Change in quality of ride of 1.75" front leveling kit vs rear+front (2"/3")
Discussion in '3rd Gen Tundras (2022+)' started by nrm91, Jul 18, 2022.
  1. Jul 18, 2022 at 3:43 PM
    nrm91
    nrm91 [OP] New Member
    Boise, ID
    2022 Platinum CrewMax Magnetic Grey
    35/11.5/20 Toyo AT III's
    Looking to do either a front-leveling kit on my 22 CM Platinum or a 3" rear + 2" front and then get 35"/11.5/R20 Toyo A/T III's. Would there be a noticeable difference in ride quality between the two options?
    Front kit or Rear + Front Kit
    I will do a little bit of off-roading, but I am worried if I raise both and get the bigger tires, I might have too big of a lift for what I need (wife might not like it either). Can anyone speak from experience on these two options?
  2. Jul 18, 2022 at 3:49 PM
    jmay86
    jmay86 New Member
    Josh
    Columbus, Ohio
    '22 Lunar Rock LTD DC TRD-OR
    That 3/2 rear kit won’t work for the new models… no more leaf springs…
  3. Jul 18, 2022 at 4:01 PM
    nrm91
    Boise, ID
    Oh shit, well that makes it easy. The front-leveling kit will work though, right?
    Yaboy likes this.
  4. Jul 18, 2022 at 4:02 PM
    jmay86
    jmay86 New Member
    Josh
    Columbus, Ohio
    Some have found last gen front spacers to work, but I can’t speak from experience… I went with the Westcott Designs 3/1 kit…
  5. Jul 18, 2022 at 7:29 PM
    t300
    t300 New Member
    Manitoba
    22tundra
    Someone on here put cornfed suspension 2/1 on and said ride quality still good. Another option. That’s what I bought, just don’t have a truck to put it on yet
  6. Jul 18, 2022 at 7:44 PM
    bcj001
    bcj001 New Member
    Brad
    Oregon
    22' Tundra Limited
    you don't need a lift or level for 35x11.5R20..... then your ride quality will still be "just like stock".... with just a little more meat on the ground =) (at least using the stock TRD wheels.... 35x12.5R20 I believe rub.... and benefit from a level / lift). I purchased a 2" spacer level kit, and ended up not needing or using it....
  7. Jul 18, 2022 at 8:43 PM
    nrm91
    Boise, ID
    Oh interesting, I thought for 35" tires, I needed the front to be lifted a bit to prevent rub. So did you just do stock leveling and add 35x11.5R20 tires? If so, out of curiosity, what tires did you go with?
  8. Jul 18, 2022 at 9:07 PM
    brucega7x
    brucega7x New Member
    2022 Tundra SR5 CrewMax 4X4
    Tires made my ride far stiffer than just the leveling kit did.
    When it was just leveled it felt identical to factory.
    Stiffer E rated tires made the ride quite stiff.
  9. Jul 18, 2022 at 9:11 PM
    nrm91
    Boise, ID
    Damn, not what I wanted to hear. What tires did you get?
  10. Jul 18, 2022 at 9:13 PM
    brucega7x
    35” Goodyear UltraTerrains
  11. Jul 18, 2022 at 9:17 PM
    nrm91
    Boise, ID
    Oh interesting, I've been looking at the Toyo A/T IIIs and have heard really good things about them, so maybe it's just those tires?
  12. Jul 18, 2022 at 9:19 PM
    brucega7x
    I dunno. E rated tires are generally very stiff by design. Maybe someone who knows better than me could tell you.
    It’s not unbearable. Just saying in my experience they’re definitely not the way to go if trying to maintain the smooth OEM ride.
  13. Jul 18, 2022 at 9:20 PM
    nrm91
    Boise, ID
    What would be the biggest size you'd recommend if I wanted to keep my ride quality?
  14. Jul 18, 2022 at 9:22 PM
    brucega7x
    It’s not the size that’s the issue, it’s the load rating. E is very stiff. I believe D is what the truck comes with. But I don’t think there’s a whole lot of bigger tires that come in a D rated tire.
  15. Jul 18, 2022 at 9:24 PM
    bcj001
    bcj001 New Member
    Brad
    Oregon
    22' Tundra Limited
    I didn't level at all, left it stock... I have zero rubbing at full turn on the liner, or mudflaps... truck is totally factory / stock just installed the new tires on the factory TRD rims. (if you click image below my user name, and go to media you can see before and after). I went with the Nitto Recon Grapplers in 35x11.5R20. I didn't really notice a ride change with the E rated tires, but it might be a little stiffer... (changed tires at ~400miles). I can say I like these recon grapplers better than the KO2's I was running on my last truck... If it matters, just finished a big camping trip, and very impressed with the trucks towing vs my 2016 GMC 1500... Zero issues climbing the big hills with the trailer (~6k pound travel trailer).
    jeosbor1 likes this.
  16. Jul 18, 2022 at 9:33 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    If you’re running stock wheels consider 275/65/20’s
    Troa likes this.
  17. Jul 18, 2022 at 9:34 PM
    nrm91
    Boise, ID
    Thank you for sharing. I was considering those tires, but think I am going to go with the Toyo A/T IIIs instead, just based on some of the stuff I have read. Though it seems like I can't really go wrong with either
  18. Jul 26, 2022 at 4:18 PM
    rboyer224
    rboyer224 New Member
    Robert
    2022 SR5 TRD Off Road Army Green
    None Yet
    So I'm assuming that same size but in the 18" Wheel/rim would also fit stock suspension? Thanks.
  19. Jul 26, 2022 at 4:31 PM
    Chapp
    Chapp New Member
    2022 Tundra TRD Off Road
    Stock....for now
    Im waiting on a 2 inch spacer lift from Rogue Offroad in Vegas, along with some Methods and 34 inch Falken Wildpeaks. Ill post once I get it in and see how it rides.
    rboyer224 likes this.
  20. Jul 26, 2022 at 7:05 PM
    jeosbor1
    jeosbor1 New Member
    North Carolina
    2022 Lunar Rock Limited TRD OR
    Two inch Super Lift didn't cause any noticeable ride quality changes.
    Chapp likes this.
  21. Jul 26, 2022 at 8:01 PM
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    Modest lifts do not prevent rub with 35s or smaller. Look at where rubbing occurs (front and rear of the well, maybe skid) and it should be pretty obvious that you'll still rub there when the suspension compresses, and often even if it doesn't. For 37s you might need a lift to keep from hitting the top of the well.
    Gen3s are cool because you can fit 35s easy if get the right offset wheels... no mods needed. Earlier models required quite a bit of futzing around... but a *lift* was not required.
  22. Jul 27, 2022 at 5:50 AM
    nrm91
    Boise, ID
    So can I run Toyo A/T IIIs on my stock Platinum wheels in 35/11.5/20?
