Check engine lighjt
Discussion in '1st Gen Tundras (2000-2006)' started by Hearne1954, Mar 8, 2021.
  1. Mar 8, 2021 at 10:53 AM
    Hearne1954
    Hearne1954 [OP] New Member
    Joe
    2004 Tundra
    I’ve got PO325 code I’ve replaced knock sensor but engine light refuses to stay off any suggestions
  2. Mar 8, 2021 at 2:33 PM
    Professional Hand Model
    Hand Protectors
    Both Knock Sensors? Brand?
  3. Mar 8, 2021 at 2:44 PM
    Hearne1954
    Joe
    2004 Tundra
    No just bank one Denso was brand
  4. Mar 8, 2021 at 2:50 PM
    Hand Protectors
    Bummer man. Those are High Dolla not to mention all the work to replace. Hope you figure it out.
  5. Apr 30, 2021 at 2:51 PM
    DaWhiteTundra
    DaWhiteTundra New Member
    Anthonee
    Sacramento, Ca
    White 2002 sr5 v6 Rwd
    Lsd (Blistein 5100’s all around, eibach lift springs, eibach 1inch rear block, daystar 2.5 inch lift w/wheelers all, 13wl caliper swap, Powerstop slotted drilled rotors, ss brake lines, otw)
    Did you figure it out?
    I’m getting ready to get in there... so I can’t speak from experience. But from what I’ve read the wire and the knock sensors are super fragile because it heats up with the intake. My buddy who gives me advice on work I do to my vehicles told me don’t even touch that wire or the sensors if you don’t have to. They break on their own sometimes.
    I have to change the gasket on my bypass pipe and am going to change the wire harness while I’m in there. I’m hoping my knock sensors aren’t brittle af and don’t break when I try to pull the plugs on them.
