Chrome Delete Covers for Tundra Bumpers - BumperShellz
Discussion in '2.5 Gen Tundras (2014-2021)' started by EC1, Oct 19, 2018.
  1. Jul 11, 2021 at 3:01 PM
    #3931
    Leoking
    Leoking Leon-0
    Edward
    Minnesota
    '16 Toyota tundra CM Sr5
    So doing the install on the front ones when bending or just flexing the cover/shellz to put them does it make the paint crack or something? Or even if using the heat gun will make the plastic even more flexible that may ruin the paint? Anyone noticed something?
  2. Jul 12, 2021 at 5:16 AM
    #3932
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    2018 Silver Tundra TRD Off Road Crewmax
    RC 1.75” Front, 1” Rear, TRD Dual Exhaust, Nitto RGs 275/70/18, TRD Center Caps, Rugged Cover Hard Tonneau, Rhino Liner, LED interior/exterior upgrade
    I just put my silver hood bulge and surround on the other day and the pieces are fairly rigid, although flexible. There is no damage done in the movement, tugging and pushing needed for the install. The surround went on in seconds, without any issues other some of the tape needing some heat to stick. However, I was totally less than impressed with the fit and install of the bulge. I prepped, I was ready, had everything set and just could not get the top left and right sides to stick, or quite make it all the way over the chrome edge. I removed, adjusted, pushed, prodded, heated, pressed, you name it and there just does not seem to be enough material to make it on each side. Along the top edge it’s fine, but as it slopes down, the 3M tape won’t stick under there and you can see the chrome. There needs to be more material in that area and thicker or better tape- but I can’t remove again and get under there to add anything. Even so if I get it to stick, you’ll still see the chrome edges poking out. Does it look better than before? Yes, but I’m pretty bummed that after all this time waiting, and the cost, I’m looking at those areas now and have been heating it and trying to get it to be less noticeable. Sadly thinking I may have to buy just an actual silver bulge so my OCD settles down and the plastic doesn’t look half assed or pulls away with ice this winter or cold temps. I am happy for those that had a great install and mine may be the exception as it is difficult to expect every truck and trim to be the same shape.
  3. Jul 12, 2021 at 7:41 AM
    #3933
    Leoking
    Leoking Leon-0
    Edward
    Minnesota
    Gotcha, thanks for the info. I sent my end caps to the local shop and the painter said I have to be careful when put them on because the paint might crack.so I'm a bit concerned when that time comes :monocle:
    Hammy68[QUOTED] likes this.
  4. Jul 12, 2021 at 9:29 AM
    #3934
    JJMyerz
    JJMyerz New Member
    2020 Tundra Offroad TRD
    Hey everyone,
    wanted to get some feedback on the grille pieces, do they fit flush or do they add a lot of thickness and look too bulky? I’m a bit picky and want to know how slim and oem they truly look
    thanks!
  5. Jul 12, 2021 at 10:16 AM
    #3935
    EC1
    EC1 [OP] Ask about our BumperShellz Vendor
    Rocklin, CA
    BumperShellz
    Can you send me pictures of what you're seeing with the hood bulge? You have waited a super long time for these, so I want to figure out what's going on and see what we can do to fix it.
  6. Jul 12, 2021 at 10:59 AM
    #3936
    1g3tundra2
    1g3tundra2 New Member
    2018 gray tundra
    What hood visor is that?
  7. Jul 12, 2021 at 11:26 AM
    #3937
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    Sorry about the rant- just was frustrated and out of time messing with it. I’m trying to figure out how to maybe get some stronger or thicker tape under there. It fits ok in all other areas, which leads me to believe I have it tight and pressed in where it needs to be. I think it’s mainly a tape issue and the shape somewhat on the upper corners. I cannot get them to stay down or completely reach the edge of the chrome. I’ve heated extensively and have got it to stick briefly when warm in the sun, but then both sides pop back up. Even pressed down you can still see some chrome, but I could live with it probably if the tape would somehow keep the corners down.
  8. Jul 12, 2021 at 11:48 AM
    #3938
    Broomsky06
    Broomsky06 New Member
    2021 Tundra Silver CM
  9. Jul 12, 2021 at 11:49 AM
    #3939
    Broomsky06
    It looks like maybe you need the super thin 3m tape he was sending out with the recent orders. It almost looks from the pics that the tape is too thick and causing it to leave a gap where it’s not sealing. The second to last picture of yours you can see where it starts to stick up right where the thickness of the tape starts.
  10. Jul 12, 2021 at 12:02 PM
    #3940
    1g3tundra2
    2018 gray tundra
    I have the same gap does bug me a tad bit. Was going take it off and try to get it down. Lmk what works. Seems like few other members having same issue
  11. Jul 12, 2021 at 2:49 PM
    #3941
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    Thanks for the reply- I think they have the thin tape and it’s under there, but not touching at all. If I use heat or press down when it’s hot, it will still stick momentarily, then you hear the tape let go and it pops back up. It’s just too much of a gap and resistance with the shape of the plastic to stay down where it needs to be.
  12. Jul 12, 2021 at 2:57 PM
    #3942
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    I may try to find a stronger tape, if there is one, and try to get some pieces in near the edge using tweezers or something. I’m not going to take this thing off again- if it comes off, it is stating off, lol. Been twice now, and I know that is not good for the tape adhesion.
  13. Jul 12, 2021 at 3:09 PM
    #3943
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    They don’t add any thickness and look oem in my opinion. They sit so close to the chrome trim that unless you inspect the truck super closely, you would never know that it didn’t come with the color match trim. I had some difficulty installing the bulge piece and can still say that it looks stock.
  14. Jul 12, 2021 at 10:54 PM
    #3944
    Photoweekender
    Photoweekender New Member
    Queens, NY
    2022 Tundra Limited DC TRD OR 4x4 Army Green
    TRD Pro Skid Plate Tonneau cover - OEM Talons Garage cat plate Emblem blackout Solar panel on tonneau cover
    i was among the first orders and my bulge cover came off while driving on the highway. I was able to pull over on NY 87 (very busy highway) and pull it off and threw it in the back. I contacted CS and a new one is on the way.
    Lesson: be careful with the bulge trim if it doesn't stick like the other pieces.
  15. Jul 13, 2021 at 1:05 PM
    #3945
    Tundra694
    Tundra694 New Member
    AJ
    2021 Tundra Crew Max Trd Off Road
    Thank you for all of the help! I was able to get into it today and found that the sensor was a bit snug in the hole. I removed it and filed the hole all the way around to give it some clearance and once I put everything back together they worked as before. Glad it’s all good to go now. Thank you.
    EC1[QUOTED][OP] likes this.
  16. Jul 13, 2021 at 4:07 PM
    #3946
    EC1
    Rocklin, CA
    BumperShellz
    Tape is the key. I'm going to send you out a bunch so you can re-tape it if you can get it off. If something goes wrong with that, send me a message
  17. Jul 13, 2021 at 4:12 PM
    #3947
    joe557
    joe557 New Member
    Joe
    2014 Crewmax SR5 4x4 TRD
    Bilstein 6112/5160s, durobumps, 1" CB shackles, RCI skids
    Are we really relying on a bunch of tape to hold these things in place? That doesn't seem like a long term solution, especially for those who live in extreme cold or hot climates.
    BravoDeltaRomeo and Pbed85 like this.
  18. Jul 13, 2021 at 7:59 PM
    #3948
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    I think if done right in conjunction with well fitted pieces, the 3M Automotive tape does work well. I’ve had the rear bumper covers from this company on older Tacomas for years and years, as well as the front and rear covers on my Tundra for a few years now up here in northern NH. Cold temps are concerning, so I want to make sure all points of contact are touching properly, and hopefully it will be fine.
  19. Jul 16, 2021 at 5:03 PM
    #3949
    EC1
    Rocklin, CA
    BumperShellz
    The 3M tape we use is specifically designed for chrome and other low surface energy applications. Like @Hammy68 said, as long as if the tape is touching down, or not being held off in some areas there won't be any issues with it. Hot and Cold isn't an issue after installation. Just when the tape is wetting out initially. Generally speaking, adhesion hasn't been something we have needed to worry about. The tape is extremely strong when bonded. The times where we see it crop up are instances like the hood bulge where we are dealing with an entirely new application with tiny tolerances, so there is some variation somewhere that we haven't seen in our testing. And on that note, if you are seeing issues with adhesion anywhere early on, just shoot me a message and I'll do whatever to make sure we don't scare the crap out of any more wives on the highway lol
    All that being said, I too feel better when I bolt something on instead of praying that some magic tape holds it on haha. There just aren't any mechanical fasteners available near the hood bulge, but we use them extensively on the front and rear BumperShellz
    Photoweekender and Hammy68 like this.
  20. Jul 16, 2021 at 5:07 PM
    #3950
    EC1
    Rocklin, CA
    BumperShellz
    Doing another MGM/Attitude Black/Silver Sky run late next week. Also, Matte Black will be back in stock for those of you that have been waiting for that!
    sigh824 and joe557 like this.
  21. Jul 17, 2021 at 9:35 AM
    #3951
    WonkyDonkey
    WonkyDonkey New Member
    Justin
    2019 Cement Tundra TRD offroad limited
    Bought it with a ARE camper and some factory TRD/Toyota bolt one's, otherwise mostly stock
    @EC1 any word when cement will be available?
  22. Jul 18, 2021 at 8:27 PM
    #3952
    daays
    daays New Member
    On the fence on whether to go with sky silver or matte black shells. Help!
  23. Jul 19, 2021 at 5:09 AM
    #3953
    BorderTaco
    BorderTaco New Member
    21 Yeehaw Yuppie Truck
    @EC1 there ever going to be a wind chill pearl run?
  24. Jul 19, 2021 at 8:46 AM
    #3954
    buffaluphagus
    buffaluphagus —————————————
    When will Mgm front bumper be back in stock?
  25. Jul 21, 2021 at 11:52 AM
    #3955
    tomwithatundra
    tomwithatundra .
    2018 Tundra SR5 Cement
    5100’s middle setting, +18 offset, BFG At2’s 275/65/18
    This
    Rabidllamas likes this.
  26. Jul 21, 2021 at 3:31 PM
    #3956
    EC1
    Rocklin, CA
    BumperShellz
    That is the first color we are going to be painting in our booth. Might do a test run here of maybe 10-15 sets only on the forum to grease the skids. We're still buried with orders which is the only thing that is slowing up that process right now. At the end of next week, I'll post another update about the coming cement run. To stave off questions, I'm probably not going to do a waitlist for that one right now because it's so up in the air and I don't want to set expectations that I can't guarantee. It'll just be when I get the green-light from our paint manager and I'll post a certain number of sets for sale.
  27. Jul 28, 2021 at 2:51 PM
    #3957
    Leoking
    Leoking Leon-0
    Edward
    Minnesota
    The before and after of just the bumpershellz, mirror caps, hood bulge and grille is OEM.
    Hammy68, EC1[OP] and YotaTruckLtd like this.
  28. Jul 28, 2021 at 2:59 PM
    #3958
    GWill
    GWill gods gift to the internet
    Willis
    Don’t know what you’re talking about
    2020 MGM TRD Pro
    Headlights too?
    EC1[OP] likes this.
  29. Jul 28, 2021 at 3:01 PM
    #3959
    Leoking
    Leoking Leon-0
    Edward
    Minnesota
    :thumbsup: headlights and grille from a 2019
    EC1[OP] likes this.
  30. Jul 28, 2021 at 3:05 PM
    #3960
    GWill
    Willis
    2020 MGM TRD Pro
    Talk about glowing up!
    EC1[OP] and Leoking[QUOTED] like this.
