyota
    Shanesyota Midnight
    Shane
    Ohio
  17. Jul 9, 2019 at 6:19 PM
    cornwall325
    I cleaned mine with a swiffer and a damp microfiber with water only. I first gently “dabbed” at what dust was there with a new unscented swiffer. I followed up with a new white microfiber that I had damp. I was very gentle and didn’t use any pressure with either of these. So far all looks well and I’m hoping to not have to clean it for a while now since the plastic is so delicate.
    P-Factor likes this.
  18. Jul 9, 2019 at 7:04 PM
    AgileTundra
    AgileTundra New Member
    2018 Silver Sky Tundra Platnium 4x4
  19. Jul 9, 2019 at 7:26 PM
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2022 Tundra 1794 Supersonic Red
    Nitto Ridgegrapplers 175/60/20
    I screwed it up on our Sienna using window cleaner. Must have been the ammonia? Cloudy in one corner now. Peace. D
