Cleanest/Easiest Oil Change
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2020Platinum, Oct 4, 2021.
  1. Oct 4, 2021 at 8:44 AM
    2020Platinum
    2020Platinum [OP] www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    I’m sure most are aware or already using these pieces, but man I wish I added these sooner!…anyone on the fence, buy em…oil changes are so much faster/cleaner now!
    Toyota Tundra, Fastest/Cleanest Oil Change!...Fumoto Valve, MotivX Tool Kit, OEM Aluminum Cap Swap!
    https://youtu.be/UxsIvCSZPS8
    Kbar691, ToyoD, KDDesignsri and 11 others like this.
  2. Oct 4, 2021 at 9:10 AM
    WhyW8
    WhyW8 “It’s ALWAYS Loaded”
    HB
    Sunny AZ
    2017 Super White SR5 CM
    Level Kit, DiamonBack Tonneau, Step Boards, Alpine Amp, Cerwin Vega powered Sub
    Good "how to" vid.
    Just recently install the Fumoto drain valve to my Tundra -- the plastic plunger that comes with the OEM filters works fine to drain the oil from the filter house JUST add a small section of hose to the plunger. I used a small section of liquid-tight flexible non-metallic conduit slipped right onto the plastic plunger, it was stiff enough to help fully insert the plunger with a mess
    ACE is the place - pick up some clear tubing for the Fumoto. I keep a couple old 5 QT jugs and just drain directly into 5 QT jugs for easy transfer with no drain pan to transfer from or clean up - I use a drain pan ONLY as a catch a basin --- just in case there is a small amount of spillage
    ON EDIT: as stated below --REMEMBER the pan holds 8.5 QT's so tend to your catch jug/pan
  3. Oct 4, 2021 at 9:29 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I have these items on my truck and i have to say it was easily one of the best mods/money i could have spent. I changed my oil in 20 minutes the last time. longest part of using these is waiting for the draining, since its a tad slower than just having the pan open completely. Well worth it.
  4. Oct 4, 2021 at 9:32 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I do the same with the Fumoto. Keep in mind the Tundra holds 8 quarts. I put the jug under the Fumoto and stay with it until it fills, close the Fumoto replace the jug and drain the rest. I use a drain pan under the filter hose.
  5. Oct 4, 2021 at 11:34 AM
    Blue Thunder
    Washington
    I have the same setup. It is super easy, but as mentioned above takes longer than normal due to the smaller drain. Warming the oil helps a lot. I don’t rush it, so it isn’t a big deal.
    gosolo, 2020Platinum[OP] and WhyW8 like this.
  6. Oct 4, 2021 at 12:14 PM
    jimmyfu
    jimmyfu New Member
    N. California
    2014 Tundra DC SR
    I'm just itching to change my oil - last time I did it I installed a ValvoMax. Thought about the Fumoto but heard it drains slower. May reconsider though if the ValvoMax starts to leak...
  7. Oct 4, 2021 at 12:49 PM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    I just use a Sh!t load of news paper and water hose. :crapstorm:
    Good thing I only have to change it once a year.
    Motor71 and 2020Platinum[OP] like this.
  8. Oct 4, 2021 at 12:56 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Three Toyotas in the driveway. FOUR Fumotos on them. Four? Yes. Four. The Tundra has the rare and elusive Jowett Performance aircraft aluminum oil filter cap that itself features a Fumoto drain valve in the bottom of it. Oil changes super easy peasy.
  9. Oct 4, 2021 at 1:01 PM
    Cock-A-Doddle-Do
    Cock-A-Doddle-Do New Member
    Brett
    Cypress, Texas
    2021 TRD Off Road CM -Super White
    What makes you think the ValvoMax will leak and that the Fumoto is any better?
  10. Oct 4, 2021 at 1:03 PM
    jimmyfu
    jimmyfu New Member
    N. California
    2014 Tundra DC SR
    Just from reviews on Amazon and reddit - it's always a mixed bag. Figured if one leaks, then I'll at least try the other one before completely writing them all off.
  11. Oct 4, 2021 at 1:05 PM
    Cock-A-Doddle-Do
    Brett
    Cypress, Texas
    Got it, I've been looking at both and on the fence as to what one I should install
  12. Oct 4, 2021 at 1:07 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Another great video! Good to see you're still there, Patrick!
  13. Oct 4, 2021 at 3:26 PM
    CallsignKodiak
    CallsignKodiak New Member
    Bear
    Iiawah
    2021 CrewMax 4x4
    Bone stock
    Thanks for posting.
    Question: 5 quarts...windshield washer fluid or...? I'm drawing a blank here.
  14. Oct 4, 2021 at 4:49 PM
    WhyW8
    HB
    Sunny AZ
    Five Quart Oil jugs - buy my motor oil in 5 QT containers
  15. Oct 4, 2021 at 5:39 PM
    CallsignKodiak
    Bear
    Iiawah
    2021 CrewMax 4x4
    Bone stock
    Good point. I completely forgot those were 5 quart containers. New truck dictates some new habits for me.
    Tundratoofun likes this.
  16. Oct 4, 2021 at 8:04 PM
    2020Platinum
    Patrick
    Northeast PA
    thanks Ron, I appreciate it!!
    nice!… I’ve seen that and almost went that route, but every time I looked it was out of stock…haha…looks sweet though!
    thanks Kelly!..much appreciated!…still chugging along, mods on the truck have slowed some since we bought the new house but I’m still tickin…already thinking about what I’m gonna do with the next gen :facepalm:
  17. Oct 4, 2021 at 11:00 PM
    Amateur Guy
    Amateur Guy New Member
    24 months free oil change has ended. I self-changed oil on my 2019 first time yesterday. What should have been a 30 minute job turned in to 3-hour ordeal. When dealership changed oil last time, they tighten the oil filer cap so tight I could not remove it, even with beaker bar. I had to use my numatic impact wrench at maximum setting to remove it. I was ready to order the replacement cap because I was sure I'll break it. Some lazy ass didn't even remove the locking tab. They just bent it back. Now, I'm wondering if dealership even changed the filer. Maybe they couldn't remove it either and just left it.
  18. Oct 5, 2021 at 2:21 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Great video, nicely done!
    2020Platinum[OP] likes this.
  19. Oct 5, 2021 at 6:32 AM
    Legga400
    Legga400 New Member
    2021 Limited Nightshade
    How does that work exactly? I'm having a hard time visualizing on the Jowett page. Ordering is weird, piece at a time instead of one package.
    It takes the place of the metal circle thing so you can just drain via the Fumoto and then unscrew to replace the filter?
  20. Oct 5, 2021 at 6:43 AM
    MadMaxCanon
    Love your videos man, best ones on the internet for tundra. I will be using your tranny cooler install video hopefully soon. I dont know if you did one for your suspension, but if you did, i would love to see it!
  21. Oct 5, 2021 at 6:56 AM
    Amateur Guy
    The drain faucet is an excellent idea. I made a big mess draining the oil, even with an oversized catch pan.
    The filter housing cap and metal cap should be torqued to approximately 25 and 12 foot pounds.
  22. Oct 5, 2021 at 7:06 AM
    coldcanuk
    coldcanuk New Member
    2021 Tundra Platinum
    I've had Fumoto valves on my vehicles for the last 15 years, never an issue. First thing I do to a vehicle when I get it.
    I do add a little of the permatex high temp thread sealent 59235 to it before putting it on. I figure cheap insurance, am a big fan of the stuff. I actually add a whiff to most of my drain plugs and will use for my transfer case plugs when I do them.
    See the new MotivX filter wrenches are different, no more making them fit over those flanges up high, a lot better now. Look cooler too..........
  23. Oct 5, 2021 at 8:26 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Same experience here. Mine had to be torqued to 130. I broke one cheap filter wrench. I used a 2'+ breaker bar and my neighbor had to hold my legs. One key with the filter wrench is to use a socket versus inserting the 1/2" drive. This is not necessary if the cap is torqued properly. Also the cheap filter wrenches are fine too if not over torqued. I was fortunate to have a metal cap ready to go. I destroyed the plastic one. I wrote the service manager an email describing what I went through and the fact that I was missing one skid plate bolt and another was not original. He replaced the bolts and asked if I wanted them installed. I said nope you all will not be touching my truck again. He also offered a new filter cap. In hindsight I should have taken it because I had same problem on son's Camry and had to buy a new cap.
  24. Oct 5, 2021 at 9:09 AM
    Motor71
    Motor71 teufel hunden
    Rob
    New Jersey
    2016 tundra platinum
    TRD sway bar, matching mirror cover, 20% tint, esp aluminum box, Line-X premium, Undercover Flex tonneau cover, led interior lights, winjet smoked tail lights. Road armor rear bumper w/ road armor shackles, go rhino front bumper.
    Me too, I only put 2000 miles on it a year.
  25. Oct 5, 2021 at 11:07 AM
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    Fumoto has a new valve that drains significantly faster. Its F133 instead of F103
    https://www.youtube.com/watch?v=db304Qeo4tY
    The Motiv X tools for the filter housing are definitely worth buying. Both the tool for draining the housing and the one for removing the housing.
    https://www.amazon.com/gp/product/B087QQW3S8?ie=UTF8
    https://www.amazon.com/gp/product/B00XTAGHU0?ie=UTF8
    CallsignKodiak and BobsYourUncle like this.
  26. Oct 5, 2021 at 11:58 AM
    Legga400
    Legga400 New Member
    This is the correct kit for a 2021? I assume nothing has changed but the kit linked in the original youtube vid is no longer available. I wonder if it will work on a 2021 4runner as well.
  27. Oct 5, 2021 at 12:18 PM
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    The two housing cap tool and the housing drain tool will both work on the 2021 4Runner.
    As for the funnel, I think this is a better buy than the Toyota specific. Its a bit more expensive but it works on a bunch of vehicles. That said I just use this, also works very well on a variety of cars. Just have to be a little more careful.
    https://www.homedepot.com/p/FloTool-Super-QuickFill-Funnel-05062MI/205152513
  28. Oct 5, 2021 at 12:22 PM
    jhardy1979
    jhardy1979 New Member
    Justin
    MGM 2015 Tundra Crewmax Limited 4x4
    What size clear tubing is needed for the fumoto?
  29. Oct 5, 2021 at 12:26 PM
    2020Platinum
    Patrick
    Northeast PA
    They got me once too, I said never again…it’s crazy!
    Thank you!
    Thank you, I appreciate that!!…I actually started making one when I installed my lift but it was too hard to get all the angles and good shots so I squashed it…I did my lift myself in my garage so I got sick of tryin to worry about camera angles…hahaha
  30. Oct 5, 2021 at 12:32 PM
    Tundra14Platinum
    Tundra14Platinum I love reading the CoC in my spare time
    2014 Platinum CM Sky Silver
    TRD PRO Grill/Headlights, Swaybar, Eibach
