clean my throttle body 2007 tundra 5.7
Discussion in '2nd Gen Tundras (2007-2013)' started by oldbottles_29853, Aug 14, 2015.
  1. Aug 14, 2015 at 2:28 PM
    oldbottles_29853
    oldbottles_29853 [OP] New Member
    james
    beaufort sc
    2007 tundra crewmax 5.7 sr5pOini
    need some advice on how to clean the throttle body on my 07 tundra 5.7 with 135,000 miles.been told to use toyota cleaner. been told to spray throttle body butterfly then get someone to cut on ignition and press throttle to open butter fly and housing and clean with a tooth brush,then clean with a rag.sounds reasonably to me. any in put would be helpful, thanks
  2. Aug 14, 2015 at 2:35 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    Never cleaned a Tundra throttle body before but I did on my Silverado. I would suggest removing it so you can clean the whole assembly and not have to worry about using another person. This will also ensure no debris get left in your intake. My silverado it was 4 bolts and it was off. I'm sure the Tundra is similar. And any throttle body cleaner will do.
    PhotoNerd likes this.
  3. Aug 14, 2015 at 5:36 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Don't remove it, there is coolant flowing through it... you'll create a mess. Just remove your intake tube. Don't spray directly onto the thing, spray into a rag and wipe the rag on the tb butterfly. Do this all with the batt dosconnected.
    Pusb the Butter fly gently open with one finger and clean inside, both top and bottom. Out everything back together and let the truck idle for a bit. It'll likely relearn idle which could take a few.
    T-Rex266 and mdavis like this.
  4. Aug 14, 2015 at 5:44 PM
    mdavis
    Michael
    Rock Hill, SC
    Had no idea coolant ran through it...
  5. Aug 14, 2015 at 7:13 PM
    Mike Tread lightly.
    south carolina
    Coolant runs though it to keep the tb warm. It has any advantages by doing that.
    mdavis[QUOTED] likes this.
  6. Sep 20, 2023 at 6:57 PM
    Orions Dad
    Orions Dad New Member
    2007 Tundra 4.7L
    There is coolant does run through the TB but only a small amount will come out of the 2 lines just have a small rag handy. By removing the throttle body it is much easier to clean on both sides of the butterfly valve and you can inspect the screen that catches any debris that could get past the butterfly
