Changing Valve Cover Gaskets
Discussion in '2nd Gen Tundras (2007-2013)' started by Les7311, Jan 20, 2017.
  1. Oct 19, 2019 at 8:32 PM
    Les7311
    Les7311 [OP] Look up, what do you see
    2008 Blue Tundra TRD 4x4
    I think if remember from the firewall I need a pic.
    HbbTundra08[QUOTED] likes this.
  2. Oct 20, 2019 at 11:47 AM
    HbbTundra08
    HbbTundra08 Epstein Didn't Kill Himself
    Brad
    2008 Toyota Tundra Crewmax SR5 2wd 5.7L
    TAC Stainless Steel Bull Bar RCI Steel Engine Skid Plate Two Stainless Steel 100w KC Daylighters Black Husky Weatherbeater Floor Liners front and rear. Kenwood Media System with Rear License plate backup camera integrated.
    Thanks so much for the reply, minutes later I found the lower left bolt hidden behind the metal coolant lines:rolleyes:
    I waited till this morning and put the cover back on and buttoned everything up! Runs fine, no leaks seen, and most importantly...no check engine lights:)
    I’ll post a few key photos here soon to help others get some other views of the engine bay.
    Les7311[QUOTED][OP] likes this.
  3. Nov 4, 2019 at 10:05 AM
    jbriceno
    jbriceno New Member
    Jorge
    2011 Toyota Tundra Crewmax 2x4 5 inch lift
    2 inch leveling spacer with 3.5 inch lift spindle and 2.5 inch rear blocks with AirLift 5000 Ultimate airbags
    Gee, I sure wished I had read your thread Les7311 before I changed out my spark plugs (100,233 miles). I found oil in 4 of the plug ports but didn't think to syphon it out with a small vacuum hose, hence when I removed the plugs oil penetrated into the cylinders. When I started up my truck much blue smoke came out for about one minute until it cleared. Hopefully I didn't end up fowling a plug or two. Truck seems to run fine and strong and no codes coming up nor any missing. I may go back and syphon the oil from the one that I saw had most then pull the plug and check it to see if any oil on the tip. Probably burned off by now, I hope. I did copy and past your post on changing the VCG and tube seals, but may wait a little before tackling this project. Appreciate the post and picks. Question. Is it necessary to pull the plugs when changing the VCG and Seals? Thanks for your reply...Jorge
    Les7311[OP] likes this.
  4. Nov 4, 2019 at 3:12 PM
    Les7311
    Sure to pulling the plugs. You already down there in the “gutz”, so a few more minutes won’t hurt, than having to go back later.
    the tub seals are most likely compromised since you have oil on the plugs.
    Good luck bud, and post up.
  5. Jun 18, 2022 at 2:33 AM
    Pheckphul
    Pheckphul New Member
    2008 Toyota Sequoia Platinum 5.7L
    I'd aim this at the OP, but it seems he hasn't been on here in over a year; hope he's alright.
    Am I missing something, or did @Les7311 leave all the sensors in the valve covers when he removed them? Is that kosher? In the write up on another board the guy removed them all.
    Yes, I'm still fussing with replacing my valve cover gaskets. I haven't had the time to get back to them in the last couple of days, much to the annoyance of my wife.
  6. Jun 19, 2022 at 6:54 PM
    WVI
    WVI New Member
    @008 Tundra Limited
    I just did the P-side on my truck today...at least almost got it done...
