Cheap amazon light bar in hood bulge
Discussion in 'Lighting' started by TRDProLife, Apr 15, 2021.
  1. Oct 19, 2021 at 7:04 PM
    #61
    RobertD
    Robert
    DFW, Texas
    I had checked Amazon and 4wdking's homepage and was thinking it was protective film since none were listed as blue but was hoping I was wrong lol
  2. Oct 22, 2021 at 4:08 PM
    #62
    ErikTRDTUNDRA
    ErikTRDTUNDRA New Member
    Erik
    2018 Tundra crewmax 1794
    So update , I got everything apart and ready to install and the mounts provided do not work. Will need to purchase the aftermarket mount kit for the light bar
  3. Oct 22, 2021 at 5:57 PM
    #63
    Nonor
    Nonor New Member
    Ok, finally arrived and with some finessing I got to work perfect! 3444FD58-340B-44EF-86AA-D5E42823ACFA.jpg658CCA8F-6041-457C-AE20-75E3BC00B6C4.jpg
  4. Oct 22, 2021 at 6:58 PM
    #64
    Nonor
    Nonor New Member
    What’s the problem with the brackets?
  5. Oct 22, 2021 at 7:41 PM
    #65
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM Tundra & 25 TRD Pro Sequoia
    did you install the light bar behind the mesh?? that looks killer! Do you have anymore pics of the install?? And can you post up some night shots??
  6. Oct 23, 2021 at 8:29 AM
    #66
    ErikTRDTUNDRA
    Erik
    They are way to small, they are only about 1.5 inches
  7. Oct 23, 2021 at 10:28 AM
    #67
    Nonor
    Nonor New Member
    Yeah, to short. This light comes with 2 mounts. I did install behind the mesh, I’m sure I loose some light but not enough to make me worried, I like the extra stealth/finished look. It wasn’t full night time, but that’s what I got yesterday.
  8. Oct 23, 2021 at 10:32 AM
    #68
    ErikTRDTUNDRA
    Erik
    Looks good bud, you went with the Nilight?
    Nonor[QUOTED] likes this.
  9. Oct 23, 2021 at 2:46 PM
    #69
    Love the scenery...no mountains here in this hot @$$ state.
  10. Oct 24, 2021 at 10:47 AM
    #70
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    looks so good! Did you have to modify the plastic grill insert at all to get the light to fit behind it?
  11. Oct 24, 2021 at 12:56 PM
    #71
    Nonor
    Nonor New Member
    I just snapped the top tabs and reused the screws, I did use a step drill to make the brackets holes bigger because the light was hitting the plastic cover that way I was able to “move” the light down a bit.
    mav7021234 and Toe404 like this.
  12. Nov 4, 2021 at 8:42 PM
    #72
    ErikTRDTUNDRA
    Erik
    Finally got the light bar installed. Looks very clean and OMG it’s bright. I may need to adjust it down a bit but overall very happy. I’ve only been cut off once since the bar has been installed but trust be who ever the poor sap was I’m sure he is still seeing spots when he closes his eyes.
    icodeintx and Toe404 like this.
  13. Nov 4, 2021 at 10:44 PM
    #73
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    Pics?!?!
  14. Nov 5, 2021 at 5:24 PM
    #74
    Merkopac661
    Merkopac661 New Member
    White 2018 Tundra Sport 4x4
    I got the Nilite 41". The corners of the hood bulge stick up. Ive done everything I can think of to get it to line up. Ive cut a slot where the original hole in mounting bracket was so I can adjust the height up and down on the bar. Ive set it so far back that the allens that connect brackets to light bar are inside the bulge and dropped down 1/8" and bulge still sticks up on the corners. I took light out and bulge still sticks up? Maybe bulge warped out of shape or maybe bent weak metal on hood where the holes for the black tabs from bulge go? Any advice? Pics coming
    mav7021234 likes this.
  15. Nov 5, 2021 at 5:27 PM
    #75
    ErikTRDTUNDRA
    Erik
    Have you removed the outer tabs of the hood bulge ?
  16. Nov 5, 2021 at 5:29 PM
    #76
    That's definitely a no-no for sure!
  17. Nov 5, 2021 at 5:33 PM
    #77
    Merkopac661
    If your talking about the top outer tabs on hood of truck where the black round tabs press into. I trimmed those so I can still use black tabs. If yourtalking about trimming tabs on hood bulge itself, I haven’t trimmed anything in hood bulge.
  18. Nov 5, 2021 at 5:35 PM
    #78
    ErikTRDTUNDRA
    Erik
    Have you reviewed the sdhq installation guide ?
  19. Nov 5, 2021 at 5:36 PM
    #79
    Merkopac661
  20. Nov 5, 2021 at 5:38 PM
    #80
    Merkopac661
    Sorry about sideways photos. I suck
    Tundra14Platinum likes this.
  21. Nov 5, 2021 at 5:41 PM
    #81
    Merkopac661
    I will read this. thank you. I already ordered the sdhq bracket just couldnt wait for it to arrive. Hope I didnt mess up drilling mounting holes for nilite bracket.
  22. Nov 5, 2021 at 5:45 PM
    #82
    Merkopac661
    As far as bar goes. It works good if I can get it mounted right. Its bright and I like the looks of it when its off.
  23. Nov 5, 2021 at 5:46 PM
    #83
    ErikTRDTUNDRA
    Erik
    The bracket you get with the light should be sufficient with the modifications you made to it. There is also a fairly decent install video on YouTube of the nilight installed in the hood bulge. Check it out
  24. Nov 5, 2021 at 5:50 PM
    #84
    Merkopac661
    Thanks for the replies. Im gonna give it another go tomorrow after work.
  25. Nov 5, 2021 at 5:51 PM
    #85
    ErikTRDTUNDRA
    Erik
    Here are a few pics of mine installed
  26. Nov 5, 2021 at 7:56 PM
    #86
    Merkopac661
    This is the step I missed. Trimming the outer plastic brackets on the hood bulge. I think this will solve my problem. Thanks
    Toe404 likes this.
  27. Nov 21, 2021 at 10:13 AM
    #87
    Sonicbluerider
    Sonicbluerider New Member
    Dennis
    2019 Tundra
    So I watch the video an first he says no possible light adjustments then proceed to say he went outside an adjusted light without telling you how he adjusted it. So is there or is there not adjustments on this?
  28. Nov 21, 2021 at 10:17 AM
    #88
    ErikTRDTUNDRA
    Erik
    I actually have planned on adjusting mine today. I will let you know if and how much adjustment I get. Mine is just a touch too high .
  29. Feb 22, 2022 at 12:31 PM
    #89
    20Tundra_sauce21
    20Tundra_sauce21 New Member
    I have the same set up and using the provided bracket but im having trouble putting the hood bulge back on without the plastic screen hit the light and making it bulge up.
    can you send me some pictures of you have any on how you prevented them bulge on the corners
  30. Sep 30, 2022 at 6:46 PM
    #90
    mav7021234
    mav7021234 New Member
    Do you have a picture of how far down you drilled on the bracket?
