Check engine light
Discussion in 'General Tundra Discussion' started by ODSteve, Sep 23, 2014.
  1. Jan 5, 2015 at 8:18 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I have had the hypertech installed since 6/12/14 without a problem. Don't think that is it. I assume that the hypertech programming cant change unless its failed. If it failed i think there would be symptoms other than a MAF trouble code.
  2. Jan 6, 2015 at 11:41 AM
    Mike Tread lightly.
    south carolina
    After reading the hypertech website the firmware is rewriteable for the curves via usb connection. so firmware can get screwed up when loading it. It only takes one line or one number out of place to mess it up. I would rewrite the hypertech again to rule out a upload glitch. the way there software is done it doesnt check the checksums so the possible is there since it has got cold on you.
    Unless the hypertech has a cold solder joint somewhere. that would only show up when it cold...
    Keep us up to date on this.. running some ideas off the top of my head that might help..
    T-Rex266 likes this.
  3. Jan 7, 2015 at 3:49 PM
    csuviper
    Broomfield, CO
  4. Jan 7, 2015 at 4:26 PM
    Mike Tread lightly.
    south carolina
    Is the cel coming on when the scangauge reports the fault?
  5. Jan 7, 2015 at 4:47 PM
    csuviper
    Broomfield, CO
    No not the last two times
  6. Jan 7, 2015 at 5:03 PM
    Mike Tread lightly.
    south carolina
    Ok the ecm is stored the code its not a problem to the ecm yet why no cel.... To me looks like you have some sort of drop out either in the maf or in the hypertech..
    Scangauge is not fast enough to catch the drop out only a lab scope can get the drop out.
    I would try to disconnect the hypertech( if you can) and see if the code hits up again.. rule out the hyper tech in or out of the problem..
  7. Jan 7, 2015 at 8:20 PM
    csuviper
    Broomfield, CO
    Hypertech :(
    Removed and drove 75-80 and no code. Crap.
  8. Jan 7, 2015 at 8:31 PM
    Bummer...have you googled this to see if there's a simple solution such as a firmware update?
  9. Jan 7, 2015 at 9:28 PM
    csuviper
    Broomfield, CO
  10. Jan 7, 2015 at 9:29 PM
    csuviper
    Broomfield, CO
    Haven't been home yet to try.
    Thank you everyone for helping troubleshoot. I'll have to do some research and prob call Hypertech tomorrow as well.
  11. Jan 8, 2015 at 11:55 AM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Damn...
  12. Jan 8, 2015 at 8:42 PM
    Mike Tread lightly.
    south carolina
    Hypertech might have a work around no hope is lost... looks like we found the problem..
