Checking out a cheap first gen today
Discussion in '1st Gen Tundras (2000-2006)' started by Timjtitus, Apr 9, 2024.
  1. Apr 9, 2024 at 5:31 AM
    Timjtitus
    Timjtitus [OP] New Member
    Looking at a RCLB V8 4x4 with rear end noise. Any pointers on narrowing it down to bearings or the diff being toast?
  2. Apr 9, 2024 at 5:37 AM
    BroHon and The Black Mamba like this.
  3. Apr 9, 2024 at 5:38 AM
    shifty` In South Dakota Trouble ain't hard to find
    I mean, what kind of noise? "Rear end noise" is vague. It could be any number of things:
    • Grinding/dragging, like ... rear end gearing is shot, parking brake isn't adjusted properly and pulling and/or the shoes aren't adjusted properly and/or the shoes are worn through, or similar
    • Skipping/bumping, like ... it has LSD rear end and the previous owner put the wrong fluid in it, so it's skipping (chatter), or they did it for a long time and now the clutch pack is worn out
    • Howling/whirring, like ... bad pinion bearing, bad wheel bearing
    Knowing the type of noise and what other symptoms exist (any vibration in a specific speed range, does it stop/start at any time?) would be helpful.
    I mean, the biggest concern is the frame condition and timing belt. But I think you know that already.
    JasonC. and 455h0le_dachshund like this.
  4. Apr 9, 2024 at 5:43 AM
    Timjtitus
    Yeah, ad wasn’t specific on the the type of noise. I’ll find out in a few hours
    shifty` likes this.
  5. Apr 9, 2024 at 5:49 AM
    Well, the three bullet points above will give you the main types of sounds to check for. I'd probably want to test drive it (if they'll let you) to figure out which type of sound.
    No matter which one of the above it is, you can fix for under $1k pretty easily in any of the three cases. Wheel bearings will be the most difficult to replace, and I'd be tempted just to get some used axles off another truck. But they'll also be the easiest to diagnose: If you can jack up each rear wheel independently and push/pull with hands on opposite sides in a couple of positions to check for play, it's a good start. You can also try spinning the wheel to see if grinding happens, could isolate brake issues.
    You may also want to grab the drive shaft at the joints and check for play. Inspect the carrier bearing and its bolts to make sure it's both secure and not destroyed.
  6. Apr 9, 2024 at 5:05 PM
    JEVE615
    JEVE615 Old Yota Enthusiast
    Josh
    06 Tundra AC SR5 4.7
    Check for rust!!!
  7. Apr 9, 2024 at 5:54 PM
    Timjtitus
    Indiana and a salvage title!
  8. Apr 9, 2024 at 6:14 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    2003 V8 SR5, Access Cab, 4x4, White
    Run away.
  9. Apr 10, 2024 at 3:19 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    That's an oddly broad statement. A salvage-titled vehicle can be an excellent value depending on many variables (price, previous damage, repairs done, one's ability to DIY repairs/maintenance, etc.) I wouldn't think twice about buying the right vehicle with a salvage title.
  10. Apr 10, 2024 at 4:22 AM
    Depends whether your insurance company will insure. And how it’s handled can vary state by state, if I recall.
  11. Apr 10, 2024 at 4:47 AM
    joescho
    joescho New Member
    Joe
    Scranton,PA
    2024 Supersonic Red Platinum
    How does that get handled ? I never thought of that. I know you said it varies by state, but do they flat out refuse to insure it and you're SOL or do they end up insuring it and charge you a crazy premium?
  12. Apr 10, 2024 at 4:48 AM
    Many won’t offer full coverage. Which means you can’t have a lien on it.
    Jack McCarthy and shifty` like this.
  13. Apr 10, 2024 at 5:37 AM
    @Dakillacore may be able to elaborate on it, at least for state of GA. May also have a map or something for state-by-state.
  14. Apr 10, 2024 at 7:49 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    With the OPs own admission of the truck having unknown rear end problems, and now finding out it has a salvage title, there are hundreds of things that could be wrong with it. Are the rear end problems caused by how it ended up with a salvage title? Obviously need more history of this truck, but I still stand by my initial statement to run away. I personally wouldn't consider a salvage titled vehicle unless I was going to turn it into something that was not street legal.
    shifty` likes this.
  15. Apr 10, 2024 at 8:22 AM
    joescho
    joescho New Member
    Joe
    Scranton,PA
    Or something that wasn't a critical vehicle in your life.
    ATBAV8[QUOTED] likes this.
  16. Apr 10, 2024 at 11:16 AM
    Sounds like an outlier situation to me. Rebuilt is different than salvage though. Some may offer coverage for a rebuilt title, No one will insure a salvage total loss vehicle. That’s why it got totaled.
    BroHon and ATBAV8 like this.
  17. Apr 10, 2024 at 5:07 PM
    chunk
    chunk New Member
    110 miles north of Los Angeles, Ca.
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    In California, a salvage title reduces resale value considerably, so it should be priced accordingly, if all else checks out okay.
  18. Apr 10, 2024 at 5:11 PM
    weadjust
    weadjust New Member
    Tupelo, MS
    2006 Tundra Limited DC
    If you can live with the dings & dents. A hail damaged total loss/salvage title vehicle can be good deal. You will most likely only be able to get liability only insurance.
    The Black Mamba likes this.
  19. Apr 10, 2024 at 5:25 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Yep. Our 02 Corolla was a salvage title because of hail. I was was still able to insure it for liability. Hailey was a great car despite being a salvage title.
    bmf4069 and BroHon like this.
  20. Apr 10, 2024 at 10:33 PM
    Timjtitus
    It was a total loss from an accident. The diff was sealed poorly and gear oil leaked out.
  21. Apr 11, 2024 at 2:22 AM
    tvpierce
    Maine
    Did you buy it?
  22. Apr 11, 2024 at 3:44 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Weight reduction, mostly rust.
    Must be terminology nuances because when the storm/tornado damaged mine they "totaled" it.
    I'm insured with liability, and have glass coverage... Same company.
    I'm in Michigan (M?):anonymous:
  23. Apr 11, 2024 at 4:13 AM
    Timjtitus
    No
  24. Apr 11, 2024 at 4:40 AM
    Liability does not insure your vehicle. It insures the other guy you hit. The difficulty is getting them to insure the totaled vehicle with comprehensive coverage.
  25. Apr 11, 2024 at 5:35 AM
    Dakillacore
    Dakillacore This aggression will not stand, man.
    Georgia
    2006 Toyota Tundra Limited DC V8 2WD
    Sorry for being late to the party here but salvaged title vehicles are something to be very very weary of, depending on the damages. Here is a bit of information from my experience in collision repair..
    * Salvaged title vehicles can be perfectly fine if it was only hail damage that caused the issue and nothing structural or flood related. The state has to inspect every vehicle for "road-worthiness" before they will approve it to be insured again, but it cannot be insured unless that title is approved. The only issue with this is the state inspectors have no idea what it takes to repair the vehicles properly and are only completing the most basic of inspections(tail lights work, wheels turn, DOT regulations followed), so while you may be able to get approved and the title solid again it may not be actually safe. There are a lot of shops that will turn and burn a total loss, covering structural damage or completely bandaid up a flood damaged vehicle to make a quick buck. I have seen plenty of these type roll through my door and my god....they should not be on the road. State inspectors do not take off bumpers to complete a full inspection as it's only an exterior inspection.
    *If the vehicle is currently a total loss, you cannot get it insured until it has been approved by the state. As Shify said, it varies state by state. Some companies won't have a problem with insuring a salvaged vehicle but others don't want to be tied to one because it could have been a poor repair and liability could be a problem. Insurance companies are already pulling home insurance policies from high risk areas like California and Florida, and it's the same with a salvaged title vehicle. It's a high risk and could be either an expensive policy or they could refuse to insure it. Some companies probably won't care, but insurance companies are starting to tighten their belts due to climate disasters, cost of parts nowadays, and safety liabilities.
    joescho[QUOTED] and shifty` like this.
  26. Apr 11, 2024 at 5:37 AM
    Dakillacore
    Georgia
    Exactly this right here. Liability give you, the policy holder, jack shit when it comes to coverages. They will cover the person/thing that you hit but you get nothing.
    Hell, I have full coverage on all my cars, even the 98 Camry because in the event of an accident at least I will be able to get a TL settlement as a down payment on something else and a rental vehicle in the meantime.
    Side note: Check your policy for rental coverage! Most insurance companies do not include rental vehicle coverage in a full coverage policy. It will only add maybe $5-10 extra per month.
    shifty` likes this.
  27. Apr 11, 2024 at 6:38 AM
    The Black Mamba
    The Black Mamba He must increase, but I must decrease - John 3:30
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Michigan (MN)
  28. Apr 11, 2024 at 6:43 AM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    :confused:
  29. Apr 11, 2024 at 6:54 AM
    The Black Mamba
    Ryan
    DFW
    Imma keep it stock
  30. Apr 11, 2024 at 7:07 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Oh, yeah absolutely. I thought you were talking no ins period. Might not have had onboarded enough coffee yet ;)
