Chemical Guys Results
Discussion in 'Detailing' started by BayRunner, Jun 11, 2018.
  1. Jul 5, 2018 at 2:06 PM
    #61
    HecticEnergy
    HecticEnergy New Member
    TJ
    SE Texas
    2017 MGM Tundra SR5
    Winjet Rear brake lights, leather seats, BackFlip tonneau cover, Spyder headlights, Pro Grille, pop&lock
    Thanks for the product suggestions.
    I bought my truck new in May '17. only about 16k miles on it. A few long trips, but out side of that probably do around 600mi/mo
    I take decent care of it - washing regularly as weather allows. Usually a few time a month except in the winter when it's constantly raining. all by hand, never automatic car wash (except, I think the dealer uses an automatic car wash when I take it in for reg maintenance..) In any case I havent noticed any swirl marks or anything that would require paint correction.
    Also, it lives outside (not garaged).
    Hand wash process:
    Pressure wash with 1600psi holding it a few feet back. I go over the whole truck once top to bottom, spending a little extra time on areas with obvious gunk (usually the front end bugs).
    I used the foam accessory with some walmart pressure washer car wash soap, but it's not all that great so I switched to using a bucket with Mr. Pink.
    Using a microfiber mit, I do a section of the car at a time, rinsing again with the pressure washer, scrubbing with soap, and then rinse the soap completely off.
    Once the car is completely washed I'll run around again with the pressure washer then dry it with a extra large microfiber towel (bath towel sized).
    I dont wash the wheels every time (usually run out of time...) but when I do I wash those last.
    The water is usually still fairly clear when I get done with the body. Probably a combination of the high pressure rinse and not going too long between washes.
    Usually only takes about 30-45 minutes, 45-60 if you want to include setup and take down.
    These products you guys recommended suggest clay bar first. I've never clay bared a vehicle, but it appears to take several hours. If that's the case I think I'll have to take it to the pros as I'm not sure I can take 4 hours of uninterpreted time to clean the vehicle (wash, clay bar, wax) :\
    Maybe I can swing it if it's a once a year thing, but I dont think I'm that lucky lol
    Ceramic coating may be the way to go... it's expensive, but at least it should last 5+ years, right?
  2. Jul 6, 2018 at 5:05 AM
    #62
    briarpatch
    briarpatch New Member
    During your wash process, if you're using a single wash mitt, I'd recommend the 'two bucket method'....lots of Youtube videos out there showing it. Basically, you have one wash bucket and one rinse bucket, each with a Grit Guard (or similar) in them. I've gotten away from it, and now use a single bucket, switching (frequently) to a clean mitt. Yes, I need several mitts, but I feel like it mitigates the potential for me to mar the paint while washing. For the record, I do the wheels and tires first. Keep in mind, if your dealer washes your car at an automatic wash, there's a really good chance that your paint will get swirled. Even if it's touchless, the soaps that they use are not Ph-balanced, and will degrade any protection (wax) currently on it.
    Claying a vehicle is not rocket science, and will not take hours, even on a Tundra. I can clay mine in about 30 minutes, and I really only do it once a year, maybe twice. The down side to claying is that it's generally recommended to polish afterwards, since clay is an abrasive, and can cause some (minimal) marring of the paint.
    Ceramics are all the rage, and durability claims and/or warranties vary by manufacturer. You will likely pay some serious coin to have one done professionally, but if you're not really into the detailing side of this, it could be the way to go for you.
    driverdog and HecticEnergy like this.
  3. Jul 6, 2018 at 6:51 AM
    #63
    HecticEnergy
    TJ
    SE Texas
    2017 MGM Tundra SR5
    Thanks for the reply!
    30 min isn’t all that bad for claybaring. Maybe I’ll order the stuff for next week.
    After I wash next time I’ll pay extra attention and check for swirling.
    I wash pretty much top to bottom: starting with the top of the truck, back window and windshield. Drivers side of the truck then the passenger. The around the box. Finally the hood and front 1/4 of the truck.
    Why would you start with the wheels? Seems like starting with the dirtiest part of the truck would be counter productive. I also use a mf rag and detailing brushes for the rims and tires - not the mit I wash the body with.
    I’m going to go spend more time in the detailing section... lol
  4. Jul 6, 2018 at 7:29 AM
    #64
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
    What do you recommend to get the bugs off? Is there something to put down to help with the ease of getting them off as well?
  5. Jul 6, 2018 at 7:30 AM
    #65
    Ref wheels/tires- use some cleaner to let it soak. Then use a wheel and tire brush to get the dirt off followed by rinsing. :thumbsup:
  6. Jul 6, 2018 at 7:42 AM
    #66
    War Machine
    War Machine SSEM # 5 3MW
    Bounce sheets and water. Nothing better. Cheap and easy.
  7. Jul 8, 2018 at 8:13 AM
    #67
    briarpatch
    Kenotek Anti Insect or Poor Boys Bug Squash
  8. Aug 11, 2018 at 7:13 PM
    #68
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    Few weeks back I purchased fine clay eraser mitt by CG. I purchased it hoping it would take off tar from the recent road work. Well I got a bit excited and used to little lube and mard the paint a bit. Next pass use more lube and noticed it was not taking off tar spec. What are you guys using to take off tar? Haven't found the right product.
    I did read you can use heavy soap with clay eraser mitt instead of lube not sure if that a good idea? Wondering if I should have gotten the extra fine for my paint. I am afraid if I use it on my whole truck I will mar the pait here and there. Need to be careful with this mitt. Clay bar seems to be a bit safer. Think a medium clay bar will take tar off, and not be so harsh on my newer paint? Really getting into this detailing.
  9. Aug 12, 2018 at 10:40 AM
    #69
    briarpatch
    Stoners Tarminator
  10. Aug 12, 2018 at 10:57 AM
    #70
    MotoTundra
    MotoTundra The Ocho
    Don
    I use turtlewax bug and tar remover before I clay bar. It is extra elbow work but I feel it helps remove a good bit of tar which equals less little scratches from using the clay bar.
    I will always polish with my DA random orbital buffer and wax after I clay bar, it removes all the little scratches from the clay bar.
    SouthBoundSteve likes this.
  11. Aug 12, 2018 at 12:18 PM
    #71
    MotoTundra
    MotoTundra The Ocho
    Don
    Our roads are a mess. Those tar & chipped roads are no good for those OCD about their paint.
  12. Aug 12, 2018 at 12:37 PM
    #72
    MotoTundra
    MotoTundra The Ocho
    Don
    That's awesome. For some reason this type truck comes to mind for those dirt roads...
  13. Aug 12, 2018 at 1:08 PM
    #73
    MotoTundra
    MotoTundra The Ocho
    Don
    Haha I bet!
  14. Jul 19, 2019 at 9:55 AM
    #74
    alpinepro4
    Pat
    Anyone use Mr. Pink in there foam cannon? I just bought some honey dew foam for the cannon and it works great! I need to use up the rest of Mr. Pink. Mr. Pink work just as well as honey dew foam in foam cannon?
  15. Jul 19, 2019 at 11:04 AM
    #75
    briarpatch
    Mr Pink was where I started...decent soap, but Honeydew was better....much better out of the foam cannon
  16. Jul 25, 2019 at 10:37 AM
    #76
    briarpatch
    Unless you plan on using the power washer for other, more heavy duty pursuits, an electric will work fine with a foam cannon. I have a SunJoe, and both an Amazon (20.00) foam cannon and an MTM PF22 foam cannon....very pleased with the performance of both.
    dak13, Pudge and driverdog like this.
  17. Jul 25, 2019 at 8:44 PM
    #77
    Pudge
    CT
    2015 Blue Ribbon Platinum
    $100 kärcher Electric washer and $20 Amazon MATCC gun gets the job done very well, I don't even use soaps meant for a cannon. I use chem guys maxisuds2 in the gun, then carpro reset in the buckets. I hear reset doesn't foam well.
    The key is fill your cannon vessel with hot water almost to the top, then add a couple ounces of soap and play with the settings til you get it right. The foam really does lift and release a lot of junk. I would imagine with a ceramic coating you could get away with rinse, foam, power wash now and then and be totally hands off your paint.
    I like to foam the frame and undercarriage now and then with dawn, then power wash it off
    driverdog likes this.
  18. Jul 26, 2019 at 3:59 AM
    #78
    Lol...that conversation could have ended like this.
    dak13 likes this.
  19. Aug 5, 2019 at 5:17 PM
    #79
    Kyk1e
    Kyk1e New Member
    Kyle
    Limerick, Pa
    2017 Toyota Tundra TRD Pro
    Which model kärcher do you have? I have the MATCC cannon and want to make sure it’ll fit the washer.
    Pudge[QUOTED] likes this.
  20. Aug 5, 2019 at 7:50 PM
    #80
    Pudge
    CT
    I think its called a K2 , I bought an the matcc gun with the karcher adapter from Amazon. I think they sell guns to fit various models
    Kyk1e[QUOTED] likes this.
  21. Aug 13, 2019 at 3:23 PM
    #81
    SMK Shoe
    SMK Shoe Not New Member
    Paul
    Central North Carolina
    2017 Tundra TRD DC
    Step Bars, Rear Swaybar, 2,000 Watt Amp, 2-10" Subs, new door speakers, De-Badged, Hondo vent mounts, Calipers, 6112/5100 shocks, SPC UCA's, Front bumper, Bed Bars, bed rack, Fuel Rims
    Anyone deal with chemical guys customer service. Made a order about two weeks ago of a few things. Arrived in a timely manner, only issue was that the mr. Pink had leaked in the box. Didn't affect anything except for a PITA un box ( having to wash every bottle) and that about 1/4 of the mr. Pink had leaked out. Sent a e-mail with pictures right away but haven't gotten a response back. Not like it really affected much ( still enough soap to make it till next summer), but no response or even acknowledgement that it happened is a little disturbing. Like their products but this definitely puts a bad taste in my mouth.
    Prostar 190 likes this.
  22. Aug 13, 2019 at 4:43 PM
    #82
    I had something break in shipping once. They were very fast on getting a new one out for me. So I was very happy with the service.
  23. Aug 14, 2019 at 4:31 AM
    #83
    briarpatch
    Chemical Guys customer service is not the best.....that's why I stopped buying directly from them. When I get their stuff, it's either through Amazon or Autogeek. As a side note, I really use very little from them anymore, there are better options out there
    Pudge likes this.
  24. Aug 14, 2019 at 4:52 AM
    #84
    SMK Shoe
    Paul
    2017 Tundra TRD DC
    I'll give it to the end of the week . That will be over 10 days since the first email. I do believe that I may start looking for my detailing supplies somewhere else. not like 2$ worth of soap is a big deal or anything, But the lack of a response is. To many companies want my business, so I will look there.
    War Machine and Prostar 190 like this.
  25. Aug 14, 2019 at 5:31 AM
    #85
    War Machine
    Almost every detailing product company has exceptional customer service. CG and Dallas Paint Correction are the only ones I’ve heard bad reviews on. Pretty much every one of their competitors would apologize and fix your issue immediately.
    I’ve had the same issue with CG soap leaking in the package, but I bought it through Amazon. They refunded me within minutes.
  26. Aug 14, 2019 at 5:35 AM
    #86
    SMK Shoe
    Paul
    2017 Tundra TRD DC
    Heck, I think the apology is more of the issue than 2$ worth of soap. First time I have ordered from them directly and it will probably be the last. Not the kind of impression I would want to make to a first time customer that does a lot of detailing.
    War Machine likes this.
  27. Aug 14, 2019 at 9:16 AM
    #87
    owb2gp
    owb2gp New Member
    ID
    I would recommend calling them. They took care of my issue quickly and send replacement items. I've never had an issue with them taking care of damaged products.
  28. Aug 14, 2019 at 4:12 PM
    #88
    Drew C
    Drew C New Member
    FWIW worth I had an issue/email out t them with no response.
    Also, I had a product leak from Amazon (CG product). Amazon was kind of a pain in the arse. I would have to send back the leaked bottle. They were gonna send a replacement, Bill me and then credit upon the return. Technically not a problem but not worth the hassle. Other issues with amazon (not many) generally resulted in a replacement at n/c. Not that time.
  29. Aug 14, 2019 at 4:45 PM
    #89
    owb2gp
    owb2gp New Member
    ID
    I'm curious why people email over taking a minute to call these companies that have people to help. Much faster in my opinion with better results. And when I hear I don't have time for that I really doubt that. But the same people will spend 10 minutes writing a bad review.
    Prostar 190 and Pudge like this.
  30. Aug 14, 2019 at 5:19 PM
    #90
    SMK Shoe
    Paul
    2017 Tundra TRD DC
    I like e-mailing because it gives them time to figure out the issue. Instead of dealing with three different people on the phone at once, they can work each issue. Not that I needed them to solve the issue immediately, I expect they ARE busy. but I would expect some type of response within a day or two. Emailing also allows them to see the attached pictures.
