Center seat belt help.
Discussion in '1st Gen Tundras (2000-2006)' started by Dan32981, Apr 1, 2021.
  1. Apr 1, 2021 at 12:30 PM
    Dan32981
    Dan32981 [OP] New Member
    2005 Tundra quad cab limited edition
    Hi all, new member here. I have a 2005 Quad cab limited Tundra. My rear center seat belt is locked and will no longer extend or retract? I popped back seat panel open a bit but couldn't see the retractor. Anyone experience this or have a way to fix it? Thanks!!!!
    Dan.
  2. Apr 6, 2021 at 4:29 PM
    I don't have any experience with this, the AC only has a lap belt in the center, but will bump this back up to the top to see if someone else can help. Welcome to the forum and thank you for your service.
  3. Apr 6, 2021 at 8:02 PM
    Dan32981
    KNABORES, Thanks for bumping the post back up.
    Dan.
  4. Apr 7, 2021 at 10:51 AM
    peanut
    peanut making uneconomical choices about my truck
    2001 Tundra 4x4 V8 Access cab 222k miles
    Is the belt & retractor installed in the car correctly? I had mine out to clean the belts up and they got locked up because the catches inside weren't in their normal orientation. I found a youtube video that explained that when they lock up you have to have em in the installed orientation and then pull on the belt in the gentlest and smoothest manner you can. Just barely any tug at all. Like you're trying to not scare the mechanism. After that they've been working fine. Maybe it'll help?
  5. Apr 7, 2021 at 10:53 AM
    peanut
  6. Apr 7, 2021 at 1:52 PM
