Check engine light on, traction control off, and can’t see P R N D on the display
Discussion in '2.5 Gen Tundras (2014-2021)' started by Michaeltxz71, Jun 24, 2019.
  1. Jun 24, 2019 at 6:00 AM
    Michaeltxz71
    Michaeltxz71 [OP] New Member
    Michael
    2014 Metallic gray SR5 DC 4x4
    2014 SR5 DC 4x4
    After two days of travel up to Flagstaff Arizona, from Texas. After parking and getting camp all set up, I noticed my check engine light was on, traction control off display, can’t see P R N D display and my review camera won’t come on? Has anyone gone through this??? Thank you
    Michael
  2. Jun 24, 2019 at 6:12 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Very similar to what happened to me after I installed an aftermarket stereo. Definitely was my fault, but pissed me off so bad I put in an oem nav unit.
    These trucks seem to have weird electrical systems, good luck and I’ll be watching this thread.
  3. Jun 24, 2019 at 6:20 AM
    Welcome to the site.
    Anything under the hood that might be an indicator?
    -check wiring harness on drivers side by firewall. May have had a rodent do damage before and now just finally failed.
    -Will the truck run and drive?
    Now the more technical stuff. You probably don’t have a scanner on you, but if you do:
    P0705 transmission range sensor circuit malfunction
    Kerch71, Black Wolf and jeremyd like this.
  4. Jun 24, 2019 at 6:53 AM
    Michaeltxz71
    Michael
    Everything sounds good, she drives! I disconnect the battery, all errors gone, but review camera won’t come on. Going to take it for drive and push her to see what happens. If something happens then I’ll take it to a dealer
    Black Wolf and ColoradoTJ like this.
  5. Jun 24, 2019 at 7:01 AM
    Did you tow a camper by any chance? May have blown a fuse for the rear camera.
    jeremyd, Black Wolf and texasrho83 like this.
  6. Jun 24, 2019 at 8:04 AM
    Michaeltxz71
    Michael
    Yes I pulled a 24’ camper without water
    Just drove her, up and down hills, speeds up to 70, rpm work just like before, still no camera or drive display. I will check out the fuses! Thanks for the info, so far away from home and I’m thinking the worst. Let’s hope not
  7. Jun 24, 2019 at 8:08 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    My rear camera takes a little while to come back on after disconnecting the battery. Hopefully yours just comes back on.
  8. Aug 1, 2019 at 9:32 PM
    Bradmswain
    Bradmswain New Member
    Brad
    Mississippi
    2013 Black Tundra Crewmax 4x4
    M1 bumpers front and back. 10,000 lb winch. 6 inch suspension lift. 37x12.50x20 Hercules tires. Black 20 inch LRG wheels. Flowmaster super 40 series with turn downs. Smoked taillights. Black grill. Black nerf bars. 5% tint sides and back. Kicker subs and door speakers.
  9. Aug 1, 2019 at 9:36 PM
    Did you have a question Brad?
  10. Aug 1, 2019 at 9:46 PM
    Bradmswain
    Brad
    Mississippi
    My check engine light and traction control light came on and the 4lo light blinks. I bought a $370 neutral safety switch because the guy at autozone read the code wrong. I took it to my mechanic when I got back home. He said it was a sensor located on top of the transmission. Has anyone else had this problem? If so how hard is it to replace?
    ColoradoTJ likes this.
  11. Aug 2, 2019 at 1:31 AM
    I would take that 370.00 back to the parts store. Damn.
    The sensor you’re talking about is the range sensor, but I personally have not changed one out. Probably a support bolt and this is attached to the shift linkage cable. Probably not a bad job to perform.
    NewImprovedRon and Black Wolf like this.
  12. Aug 2, 2019 at 2:31 AM
    Bradmswain
    Brad
    Mississippi
    They broke the neutral safety switch when they was trying to get it off. So I’m stuck with that bill.
  13. Sep 6, 2019 at 6:43 PM
    W3LCH
    W3LCH New Member
    Anthony
    Albany NY
    2014 Black Tundra SR5
    Remote Start
    I have the same issues where can I find a range sensor?
  14. Sep 6, 2019 at 7:01 PM
    Michaeltxz71
    Michael
    I have a 2014 DC 4x4 SR5. I install a trailer break controller. With that being said, somewhere from the trailer to the plug or my install, there is a short. So after my trip, no use for my controller, I unplug it from under the dash, there is no trailer plug to the bumper. I disconnect the battery, change the fuse, connect the battery, turn on truck, no errors! It’s been 2 months nothing Hope this helps! Good luck!
  15. Sep 6, 2019 at 10:38 PM
    TTund16
    TTund16 New Member
    I get bunch of lights on (iirc, engine and traction control and 4wd) if the battery is weak. Never checked the camera. If I start the car and lights are on, I let it run for a minute or two and then restart. All lights go off.
    There are couple of threads about this including mine.
  16. Sep 7, 2019 at 12:24 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    I had the same exact issue after installing LED reverse lights on my 2012.
    Well, after one popped that is.
    It blew, out went the other side and then the camera turned off.
    I was done driving for the night so I said screw it and forgot about it till the next day.
    The CEL and trac off didn’t come on till after 2 trips the next day.
    The Bk/Up fuse was blown under the dash.
    Problem was solved after I replaced the light and the fuse.
