Chrome end caps
Discussion in '2.5 Gen Tundras (2014-2021)' started by Johnkentzel, Sep 23, 2017.
  1. Oct 28, 2017 at 7:49 PM
    Ahhhz
    Ahhhz New Member
    Oz
    17 Limited 4x
    End cap removal super easy.
    Remove Grill bolts and pull up to release pressure fit clips. It will have resistance but just pull that shit till it pops.
    These covers also have pressure fit clips. Pop um
    Then it’s some nylon pins holding in wheel well covers to access couple more bolts holding bumper cover on.
    there are maybe 6 more phillips screws/nylon pins that hold bottom of bumper insert to frame, directly underneath the bumper that also must get pulled.
    There is a steel piece called the “valance” that bumper plastics attach to. This is the main piece that is bolted to the frame. It’s un-stallation is simple but should be noted.
    You can see holes on top and bottom of end cap where it mounts to valance and skid plate.
    No need to remove the heavy duty 14mms that hold steel bumper on at front middle.
    Put blanket down to protect bumper and prove to yourself once and for all you are a responsible adult.
    End caps pop off with a few 8mms
    Everything else like detaching fogs and sensors is pretty self explans. The parking sensors use clips that just slide behind the sensor. Pay attention when removing but they can only install one way so even a pothead can figure this shit! :hattip:
    MotoTundra likes this.
  2. Oct 28, 2017 at 8:35 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    First I heard someone say it was easy, are you a tech?
    I have been avoiding it because it seems like a pain. Truthfully I thought the wheel well liner are a pain to remove while doing my fog lights.
    NewImprovedRon likes this.
  3. Oct 28, 2017 at 9:49 PM
    Ahhhz
    Ahhhz New Member
    Oz
    17 Limited 4x
    I’m just a bro who’s been tinkering on toys for a few years... I guess it depends on what you consider a PITA.
    60min, some sockets, 8 beers, cordless driver with Phillips, and a slotted (flat head) screw driver and this shit is donezo
    619Tundra, cmrock, Filthy13 and 3 others like this.
  4. Oct 28, 2017 at 11:32 PM
    Borgs
    Borgs New Member
    PA
    On the scale of gutting a deer and dragging 1.5 miles and changing lawn mower blades and sharpening- I'd put it in the middle. I called it a Pita. It's all relative.
    MotoTundra and Ahhhz like this.
  5. Oct 29, 2017 at 4:47 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Props to you, bro!
    I hear you. I believe I would also call it a PITA.
  6. Oct 29, 2017 at 5:39 AM
    BakNBlk2014
    BakNBlk2014 So Impossibly Black
    Donald
    Virginia Beach VA
    2014 limited cm attitude black 4x
    BDS 4 1/2 Nitto Terra Grappler 35x12.5/18 BW Fender Flares Moto Metal 970 Wheels Leer Tonneau Bed Cover Black Plastidip Grill CF Wrap Interior AJT Shift Knob 35% Tint Weather Tech Mats Toyota Bed Mat AFE Intake
    I did the plasti dip but would recommend powder coat after getting exhaust tips done. These are gloss blk pc but they said they can paint code color match if I need it. Looks just like paint and can take some abuse.
  7. Oct 30, 2017 at 5:35 PM
    tssull
    tssull New Member
    tim
    2016 limited gray
    did all this today. biggest pain was the parking sensors. that took about a half hour of fiddling with them. but in the end needle nose pliers and finding the 1 tab on top that releases the wire harness. and then you need to follow that wire back and detach it from the truck so you can pull the bumper off the whole way. i had a few screws left over. i guess the heavier chrome end caps have more screws holding them on. and like others have stated the fog light bezel is loose. not sure what to do with that yet. thanks to ROMAN all nice parts did the end caps new grill new hood buldge new handles all around and new tundra tags on the side. oh and trd off road suspension is the best.
  8. Oct 30, 2017 at 6:17 PM
    Tophergt99
    Tophergt99 Back in black
    Weston, Wisconsin
    2015 SR5 Black TRD Crewmax
    In progress....
    Ahhhz and NewImprovedRon like this.
  9. Nov 14, 2017 at 5:38 AM
    Cbrunt
    Cbrunt 2017 SR5 CM
    Charles
    Sacramento
    2017 White SR5 Crewmax
    Bakflip g2 cover Trd pro grill/bulge Nerf bar steps
    Nice ride. It has that mean look
    Borgs[QUOTED] likes this.
  10. Nov 14, 2017 at 9:03 AM
    Jeff@SR5
    Jeff@SR5 New Member
    Jeff
    Gardner, KS
    2014 Toyota Tundra Crew Max
    LED Cab Lights, Seat Covers, console organizer, color matched hood bulge with platinum grill, plasti dipped in black, Supreme suspensions 3-1 leveling kit, 295/70/18 Copper STT Pros. Chrome covers on handles and mirrors which will be taken off shortly.
    Spitfire, DaBoro54, Tony v and 4 others like this.
  11. Nov 14, 2017 at 9:08 AM
    AlexWV
    AlexWV Trophy Husband
    Alex
    WV
    2014 White SR5 TRD CrewMax
    ARE CX Series shell Rhino Rack cargo basket Leveling Kit 35x12.5 Thunderer TracGrip tires Rough Country 30" light bar
    Love the LineX look. I wanted to go with LineX, but my wallet (and more importantly wife) says no. I'm still trying to figure out what to do. I may tackle it with spray on bed liner myself this summer. It can't be much harder than plastidip right?
  12. Nov 14, 2017 at 9:37 AM
    Borgs
    Borgs New Member
    PA
    Thanks man.
  13. Jan 6, 2018 at 5:37 PM
    Tony v
    Tony v Member
    2017 SR5 CrewMax
    What was pricing like?
  14. Jan 6, 2018 at 7:03 PM
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
    Rear is done, pulling the front when it warms up a bit and hooking up the lights in the rear then too.
  15. Jan 13, 2018 at 9:32 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Can they Line-x without pulling the caps?
    I’m sick of pulling the front apart and the caps will be the last piece of chrome on my truck.
  16. Jan 13, 2018 at 9:55 AM
    Borgs
    Borgs New Member
    PA
    Not sure about LineX. I had mine powder coated and they needed to be removed. I think guys are vinyl wrapping them without removing but you may want to confirm.
  17. Jan 13, 2018 at 4:37 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Thanks.
  18. Jan 13, 2018 at 7:57 PM
    Hoologan
    Hoologan New Member
    California
    18 Cement Limited Crewmax TRD
    I tried to wrap my end caps today and failed miserably. Wasted half of a $180 sheet of vinyl and about four hours of my time. I figured it would be easy because I wrapped the grill of my wife’s Edge and it came out perfect (a way more complicated wrap). Should have just bought the painted end caps from SparksParts. Buy once cry once.
    NewImprovedRon and TomC843 like this.
  19. Jan 13, 2018 at 8:10 PM
    #49
    stefan702
    stefan702 IG: 702stefan_
    Randy
    Las Vegas
    2015 Tundra TRD Offroad
    IG: 702stefan_
    Definitely powdercoat them!
