Changing the oil viscosity in my 2018 Tundra
Discussion in 'New Member Introductions' started by Spectre65, Jul 18, 2021.
  1. Jul 18, 2021 at 1:00 PM
    Spectre65
    Spectre65 [OP] New Member
    William
    2018 Tundra TRD 4X4 Sport Crewmax
    K&N air filter. Magnaflow catback dual exhaust system.
    Hey everybody! Greetings from SC.
    I have a 2018 Tundra with almost 50k miles on it. I've been taking it to the dealership for oil changes and they've been putting 0w20 Mobil 1 synthetic in it. I'm going to start back changing my own oil and I want to change to 5w30 Mobil 1 synthetic back in it.. The dealership says that it could "void" the warranty if I have an oil related engine failure due to running a heavier viscosity; which I've never heard of happening with good synthetic oil. Any thoughts on switching to 5w30?..... Thanks!
  2. Jul 18, 2021 at 2:10 PM
    Tyman
    Tyman Isaiah 41:10
    Tyler
    Indiana
    2020 Tundra Sport 4wd MGM
    First in on a oil thread! Why do you want to switch?
    GODZILLA likes this.
  3. Jul 18, 2021 at 3:11 PM
    Spectre65
    William
    I want to change to 5w30 because I live in the Southeast where we have more of a warm/ hot climate the majority of the year. I feel like 0w20 is too thin and more of a break in type viscosity.. Plus I have a 99 F-150 that had 12k on it when I bought it in 2000; it now has almost 267k on it and still running like a top. I attribute it's longevity to using 5w30 Castrol or Mobile 1 synthetic motor oil every 5000-7000 miles..
  4. Jul 18, 2021 at 3:14 PM
    18" TRD Off Road Wheels
    Spectre65[OP] likes this.
  5. Jul 18, 2021 at 4:15 PM
    AZBoatHauler
    So.Arizona
    I switched to 5w-30 at 50k with no ill effects. Engine sounds smother/quieter. Do you have an extended warranty? If not, it’s about up anyhow.
  6. Jul 18, 2021 at 8:08 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! I live on the Alabama gulf coast. My wife's Highlander has been using 0W20 for over 250k miles and still runs like a top. From the 2018 manual:
    Tyman likes this.
  7. Jul 20, 2021 at 6:08 PM
    Spectre65
    William
    Thanks for the replies and the info. I appreciate it.
  8. Jul 20, 2021 at 6:12 PM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    Toyota dealerships use 5w30 in Mexico for all the UR and GR engines... And it's the only option offered
  9. Jul 20, 2021 at 6:19 PM
    Spectre65
    William
    Good to know! Thanks C.I.
  10. Jul 20, 2021 at 6:22 PM
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    Check your manual and it will show you which oil to use for the temp range you drive in. Honestly I think you’re perfectly safe with either. It’s not going to cause some catastrophic failure.
