Check my logic
Discussion in 'Suspension' started by malibuskier, Jul 17, 2016.
  1. Jul 17, 2016 at 9:13 AM
    malibuskier
    malibuskier [OP] New Member
    Dave
    2010 Tundra CM Limited
    I posted this on another forum and in an effort to save time, I'm not going to rewrite it here. I hope everyone understands....
    I'm going to be the proud owner of a 2016 CM Platinum 4x4 very soon (in addition to my 2010 CM Limited). I want a little lift on a vehicle used for towing and minor off road play (dirt roads and muddy launch ramps). My parameters are as follows:
    1. Ability to return to stock if needed
    2. Least amount of wear and tear on the truck
    3. Retain stock adjustment specs/ride as much as possible (better is ok)
    4. Cost
    After reading a ton of threads, I think I have a decent plan. I want to add Coachbuilder +3 shackles and the Camburg Bilstein 6112 performance kit. What do you folks think? Does this make sense? Is there a better way? Thoughts?
    Dave
    bandit likes this.
  2. Jul 17, 2016 at 9:18 AM
    bandit
    bandit New Member
    2011 Supercharged Mazzulla Long Travel Rock Warrior
    Duh Tundra
    As long as you DON'T jump it. That seems like sound logic and should do you well. I did a muddy launch ramp and killed the bilsteins.
  3. Jul 17, 2016 at 9:22 AM
    malibuskier
    Dave
    There will be no jumping. What happened with the Bilsteins?
  4. Jul 17, 2016 at 10:17 AM
    bandit
    bandit New Member
    Duh Tundra
    Check the link in my signature. I ended up bending the shock itself. I also, am very good at breaking things....gives me an excuse to upgrade it. lol
  5. Jul 17, 2016 at 3:58 PM
    malibuskier
    Dave
    Holy smokes! Maybe now is a good time for me to clarify. By muddy launch ramp, I meant putting my ski boat in the water. Nowhere near the muddy launch ramps you are using! LMFAO!!!
    Dave
    bandit and 2cID like this.
  6. Jul 17, 2016 at 6:47 PM
    bandit
    bandit New Member
    Duh Tundra
    In that case you should be fine! :rofl: Clearly our definitions are a little bit different lmao
    malibuskier [OP] likes this.
