Check engine light
Discussion in '2.5 Gen Tundras (2014-2021)' started by Medic, Apr 4, 2016.
  1. Apr 4, 2016 at 10:05 PM
    Medic
    Medic [OP] New Member
    Ontario, Canada
    2014 Limited Crew Max
    Just had a check engine light come on in my 2016 Tundra. Have tried disconnecting the battery to do a reset with no change. Going to call the dealership tomorrow and book an appointment. Question is should I disconnect my Hypertech before taking the truck to the dealership?
  2. Apr 4, 2016 at 10:06 PM
    What's the code read? Can you get it scanned first?
  3. Apr 4, 2016 at 10:10 PM
    Medic
    Ontario, Canada
    I don't have a code reader. Not sure if anyone close has one either.
  4. Apr 4, 2016 at 10:13 PM
    Medic
    Ontario, Canada
    Truck through a check engine light when I installed the hypertech but I was able to clear it but disconnecting the battery. Haven't had any problems for approx 2000 kms.
  5. Apr 5, 2016 at 8:31 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    I would suggest disconnecting the Hypertech if for no other reason than to deny the stealership an excuse to blame you.
  6. Apr 5, 2016 at 8:47 AM
    Medic
    Ontario, Canada
    After my night shift, the engine light is out. Stopped by a local garage and the only code we could find is a permanent mass air flow problem. I am assuming it is from the install of the hypertech. Anyone know if you can delete permanent codes?
  7. Apr 5, 2016 at 8:49 AM
    @csuviper didn't u have a similar CEL with the HT?
  8. Apr 5, 2016 at 10:38 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
