Christmas came early
Discussion in '2.5 Gen Tundras (2014-2021)' started by paulphilly, Sep 5, 2017.
  1. Sep 6, 2017 at 8:22 AM
    havasubud
    havasubud Owner ESP Truck Accessories Vendor
    Earl
    Corona, California
    2022 Tundra CrewMax Limited TRD OR 4x4
    Factory Tube Steps, TraiFX tri fold tonneau cover
    He said he rough wired it to test but is waiting for connectors to make the harness. I am working on the same thing right now.
  2. Sep 6, 2017 at 8:38 AM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Please post pictures guys =)
  3. Sep 6, 2017 at 9:27 AM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    :popcorn:
    Sunnier and Lilly like this.
  4. Sep 6, 2017 at 1:16 PM
    pvdubber
    pvdubber New Member
    Auburn CA
    2017 Silver Sky
    ...And just like that I have 600 less dollars. I made a promise to myself, and now fear where this will end up!
    paulphilly[OP] likes this.
  5. Sep 6, 2017 at 1:58 PM
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
    I’m still working on a few diagrams for the wiring conversion and I’ll also include a few pics of the plugs I’m using to create a plug and play harness for these lights and I’ll be posting them in a new thread. The wiring for the front directional will have to be changed as well. The stock 2014-2017 3 pin plug fits on the new 2018 socket but the ground and directional pin positions need to be swapped for the signals to work. The stock 14-17 sockets with the 4157NA bulbs won't fit into the new housings.
    Stay Tuned
    BlueBottle likes this.
  6. Sep 6, 2017 at 2:01 PM
    havasubud
    Earl
    Corona, California
    That's for an SR5 correct? The truck I am working on is a 17 Platinum. Waiting for all of the connectors to come in. Looking at the wiring diagrams, shouldn't be that hard. I have the factory wiring diagrams if you need them
    Slimwood Shady, kkim124 and pvdubber like this.
  7. Sep 6, 2017 at 2:07 PM
    pvdubber
    pvdubber New Member
    Auburn CA
    2017 Silver Sky
    Would it be possible for me to get a copy of the wiring diagram form you. I just ordered a set of the lights and I will get working on a harness as well.
  8. Sep 6, 2017 at 2:09 PM
    havasubud
    Earl
    Corona, California
    Whoever wants the diagrams, pm me your email and I'll send them
    T-Rex266, BlueBottle and pvdubber like this.
  9. Sep 6, 2017 at 2:17 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Nice work you guys! Is there still a level adjustment to the headlights?
  10. Sep 6, 2017 at 2:38 PM
    thomasbus337
    2020 TRD Sport DC
    Yes, level adjustment still works. The 14-17 turn signal socket and bulb are the same across all trims. I'm guessing the Platinum and 1794's are just missing the purple parking light wire in this three pin plug because on those trims the purple wire plugs into the 4 pin DRL plug.
    831Tun likes this.
  11. Sep 6, 2017 at 3:38 PM
    MMichaelJJ
    MMichaelJJ New Member
    14 Platinum CM
    Do you know the bulb number / type?
    The platinums (probably 1794s too) use 3157CK bulbs. I'm running VLED V3s now but have the V6s on preorder. Are they compatible?
    Thanks in advance.
  12. Sep 6, 2017 at 3:52 PM
    thomasbus337
    2020 TRD Sport DC
    The 14-17 uses a 4157NAK. The 2018 LED headlight uses a 7444NA. I can't speak for the new V6's but to make the V3's fit in the new smaller opening I had to remove the collar from the VLED unit and then it fit. If you're using Vleds you won't have to change any of the wiring for the directionals
  13. Sep 6, 2017 at 4:42 PM
    Tophergt99
    Tophergt99 Back in black
    Weston, Wisconsin
    2015 SR5 Black TRD Crewmax
    In progress....
    So how hard will this be to do to a 15 SR5? :D
  14. Sep 6, 2017 at 4:48 PM
    kkim124
    kkim124 New Member
    Torrance, CA
    2016 Tundra Platunum 4x4
    I'm hoping you will be able to share the information you find out with the lights. I have a platinum as well and am very much interested in this headlight swap.
  15. Sep 7, 2017 at 12:25 PM
    MMichaelJJ
    14 Platinum CM
    My 14' platinum uses a 3157CK bulb. Sounds like it's different from the trucks that didn't come with LED DRL.
    Can you take a photo of the 7444NA bulb socket? Trying to see if it's a regular bulb or a CK type.
    Here's a link to show the difference.
    http://www.vleds.com/ck/
  16. Sep 7, 2017 at 3:02 PM
    thomasbus337
    2020 TRD Sport DC
    Just curious, if you're going to use either the V3's or V6's then you can still use your existing plugs and sockets. Here's the pic for reference
    MMichaelJJ likes this.
  17. Sep 7, 2017 at 3:10 PM
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    I applaud you guys that read electrical diagrams, its like a foreign language to me. I never have been able to wrap my head around that stuff. I can do some basic wiring buts its very basic lol.
    So when someone comes up with a wire adaptor for a 2016 SR5, I will be waiting....lol
    757TUNDRA, jdg1982 and T-Rex266 like this.
  18. Sep 7, 2017 at 3:33 PM
    MMichaelJJ
    14 Platinum CM
    Can you take another picture of that 18' bulb socket with a flash to see down in there?
  19. Sep 7, 2017 at 3:50 PM
    #49
    thomasbus337
    2020 TRD Sport DC
  20. Sep 7, 2017 at 5:11 PM
    #50
    thomasbus337
    2020 TRD Sport DC
    I didn’t want to leave the SR, SR5 and Limited crowd out, so I drew up a plan for a PnP harness to add these 2018 LED headlights onto the models that didn’t come from the factory with LED DRL’s. I updated the info in my thread in the lighting section with the info.
    pvdubber, RLHULK and Quebec like this.
  21. Sep 7, 2017 at 6:52 PM
    #51
    ToyLC
    ToyLC New Member
    Very nice.
