Chrome Delete Covers for Tundra Bumpers - BumperShellz
Discussion in '2.5 Gen Tundras (2014-2021)' started by EC1, Oct 19, 2018.
  1. Jul 12, 2019 at 5:32 AM
    #2431
    Roundheadkid
    Roundheadkid New Member
    I made a mistake on my order...I accidentally ordered two front sets. Order No. 101780574 Can you cancel that order.
    I did a second order for both the front and the rear.
    Thanks
  2. Jul 12, 2019 at 6:15 AM
    #2432
    Pigglet222
    Pigglet222 New Member
    Order just placed!
    014-2019 Tundra Rear BumperShellz OEM COLORS - Pre-Order Page
    Qty: 1
    Parking Sensors: No
    Color: QUICKSAND
    THANK YOU for that 10% TUNDRA WORLD FORUM DISCOUNT CODE: TUNFRM
    Woot!
    Ely010606 likes this.
  3. Jul 12, 2019 at 6:27 AM
    #2433
    Patch999
    Kyle
    TX
    2017 Bad@$$ TRD Pro
    Just ordered. Thanks
    EC1[OP] likes this.
  4. Jul 12, 2019 at 6:48 AM
    #2434
    Jmmtjoy
    Jmmtjoy Livin the dream
    Bristow, Virginia
    2016 Crewmax SR5 Super White
    I have seen some where the sensors in the front cause the shell the be warped at the sensor. Is this normal? or does it typically sit flush?
  5. Jul 12, 2019 at 7:12 AM
    #2435
    Jmmtjoy
    Bristow, Virginia
    Are these dimples normal or was there a remedy for this?
  6. Jul 12, 2019 at 7:17 AM
    #2436
    Spitfire
    Spitfire New Member
    Long Island
    2018 Cement Limited Trd off road
    That's not normal... my paint is actually starting to bubble up around sensor a bit.. barely noticeable but hopefully doesn't get worse
  7. Jul 12, 2019 at 7:22 AM
    #2437
    Jmmtjoy
    Bristow, Virginia
    Oh man. Whats your plan if it gets worse? That doesn't sound good.
  8. Jul 12, 2019 at 7:23 AM
    #2438
    Spitfire
    Spitfire New Member
    Long Island
    I have two extra left sides bc of order mess ups lol:thumbsup:
  9. Jul 12, 2019 at 9:15 AM
    #2439
    EC1
    EC1 [OP] Ask about our BumperShellz Vendor
    Rocklin, CA
    BumperShellz
    I GOT YOU!
  10. Jul 12, 2019 at 9:22 AM
    #2440
    EC1
    Rocklin, CA
    BumperShellz
    The sensor pulls the the cover down there super tight, so that dimpling is going to happen to a certain extent. Since this past run, we've added a thickness of the 3M tape around the sensor to minimize this.
    Jmmtjoy[QUOTED] likes this.
  11. Jul 12, 2019 at 9:24 AM
    #2441
    Roundheadkid
  12. Jul 12, 2019 at 2:43 PM
    #2442
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    2018 Silver Tundra TRD Off Road Crewmax
    RC 1.75” Front, 1” Rear, TRD Dual Exhaust, Nitto RGs 275/70/18, TRD Center Caps, Rugged Cover Hard Tonneau, Rhino Liner, LED interior/exterior upgrade
    I just got mine on today and did notice this where it gets sucked in around the sensor a bit. Mine is worse on the passenger side but not horrible as long as the paint isn’t affected. Not sure how much adding 3M tape in the area would help because when you slide the white clip back on behind the bumper, that really pulls the sensor and the cover in super tight. I would have tried the 3M thing had I known about it though...lol. My covers went on pretty good, however I had to trim the sensor opening on the passenger side after it was on as it was not exactly lined up with the bumper hole, and I couldn’t get the sensor through. Also, the lower 10mm screw on the outside edge was not long enough to grab on the passenger side after install, so I bought a slightly longer one and it grabbed no problem. The project was well worth it and I love them so far!BB6F0049-A9E3-4FCF-BEAC-7CDF40A86307.jpg6449C1B3-9056-4685-8A40-5C4451BC19E2.jpg BB7CF252-F82E-48FF-BB58-F11B41735855.jpgBCB93915-CECA-4D2C-BBEA-953F51DEE391.jpg
    Ostrich and EC1[QUOTED][OP] like this.
  13. Jul 12, 2019 at 3:45 PM
    #2443
    Cthulhu
    @EC1 on the vote, for the grill surround overlay, that would include an overlay for the hood bulge as well, correct?
    EC1[OP] likes this.
  14. Jul 12, 2019 at 4:11 PM
    #2444
    sbbrown333
    sbbrown333 MGM Wrecking Crew
    Blake
    2018 MGM Limited CM 4x4
    So to access the sensors does this need to be removed? If so is it similar to the ones on the grille where you just lift the inner piece with a flathead? 530C6016-8FA7-4C9A-B1F6-C6AE98338A9F.jpg
  15. Jul 12, 2019 at 4:17 PM
    #2445
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    Yes- it has to come out to remove the liner and access the sensor. It pops right out if you get an angled screw driver or something like that to pull on it.
    sbbrown333[QUOTED] likes this.
  16. Jul 12, 2019 at 4:22 PM
    #2446
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    I’d say if you could get in the ballpark of the front covers, like in the 200s, it would be worth buying the bulge and surround set over buying the actual color matched parts from Sparks. For mine it’s in the mid 500s for both from Sparks.
  17. Jul 12, 2019 at 5:22 PM
    #2447
    EC1
    Rocklin, CA
    BumperShellz
    We did some tests with the 3M tape on the back side, and it does help, but it doesn't make it go away. Like you said, that white clip keeps them sucked in so tight. The only way to get rid of it completely, would be to file down the white clips on the "spring" portion of those white clips to make it less tight, but there is no way we're putting that in the instructions lol. Truck looks great man! Thanks for the feedback.
  18. Jul 12, 2019 at 5:30 PM
    #2448
    EC1
    Rocklin, CA
    BumperShellz
    We'll have to do some preliminary pricing to see if we can get it in that range. You're right, we need to be well below the cost of the replacement part for the grille and hood bulge. I'm pretty sure we can get there.
    Ostrich and Hammy68[QUOTED] like this.
  19. Jul 12, 2019 at 5:31 PM
    #2449
    EC1
    Rocklin, CA
    BumperShellz
    Yes! We'd develop those together.
  20. Jul 12, 2019 at 5:54 PM
    #2450
    EC1
    Rocklin, CA
    BumperShellz
    EVERYONE PART OF THE ORIGINAL GROUP BUY-------
    Hey guys! We sent out our last package from the original group buy on Wednesday, which marks the end of an era. To all of you that were a part of that, from the bottom of my heart, thank you! I think you could all tell that we weren't quite prepared for how big this was going to get, but across the board you guys were patient and understanding with all the delays that have happened. I couldn't have asked for anything better. We are a family owned business, so kids were swapped around every day to make sure a lot of us could stay late and get as much done as possible, and it made it just a little bit easier.
    Now that we've closed that chapter we're already starting a new one, so unfortunately I didn't get my 3 day nap lol, but I'll live. Thanks again guys. Thanks for the trust in our business and talking about us online to spread the word. This was the biggest product launch we've ever had in the history of our company, and it's down to all of you. Have a great weekend everyone!
  21. Jul 12, 2019 at 6:05 PM
    #2451
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    That’s a good idea- filing the clips down to alleviate some of the pull! I’m going to try that since it’s the only option I have besides removing everything, which isn’t gonna happen as I’m just letting my OCD stare at the tiny indent.
    EC1[QUOTED][OP] likes this.
  22. Jul 12, 2019 at 7:51 PM
    #2452
    Spitfire
    Spitfire New Member
    Long Island
    Any idea when I should get my passenger side endcap? My pro grill color match and bulge arrives from sparks tomorrow and want to have everything match
  23. Jul 13, 2019 at 8:59 AM
    #2453
    Yzed608
    Yzed608 New Member
    Wisconsin
    Thanks for putting it on!
    I have to pull my whole bumper off to take my plastic end caps off and put the OEM steel ones back on. Would you suggest putting the covers on with the steel caps removed from the bumper, or when they're back on the truck (or just attached to the rest of the bumper)? Would it even matter?
    EC1[QUOTED][OP] and Pigglet222 like this.
  24. Jul 14, 2019 at 10:10 AM
    #2454
    myk1013
    myk1013 New Member
    Myk
    2017 CM * MGM * TRD
    Thanks for the great customer service and producing a great product. I'm glad I hung on and waited for the group buy. This is a great victory on the War on Chrome!
    I'm curious how may sets did your company make?
    EC1[QUOTED][OP] and Hammy68 like this.
  25. Jul 15, 2019 at 7:16 AM
    #2455
    Lesroadking
    Lesroadking New Member
    Doral, Florida
    2020 MGM Toyota Tundra Trd Pro
    Diamondback SE Cover, Interior LEDS, Wet Okole Seat Covers,
    @EC1 thank you and your team. Very happy with my covers. They fit and look great. IMG_7181 (002).jpg
    EC1[OP], Ostrich and Hammy68 like this.
  26. Jul 15, 2019 at 7:43 AM
    #2456
    Spitfire
    Spitfire New Member
    Long Island
    @EC1
  27. Jul 15, 2019 at 1:42 PM
    #2457
    EC1
    Rocklin, CA
    BumperShellz
    I'll have the shipping department look at the tracking and I'll shoot you a message. I'm a little surprised that haven't shown up already.
  28. Jul 15, 2019 at 1:59 PM
    #2458
    Spitfire
    Spitfire New Member
    Long Island
    Just came about an hour ago.. nice note on packaging..lol @EC1
  29. Jul 15, 2019 at 2:56 PM
    #2459
    EC1
    Rocklin, CA
    BumperShellz
    I would do it once you have the bumper back together minus the fender wall and lower valance. You need to line up the edge of the covers with that black center valance, and that can be pretty finicky because of the variation in position of that center cover, and without having the bumper on the truck you'd kind of be flying blind.
  30. Jul 15, 2019 at 2:58 PM
    #2460
    EC1
    Rocklin, CA
    BumperShellz
    Haha I had about 3 different guys check it before they packaged it up.
