Check engine light
Discussion in '1st Gen Tundras (2000-2006)' started by 1stgentundradriver, Apr 27, 2021.
  1. Apr 27, 2021 at 9:53 PM
    1stgentundradriver
    1stgentundradriver [OP] Each sticker adds at least 5hp
    Josh
    Silverdale Washington
    2006 DC 4x4 Limited
    A few
    Welp, I went to start my truck today and I got a check engine light. Code p1442 secondary air injection switching valve no 2 bank 1 stuck closed. Anyone have experience with this code before or what may need to be replaced?
  2. Apr 27, 2021 at 10:12 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    It’s total normal. Next time you start your truck listen for a Whistle, last about 30 seconds and then shuts off. Should be coming from the intake.
    mine is on its way out and my buddy’s (sequoia 2007) had his go out and we did the bypass kit on it. He drove with the CEL for almost a year before fixing it. Most people on here also run the bypass kit. Link below.
    https://hewitt-tech.com/store/index...MI2sS2zZWg8AIVFRDnCh0RjgFYEAQYASABEgLlJfD_BwE
    video on install
    https://youtu.be/WDzNfW7Ti5g
  3. Apr 27, 2021 at 10:19 PM
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    Wondering if I need it to pass emissions? Would love to do a quick bypass kit too. I technically don’t have emissions in my county but If I was to, would this effect it. Will the bypass kit take away the check engine light?
    Edit- looked at the website. I’ll read more and ask more questions later. Thanks again @jerryallday!
  4. Apr 27, 2021 at 10:23 PM
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    Maybe I should ask, what is the benefit of running the bypass kit instead of fixing the issue? That seems like an expensive bypass kit.
    jerryallday likes this.
  5. Apr 27, 2021 at 10:27 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I think it comes down to time and money. My buddy passed smog in California no problem and CEL went away.
  6. Apr 27, 2021 at 10:30 PM
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    Interesting. I may have a shop quote the fix. And then I’ll compare it to the bypass kit. Obviously since you said your buddy had no issues driving it, I think I’m going to do the same but I’m gonna fix it ASAP. Thanks for your help, I really appreciate it! I also didn’t happen to see you were in California.
  7. Apr 27, 2021 at 10:35 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
  8. Apr 27, 2021 at 10:38 PM
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    Very interesting. Thank you for this thread. Again, I very much appreciate all your help.
  9. Apr 27, 2021 at 10:42 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    No problem, I’m sure by tomorrow morning there will be more reply’s in here.
  10. Apr 28, 2021 at 4:58 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Like Jerry said, time and money. Iirc the replacement AIP is stupid expensive.
    Tundra2 likes this.
  11. Apr 28, 2021 at 5:02 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Our sequioa (also 4.7L) has the other code for stuck open. Local mechanics wanted close to $1700.
    Mom, and pop took it to Bruce. I suggested the bypass the first time it popped codes.
    Popped codes for the second time about 3 months ago. They started asking me about the bypass. :rofl:
  12. Apr 28, 2021 at 5:15 AM
    Professional Hand Model
    Hand Protectors
    From readings, the bypass is a permanent ‘fix’ that bypasses the OEM dumb control. Going back with a new OEM assy of the same design will result in the same problem until it is ‘bypassed’.
  13. Apr 28, 2021 at 5:24 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Do the bypass, if you think the bypass is expensive wait for the quote to fix your problem.
    There is also a even cheaper kit, made by a member on T4r.org username Slyfox
    Look him up and send a email, under 60$ for a bypass with no block off plates
  14. Apr 28, 2021 at 5:41 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    This reads like a side quest!
    bmf4069 and FrenchToasty[QUOTED] like this.
  15. Apr 28, 2021 at 5:43 AM
    FrenchToasty
    Mo
    Bone stock
    Try if you have the might and the courage! Fail, and you will suffer eternal doom
  16. Apr 28, 2021 at 5:44 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I couldn't like this post any Mo even if I tried. :D
  17. Apr 29, 2021 at 10:38 AM
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    Okay so a little update. Decided to get a bunch of other things fixed along with whatever is associated with the check engine light. Truck is currently being worked on. If I get the same code after this I am going to pick up that delete kit. Thanks for all of your advice, I really appreciate it!
  18. Apr 29, 2021 at 12:04 PM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
  19. Apr 29, 2021 at 1:24 PM
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    @2006Tundra I beleive that is what others recommended. If something else happens with this code that is what I will use.
    just got done looking at your truck with the new paint job. Spent the last hour researching how much it would cost to paint mine the same Red color. Yours looks so amazing!
    2006Tundra likes this.
  20. Apr 29, 2021 at 1:43 PM
    2006Tundra
    Lou
    Long Beach, CA
    Keep us updated on your situation.
    Thank you very much. I'm really happy how the truck came out. Just keep in mind that supposedly any red paint jobs are going to be more expensive because the pigments used to make red are the more expensive. It cost me 5k to paint my entire truck with some minor dents fixed. My paint guy said if my truck was any other color, it would have been about 3-4K. I was lucky that my insurance took care of the paint job.
  21. Apr 29, 2021 at 9:56 PM
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    For sure. Red is the best color in vehicles if it’s dark deep shiny red. Not the fire engine red. Yours is exactly the color I’d like to paint mine. Salsa red?
  22. Apr 30, 2021 at 9:17 AM
    2006Tundra
    Lou
    Long Beach, CA
    Yup, Salsa Pearl Red. Color Code is 3Q3
